F40 LM Restoration | Page 107 | FerrariChat
F40 LM Restoration
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Traveller, Jan 29, 2013.
  1. Traveller
    Traveller F1 Veteran
    Apr 10, 2009
    6,323
    Tim
    I've sent you a pm
  2. I<3strippers
    I<3strippers Karting
    Apr 22, 2012
    102
    VIR
    Meant to ask Tim, was there any reason you guys didn't switch from 16 injectors to 8?
  3. Traveller
    Apr 10, 2009
    6,323
    Tim
    We assumed the combustion chambers were designed to work best with twin injectors and we don't want to veer too far from ordinal where possible otherwise where do you stop?
  4. texasmr2
    texasmr2 Two Time F1 World Champ
    22,232
    Houston
    Gregg
    Also with 16 instead of 8 you do not need to max duty cycle, can decrease the work upon the fuel pressure regulator and stay within safe a/f ratios while playing with boost.
  5. kverges
    kverges F1 Rookie
    Nov 18, 2003
    3,179
    Dallas
    Keith Verges
    I suspect the 16 injectors are just due to old technology. The internal discs, pintles and solenoids of the day were so heavy that high flow rate injectors could not open and close fast enough for the very short duty cycle needed for idle and low throttle. I will bet the second set of injectors opens only under boost. Modern injectors have a much greater dynamic range and can support over 1000 hp and still idle well.
    If the MoTeC will operate 16 injectors it is no big deal either way, but I might be tempted to have smaller injectors for part throttle and bigger for boost so you have plenty of headroom to run big boost if you feel like it.
  6. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2656 Traveller, Jul 14, 2014
    Thanks for all the comments on the injectors and that is still a little further down the road.
    Meanwhile some more progress on the carbon arches.
  7. Mr. Francesco
    Mr. Francesco F1 Rookie
    Oct 10, 2010
    4,934
    Mr. Francesco
  8. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2658 Traveller, Jul 14, 2014
  9. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2659 Traveller, Jul 15, 2014
    Resin infused and cooking. This time, so as to ensure a perfectly flat surface, we have used glass as a base. Apologies if this is getting somewhat repetitive!
  10. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    NEVER!
  11. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2661 Traveller, Jul 15, 2014
    For those in the UK, although I cannot be there, more importantly the car has been invited to Brooklands this Saturday, albeit not in her finished state, and provided it does not rain will probably be there. Just in case anyone is bored of pics and wants to see in the flesh.
  12. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2662 Traveller, Jul 16, 2014
  13. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2663 Traveller, Jul 16, 2014
  14. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2664 Traveller, Jul 16, 2014
  15. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Never gets tedious looking at their shop.
    Alan
  16. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,766
    ESP
    Bas
    Is that YearOne's F50? Can't be many of them in the UK...
  17. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2667 Traveller, Jul 17, 2014
  18. patata
    patata Karting
    Mar 29, 2007
    53
    How glue the differents parts??? Glue or other product??? How they separated this parts to make molds or make molds without separate the parts???
  19. gt4me
    gt4me F1 Veteran
    Sep 10, 2005
    5,671
    Lewis Mitchell
    Wish I wasn't so far away.
  20. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2670 Traveller, Jul 18, 2014
    Looks like thunderstorms all day so will be a no show.
    Just putting a bit of satin black on the air filter boxes rather than the gloss it was.
  21. Traveller
    Apr 10, 2009
    6,323
    Tim
    We took moulds of the inside panels using the same principles that we used to make the front clam, the secondary panels are trimmed and bonded into place using an Epoxy glue which is costly but effective.
  22. I<3strippers
    Apr 22, 2012
    102
    VIR
    I'm super jealous of James, would love to be able to work on the stuff he does!
    That's a safe assumption, on our race car we run 4 2000's and 4 1300's, although it's only a 4 cyl.
    I know you're aware about the dangers of pushing injectors to max duty cycle,but we(my shop) don't like taking injectors passed 85% just to be safe. Having anything at 100% is just asking for trouble.
    The progress here lately has been heavenly! That carbon work is second to none!
  23. Redubbed
    Redubbed Rookie
    Feb 7, 2014
    1
    The gentlemen (artists?) that have been working on this car have such an amazing skill set.
  24. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2674 Traveller, Jul 22, 2014
  25. Traveller
    Apr 10, 2009
    6,323
    Tim
    #2675 Traveller, Jul 22, 2014
