F40 LM Restoration | Page 12 | FerrariChat
F40 LM Restoration
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Traveller, Jan 29, 2013.
  1. mechaniker
    mechaniker Formula Junior
    May 30, 2004
    608
    Germany
    will you put foam inside?
  2. Traveller
    Traveller F1 Veteran
    Apr 10, 2009
    6,323
    Tim
    Yup. Hence the large 'hatches'.
  3. Hogatoshagooarnie
    Oct 16, 2009
    23
    Uk
    I see you have matched the Kevlar weave to that of the inner bumpers, great detail indeed. personally, I would not object if you chose to bolt them to the outter roof. Great thread also!
  4. Traveller
    Apr 10, 2009
    6,323
    Tim
    Thanks, that was the idea, the matching, not bolted to the roof......
  5. GV27TIFOSI
    GV27TIFOSI Karting
    Jan 12, 2008
    154
    Peoria, Arizona USA
    DT
    Traveller congratulations on your construction of the ultimate Ferrari to me!
    The race spec F40's have always had me drooling over their basically being the road car improved in every department.
    What wheels and tires will be in your final specification?
    GV27TIFOSI
  6. Traveller
    Apr 10, 2009
    6,323
    Tim
    #281 Traveller, Mar 19, 2013
    OZ/Enke LM rims from Michelotto with most likely 295 or 315 front and 335 rear Goodrich G Force Rivals. Second choice would be the Toyo Proxes R888. Need to do a bit more research on the fronts as having conflicting information on what tyre will suit an 11.25" rim. Any thoughts?
  7. Traveller
    Apr 10, 2009
    6,323
    Tim
    #282 Traveller, Mar 21, 2013
    The Flywheel and clutch.
    The clutch is no issue and we will replace with an AP race unit. The Flywheel is. Very different from a stock flywheel and yet still road driveable and they have taken literally kilos out of it. Unfortunately the teeth that engage with the starter motor are finished and cannot be remachined and there are other issues so we will need to replace and right now it looks like we might have to make our own and then rebalance with the crank.
    Anyone have any ideas out there?
    Chassis now back from being stripped and perpetration is starting and details in the next post.
  8. walnutcreek
    walnutcreek Rookie
    Mar 22, 2010
    2
    What a gorgeous restoration. Do you know the specs on the current KKK turbos? I assume these are T3 turbos, but don't know the A/R of the units. Garrett and Precision are two of the top manufacturers of newer turbos, and there have been major improvements in technology since those KKK's were built. Ceramic bearings, billet wheels, mutiple scrolls, wastegate designs....
    Turbos are an amateur hobby of mine, though mostly on German cars. Considering the displacement of the V-8, I'd hazard a guess that a pair of Garrett GT28's or GTX30's would provide all the power you might need- early spool of the turbos with great power at even moderate boost levels. I'd steer clear of the GT35's, as boost tends to hit very very suddenly, and can be a handful on the track (though UGR uses GT35's on their twin turbo Gallardos to deliver 1,500+ HP reliably on daily driven street cars).
    If you decide to reconfigure the manifolds for a single turbo, you could build a twin scroll manifold and run a larger frame T4 turbo. Twin scrolls give you early spooling, and the larger turbo gives a more linear power delivery with LOTS of power if you turn up the boost. That manifold would take some creativity and careful packaging/routing of pipes.
    Long time lurker here, but the details and quality of this have brought me out of my cave. Sorry for the long winded comments. Once I get going on turbos, I can't seem to stop.
  9. mechaniker
    May 30, 2004
    608
    Germany
    Why no std flywheel?
  10. texasmr2
    texasmr2 Two Time F1 World Champ
    22,232
    Houston
    Gregg
    Reciprocating mass and weight I believe.
  11. Traveller
    Apr 10, 2009
    6,323
    Tim
    Yup, that is about it. For racing you do not need to encumber the engine with the same mass of a heavy flywheel as a road car primarily due to different clutch useage and consequently you can substantially reduce the weight which enables the engine to rev quicker as it has less mass at the end of the crank to rotate. Go too light and it becomes undriveable on the road. Or that is how I see it.
  12. texasmr2
    22,232
    Houston
    Gregg
    There was substantial weight removed compared to the stock flywheel it seems but I have seen some flywheels that have alot more material removed making them so lightweight they would be virtually unstreetable and require high rpm's and alot of slippage. It seems there has been a nice compromise made seeing as how the car is still "street legal".
    I like the 3-puck clutch plate, what material are the contact/engagement pads made of? On my old Lexus SC300, that had a 2JZGTE engine swap and T78 turbo, it had an RPS 3-puck (not sure of the flywheel) but it was very streetable after a short learning curve. Its nice to have the best of both worlds.
  13. Traveller
    Apr 10, 2009
    6,323
    Tim
    Probably an AP two puck but could change. What is the real advantage/disadvantage?
  14. texasmr2
    22,232
    Houston
    Gregg
    Tim I think the advantages of a 3-puck over 2-puck would be driveability and will have a less aggresive engagement making it better for road use but still duarable for track use. The pad compound is also something you should consider and lets not forget that your clutch disc is unsprung which gives you more direct engagement but also leads to more stalls until one gets a feel for the clutch but after that "learning period" you will love it! The 2-puck also carry's less weight but imho the difference is a non-issue.
    I was weeks away from spending $4K on a TILTON Carbon/Carbon 4-disc clutch for my MR2T simply because you can slip the hell out of it and then replace the carbon disc but lost my job one week prior to making that commitment.
    The preverbial can of worms has been opened, right? lol
  15. Traveller
    Apr 10, 2009
    6,323
    Tim
    #290 Traveller, Mar 21, 2013
    Oh yes. And quite a big one at that.
  16. walnutcreek
    walnutcreek Rookie
    Mar 22, 2010
    2
    Some of the US (and Euro) turbo builders will swear that flywheel mass maintains inertia during upshifts, so that boost doesn't drop off so quickly. Especially with a large single turbo. It might be worth asking your shop whether or not this theory is sound, before you decide the weight of the flywheel. Pros and cons, as usual- less turbo lag with a heavier flywheel, but slower downshifts as rev matching takes longer.
  17. texasmr2
    22,232
    Houston
    Gregg
    As long as the shop knows you specific wants/needs and desires I'm sure they will get you setup. Being VERY clear and specific about those three things is key. In my mind regarding the clutch I would not be worried about originality but longevity. I spoke with a tech at Tilton and told him I would forward you his contact info.
    Jason Wahl
    tel: 805.688.2353 x192
    fax:805.688.2745
    [email protected]
  18. Traveller
    Apr 10, 2009
    6,323
    Tim
    On it, thanks Gregg. Clutch originality is of no concern I assure you!
  19. texasmr2
    22,232
    Houston
    Gregg
    #294 texasmr2, Mar 21, 2013
    Jason went thru his records and found that they had built a clutch (and possibly a flywheel) for an F40 back in about 2001 but could not pull up any renditions or info. AP may be the way to go but only if they have both parts on the shelf ie not requiring a full custom job but that may be something you cannot get around.
    Jason at Tilton informed me that the tooling etc etc for the flywheel would be around $2K, CNC'ing etc etc, so on that note it would be a full custom job YET then they could adapt an existing clutch, lighter and more durable, too the flywheel and adjust all aspects, mainly balance and engagement. He did mention though that the flywheel had crank sensors and I am not sure if the stock/upgraded F40 system was setup like that? The Motec ECU you are planning to use certainly has the option of utilizing those sensors which imho are more telling and true.
  20. SimonSays
    SimonSays Karting
    Sep 14, 2005
    192
    SoCal
    Simon
    I've been told it's not uncommon to resurface the clutch plates with new friction material, like carbon. Maybe that's an option?
  21. texasmr2
    22,232
    Houston
    Gregg
    #296 texasmr2, Mar 21, 2013
    Personaly I would not consider that approach an option on any car and especially not on an F40, jmho.
  22. Traveller
    Apr 10, 2009
    6,323
    Tim
    #297 Traveller, Mar 22, 2013
    Looks like we have agreed with a specialist flywheel manufacturer to have a duplicate made, exactly the same but to a higher standard which will take a while. This will probably be mated to a three puck clutch. Meanwhile we are also having reverse gear manufactured and for those interested here is the problem, not on the gears but on the flange. Thery look like scratches but under magnification they are actually cracks. Not cheap as upon inspection by Crosthwaite and Gardiner, it is apparently very complex to manufacture and they should know.
  23. sherpa23
    sherpa23 F1 World Champ
    10,008
    Rocky Mountains
    Bastuna
    Wait. Am I reading this right? You called Tilton specifically to ask about what they could provide for Tim's car?
  24. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,846
    Atlanta
    John!
    I believe an engineer in Australia makes these......I cannot think of his name but I know he's made several sets of Boxer, F40, 308/328 and the like gear sets. Bill at GT car parts in AZ has the lead on them.
  25. texasmr2
    22,232
    Houston
    Gregg
    #300 texasmr2, Mar 22, 2013
    Yes sir I did :).
    Tim is a good guy and me being an F40 "nut case" I want to help him out in any way I can.
    Karma! ;)
    Orrrrr did I read that wrong and your asking "WTF, why would you be doing such a thing regarding someone else's car"!?!?
