355 - F355 Stuttering | Page 3 | FerrariChat
355 F355 Stuttering
Discussion in '348/355' started by goodcoffeecode, Dec 18, 2021.
  1. goodcoffeecode
    goodcoffeecode Karting
    Dec 18, 2021
    82
    Devon, UK
    Chris Arnold
    Excellent, thanks. I've ordered the cable adapter and a scanner, so hopefully they'll be here tomorrow.
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    Theair injection pipe being loose could be the cause of the Slow Down light flashing. To much unburnt fuel getting into the cats and they over heat.
  3. Qavion
    Qavion F1 World Champ
    14,601
    Ian Riddell
    Which company did you order the adaptor from? Some adaptors may have oversized pins. Avoid the "Goliton" brand.
    If you need more information on the wiring going into those extra engine harness plugs, the plugs are numbered accordingly:
  4. goodcoffeecode
    Dec 18, 2021
    82
    Devon, UK
    Chris Arnold
    Ah, I literally just order this: Goliton® OBD OBD2 16 Pin Connector Diagnostic Adapter for FIAT 3 Pin: Amazon.co.uk: Computers & Accessories.
    Are any of these better?
    Qiilu 3 Pin to 16 Pin OBD2 Adapter Connector Diagnostic Cable for Fiat Alfa Lancia: Amazon.co.uk: Automotive
    Diagnostic Cable, 3 Pin to 16 Pin OBD2 Adapter Connector Diagnostic Cable replacement for Fiat Alfa Lancia Diagnostic Cable : Amazon.co.uk: Automotive
  5. Qavion
    14,601
    Ian Riddell
    What are all these loose wires (circled)? Something you were inspecting?
    Keep an eye on the power steering reservoir cap. The older type sometimes splits and fluid spills out.
  6. Qavion
    14,601
    Ian Riddell
    Not sure, but the Amazon star rating may be a clue. The Goliton brand shows only 3 stars.
  7. goodcoffeecode
    Dec 18, 2021
    82
    Devon, UK
    Chris Arnold
    Pretty sure those wires are for a trickle charger.
  8. goodcoffeecode
    Dec 18, 2021
    82
    Devon, UK
    Chris Arnold
    OK, started it up and let it warm through for 5 mins. Sounded "ok", but my ears aren't yet attuned to what "normal" sounds like. Once warm, it did seem to rev freely to about 4k revs. Time to drive it around the block...
  9. goodcoffeecode
    Dec 18, 2021
    82
    Devon, UK
    Chris Arnold
    Hmm, that didn't work. I think it's definitely a misfire. Can really start to hear the bup bup bup. I'll get the spark plugs out tomorrow.
  10. 26street
    26street Formula Junior
    Jan 30, 2021
    473
    Westchester New York
    Mark k
    This tool from snap on is a easy way to find which cylinder is missing with out removing the plug wire and damaging the coil
    you can find cheap on eBay and other sites
    Weak and miss firing will damage the cats and make them overheat so driving or even running for long periods of time till fixing the problem can really hurt the cats so the faster you find the problem less expensive the repair will be
  11. Shorn355
    Shorn355 F1 Veteran
    6,885
    Colorado
    Scott
    Yep - or simply won't tighten fully and fluid seeps out - Fortunately replacing the reservoir (comes with cap - can't just do the cap) is one of the least expensive things on 355 and easily obtained from various sources - I always prefer Ricambi but your call - Cheers :)
  12. Shorn355
    Shorn355 F1 Veteran
    6,885
    Colorado
    Scott
    Agree - precisely where my Battery Tender is connected and pigtail exits - the pos/neg posts are under that cover -
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    Where did you get this car? Did you not have it inspected before buying?
  14. goodcoffeecode
    Dec 18, 2021
    82
    Devon, UK
    Chris Arnold
    Bought from an independent dealer. Car had only recently had a major service and has run really well until this. It's also still under the dealer's warranty.
  15. Qavion
    14,601
    Ian Riddell
    I haven't really looked into these. It looks like they are hard to find (new)... P/N 167002. I see some are fitted with aluminium Ferrari caps:
    https://redbaycars.com/webshop.html#!/ferrari-f355/products/oil-tank-with-cap-f355-0x2f-360-part-nr-167002
    The tank is relatively cheap, so just P&H and labour.
  16. johnk...
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    Mine (95) is original and no problem. I have suspected for a long time that the real issues are 1) over tightening the car which splits it, or 2) the tank is mounted too low and the cap contacts the plastic piece that covers the throttle linkage before the cap is tight.
    Anyway, no big deal. BMW part $10 at Rock Auto (1989 BMW 325i)
    Qavion likes this.
  17. yelcab
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    Then why are we worrying about this when it is still under the dealer's warranty?
  18. goodcoffeecode
    Dec 18, 2021
    82
    Devon, UK
    Chris Arnold
    I was hoping it was something simple i could fix myself over the Xmas period - possibly too much of the Caterham owner in me?
    Qavion likes this.
  19. 26street
    Jan 30, 2021
    473
    Mark k
    If you can get a detailed report on what the problem was and post it please I would like to know
    goodcoffeecode likes this.
  20. Qavion
    14,601
    Ian Riddell
  21. Shorn355
    Shorn355 F1 Veteran
    6,885
    Colorado
    Scott
  22. Shorn355
    Shorn355 F1 Veteran
    6,885
    Colorado
    Scott
    Hmmm - mine was not split and mounting was fine - just wound not tighten - no biggie as you said - Cheap fix :)
  23. johnk...
    Jun 11, 2004
    11,291
    CT
    John Kreskovsky
    Qavion likes this.
  24. goodcoffeecode
    Dec 18, 2021
    82
    Devon, UK
    Chris Arnold
    Bit disappointing today... Got the car adapted to accept a standard OBDII diagnostic tool (Fiat 3 Pin converter plus power from 12V plug), but the bluetooth tool I bought isn't pairing to anything :(. Anyone had any experience using a vGate iCar Pro please? Red light (power) is on, and blue light (bluetooth) is flashing, Ta.
  25. Qavion
    14,601
    Ian Riddell
    Immobiliser off?
    taz355 likes this.
