F40 LM Restoration | Page 100 | FerrariChat
F40 LM Restoration
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Traveller, Jan 29, 2013.
  1. kverges
    kverges F1 Rookie
    Nov 18, 2003
    3,179
    Dallas
    Keith Verges
    16 x 400 cc/min should comfortably support 750 hp. I do look forward to seeing a dyno sheet if you are good enough to post it.
  2. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Most people realise that dyno numbers are only useful for before and afters, and even then sometimes that can be problematic if not the same day (weather, etc.).
    So dyno numbers should IMO be considered approximate. Dyno's are still wonderful tuning tools but that is what they are best at, ie. starting with x and tuning until you get cx
    Pete
  3. Traveller
    Traveller F1 Veteran
    Apr 10, 2009
    6,323
    Tim
    Fair comment and so it will prove here when we return with greater fuel flow, more revs and more boost.
  4. PureEuroM3
    PureEuroM3 F1 Veteran
    9,332
    Toronto, Ontario, Canada
    Thomas
    This thread makes me very happy, Keep up the amazing work.
  5. ApeGen
    ApeGen Formula 3
    Jun 3, 2004
    1,360
    Hong Kong
    Kevin
    If you can get Chris Harris to shoot a clip in it, that would be fantastic.
  6. ProvaF1
    ProvaF1 Karting
    Nov 23, 2006
    155
    Australia
    This.
  7. Traveller
    Apr 10, 2009
    6,323
    Tim
    There are plans and dreams.....................
  8. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2483 Traveller, Jun 19, 2014
    Forgive me all those who understand this process, but by way of explanation, this is a four piece mould with generous flanges which add strength and help combat warping, also some will be used to mount the vacuum piping. The green surface finish is " Tooling" Gelcoat and is used in conjunction with " Tooling" resin and whilst more expensive it has a low shrinkage rate which will help us remove the painted front hopefully without damage and it is tough and able to withstand high baking temperatures.
    James is applying a Silicon sealer between the mating surfaces of the jig so as to seal against air leaks when we pull the vacuum. Mr Brown is bolting everything together using 8 mm nuts and bolts, the dimples were moulded in to the flanges to aid register / alignment.
    Next up the first lay up.
  9. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2484 Traveller, Jun 19, 2014
    James, having waxed the mould and applied spray release agent is now spray gluing/laying down the first layer of material which in this case is a 200 gram woven fibre glass. This will be our exterior painting surface and will give us some tolerance should we need to lightly sand out any imperfections and when impregnated along with the carbon, be completely invisible; next layer will be 200 gram Carbon Fibre.
  10. rossocorsa13
    rossocorsa13 F1 Rookie
    Jun 10, 2006
    2,557
    Nashville, Tennessee
    M
    Don't think Tim would have to ask Chris to do that.
    If Chris gets a look at this thread, I bet he'll tweet Tim before the build is over. Chris loves the F40.
  11. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2486 Traveller, Jun 20, 2014
    Next phase uses this interesting honeycombe material which is used as the filling in a carbon sandwhich. The honeycombe media is closed cell and doesn’t absorb resin, remaining light weight; it’s interesting property is that each hexagonal cell is held together by small tags which leaves a tiny vertical alleyway between each cell which is then saturated with resin thus bonding the upper and lower Carbon Fibre laminates together providing an incredibly light and stiff piece.
  12. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    I am a novice mould maker and these photos give me a fantastic insight into how the professionals tackle such complex end products, thanks so much for sharing them Tim.
  13. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    I love watching/reading about this process. Really wonderful.
  14. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2489 Traveller, Jun 20, 2014
  15. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Does that carbon fiber need to go in a vacuum bag and/or an autoclave to cure?
    Alan
  16. Traveller
    Apr 10, 2009
    6,323
    Tim
    Yup. It will all be vacuum bagged and put in the oven.
  17. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2492 Traveller, Jun 20, 2014
  18. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Mark 5 for 30 minutes I assume. :)
    Alan
  19. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2494 Traveller, Jun 20, 2014
  20. I<3strippers
    I<3strippers Karting
    Apr 22, 2012
    102
    VIR
    Loving this!
    Carolina dyno is correct about shops artificially inflating the dyno number. Hell, I've heard of tuners taking a hair dryer to the back of the dyno stack to raise the temp so correction factor goes up resulting in a "higher" dyno reading.
    Like Ben said, WOT tuning is the easiest.
    Do you know if the tuner is pulling any plugs to look at the timing strap?
  21. Citystar
    Citystar Rookie
    Aug 28, 2005
    44
    Long Beach
    Cory Delgado
    Tim,
    Forgive me if I'm misunderstanding this, but it seems that MT is going to use a non-prepreg carbon fiber for a wet lay construction similar to how your splitter was made. I was always lead to believe that PrePreg was a superior carbon than a wet lay carbon piece. Having read through the entire thread and being familiar with the build quality from everything coming out of MT, what are the advantages of using the wet lay process for this project versus using prepreg?
    Thank you very much
    Cory
  22. Carolina Dyno
    Carolina Dyno Rookie
    Apr 25, 2013
    40
    Just a guess but I would imagine it's prohibitively expensive to own an autoclave even for someone that does this high end work. Vacuum bagging resin infused carbon will ensure a perfect surface finish even in a standard oven which in this case seem more important than saving a pound or two especially when you consider a dry carbon lay up would cost almost twice as much.
    That said I'm not a body guy at all so I could be way off base.
  23. Traveller
    Apr 10, 2009
    6,323
    Tim
    I think you are correct. This is a non structural part and if maybe it is not quite as strong or a lb or so heavier, we can live with it. Believe me it is expensive enough as it is.
  24. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    #2499 PAUL500, Jun 21, 2014
    Tim, could you please ask them which spray glue they use/recommend to lay the initial thin fibreglass layer over the green/blue sprayed on release film. that process seems far better than trying to lay on a wetted with resin first layer. Thats the part I struggle with on complex shapes, an initial skin already in place would make it much easier but I dont want any glue to penetrate or dissolve the release layer.
    Oh and the technical name of the white foam material please.
    Appreciate your help :) I assume its that 3m product in the spray can.
  25. mechaniker
    mechaniker Formula Junior
    May 30, 2004
    608
    Germany
    Paul,
    as spray You can use Airtech Airtac 2 (good stuff, expensive), Aerofix 2 (not as good) or (I think) Scotch Weld 770 (but can´t confirm, maybe another number).
    The Core Material is 3D Core. 3D|Core GmbH & Co. KG
    Good Stuff. Build some seriously light Longboards with that stuff.
