Buy
F40 Cam Belts
Discussion in 'Technical Q&A' started by Chiaro_Slag, Mar 1, 2004.
  1. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,731
    CA
    Jerry
    Anyone have some diagrams or info on changing the cam belts on an F40?
  3. rexrcr
    rexrcr Formula 3
    Nov 27, 2002
    1,572
    Kalamazoo, MI
    Rob Schermerhorn
    You want a 328 4V WSM for much F40 engine info, then there are some unpublished specifications, but not for belts.
    Gearbox build info is in the GTO WSM.
    The F40 WSM lacks quite a bit of information, one just has to dig for it.
    Rob
  4. Chiaro_Slag
    Oct 31, 2003
    7,731
    CA
    Jerry
    Thanks - I have the 328 Workshop manual and technical specifications and I am passing them on to the F40 owner. Just curious if there is anything else out there.
  5. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Cambelt change is very easy on F40, takes a day to complete, remove both seats and the central shield between the engine and the interior (it is secured by 10 screw fixings) and there's the engine, same method as 328 belt change.
    MW
