F40 LM Restoration | Page 137 | FerrariChat
F40 LM Restoration
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by Traveller, Jan 29, 2013.
  1. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    #3401 PAUL500, Jul 19, 2015
    The photo on post 907 and my post 909 on page 46.
    That unusual angle on the wishbone joint to the hub is working against the natural arc of the suspension. It just does not look correct. I made a further comment on post 917.
    Worth investigating even if to just discount it.
  2. Traveller
    Traveller F1 Veteran
    Apr 10, 2009
    6,323
    Tim
    #3402 Traveller, Jul 19, 2015
    Thanks Paul, appreciated and we will check, but from what I have seen on other LMs it looks like we are the same and difficult to assemble incorrectly. To my eyes, it looks like the shock absorber does compress in a straight line which is the crucial point so as to avoid weird loads and don't really see ow there could be an assembly error.
    All the damage to the top cup was after it had failed.
  3. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    #3403 PAUL500, Jul 19, 2015
    I guess the other questions are:-
    a) are the mounting points to the engine cradle for LM suspension as per the road car cradle or were they modified from standard by Mich, especially the angle where the top of the shock mounts to the frame.
    b) If they were the same as the road car, do you know yours is still to road car spec or could it have been modified to accept the previous group C style set up prior to your refurb.
    If it were mine I would be showing that photo on post 907 to an independant suspension specialist/designer for their input, that pic makes my teeth itch, it just does not look right.
    Something has introduced a side loading to the shock that should simply not be there. Wider wheels or incorrect offset also has an effect on the compression angle of the suspension, this is showing up with the way in which your tyres scrubbed out unevenly as well, unless that was just down the the angle the shock was sitting post breakage. Suspension is called the black art for good reason, it only takes a slight change in degrees to make a massive effect, all goes over the top of my head when the boffins start explaining it.
  4. Traveller
    Apr 10, 2009
    6,323
    Tim
    #3404 Traveller, Jul 20, 2015
    Thanks Paul, but I think the element you highlighted is correct as here is a Michelotto LM detail, same as ours with the same apparent awkward detail unless I am missing something?
  5. Traveller
    Apr 10, 2009
    6,323
    Tim
    #3405 Traveller, Jul 20, 2015
  6. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    The angle of the bracket fixed on the hub looks to be slightly different on the other LM car which also appears to use a different design of hub for the brake caliper mounting points, hard to tell as the camera angles are not the same. Also the collar on the wishbone in which the spherical bearing sits is not welded quite to 90 degrees, if you were to take that wishbone, and swap it over to the other other side then that slight difference in angle would allow more upwards movement under compression of the suspension at that mounting point.
    I am just a lightly experienced layman musing at something that does not appear correct to me, I could be miles out in my assumption.
    The way I see it as the suspension arcs upwards and the shock is compressed then at a certain point any further movement at that particular suspension point is lost and the hub is then pushing directly against the wishbone, something then has to give, either the wishbone begins to bend which would show up as indents in the wishbone from the hub trying to bury itself, or the mounting point on the hub deflects, as its a cast item that will cause a crack or breakage, or at the other end the shock is taking a sideways load and breaks at its weakest point.
    It will be interesting to see what the actual cause turns out to be, the race LMs were running very hard for many many hours and I guess never experienced this issue?
  7. Traveller
    Apr 10, 2009
    6,323
    Tim
    #3407 Traveller, Jul 20, 2015
    All checks out on the suspension. We tried the shocks without the springs and no binding, everything smooth and in a neat line. However, we noticed on disassembling the front shocks that the 'collets' that seat into the head of the unit were fitted upside down in comparison to the rears. We noticed there was no movement at the top of these front units whereas on the remaining 'good' rear unit there was and the head was free to move around a bit.
    We therefore have reassembled the good rear unit matching the fronts with the collets effectively now reversed from how we found them and there is now no movement at the top of the shock.
    Can anyone think of any reason why the fronts should be assembled different to the rears or do we just have Italy to thank?
    Attached is what I mean by Collets, two in the rear being off the good shock and to the fore, all that is left of the failed one.
    Summary, the suspension moved under harsh load and due to the head of the unit not being tightly held as a consequence of incorrect assembly, one of the collets failed allowing the head freedom to move unrestrained
  8. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Sounds like you have found your problem then :) lateral movement as a result which broke away the top of the plunger of the shock, nice easy fix. Guess it was an assembly error at Koni?
  9. Traveller
    Apr 10, 2009
    6,323
    Tim
    If it is proven, that is a damning inditement of both Koni and Michelotto which could have cost far more than the wasted trip to Anglesey, the costs of the fix etc. We were very lucky but will anyone take responsibility?
  10. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Not a chance, they will just replace the component at best, its the way of the world these days, deny all responsibility.
  11. Traveller
    Apr 10, 2009
    6,323
    Tim
    Amazingly, I found CM at his desk as always at midnight and hopefully some progress.
  12. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    I asked the same question on a motorsport forum frequented by F1 based guys and generally they seem to think the suspension in the photo is on full droop (even though it looks level) hence the unusual mounting angle of the wishbone, and once loaded up it would be far more level, and not the probable cause of the shock failure.
    They also said any lateral loads would be taken up by the top mounted spherical bearing on the shock, so your findings about the collets being the wrong way around seem to be pointing in the correct direction as the cause of the failure.
    Apologies for the red herring, I assumed it was not at full droop as the wishbones look parallel to the ground, I need to remember what they say about assumption!
  13. Traveller
    Apr 10, 2009
    6,323
    Tim
    Thanks for that Paul-reassuring. They are correct in that the suspension is on full droop as the LM wishbones only permit that amount of travel.
  14. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Heck in that photo the drive shaft angle has me wondering, especially as it is going to be worse when on the ground and under (torque, suspension squatting) load.
    Surely the driveshaft should be close to straight?
    Pete
  15. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    I think that pic shows my error far better, if you look at the angle of the stub axle, once the shock is loaded up on the ground the stub axle will run in the same line as the driveshafts and the wishbone mount would also level up.
  16. Traveller
    Apr 10, 2009
    6,323
    Tim
    Well I have to say having tracked CM down at his desk as normal at 12.30 , that is 0030, he has responded as you would expect. No new Konis on the shelf, so we are returning our two rears to be rebuilt and meanwhile in advance he has sent us a set of more modern LM qualified Penske dampers. Due tomorrow, once we see them, we might keep them on the car as easier to adjust and we can get on, and then once the Konis are back, hold them as spares for originality purposes? We'll see.
    He also says that the trend now seems to be that when an LM is returned to his shop, the instruction is to return it to museum condition as that is where they are now headed. Pity.
  17. Traveller
    Apr 10, 2009
    6,323
    Tim
    #3417 Traveller, Jul 24, 2015
  18. Arjun
    Arjun Formula Junior
    Feb 26, 2006
    330
    I have the same Penske suspension - you're going to love it.
  19. Traveller
    Apr 10, 2009
    6,323
    Tim
    They look a lot easier to set up than the historic Konis?
  20. Caeruleus11
    Caeruleus11 F1 World Champ
    11,608
    Ohhh my mouth waters... :)
  21. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    On second thought, that driveshaft must surely not be connected to the gearbox.
    I wish we could see a photo with the car on the ground and suspension in its correct position ...
    Pete
  22. Traveller
    Apr 10, 2009
    6,323
    Tim
    #3422 Traveller, Jul 25, 2015
  23. pshep138
    pshep138 Formula 3
    1,390
    The Midwest
  24. Traveller
    Apr 10, 2009
    6,323
    Tim
    #3425 Traveller, Jul 28, 2015
