F430 Complete Fluid Change Tips | Page 2 | FerrariChat
Discussion in '360/430' started by spvisd, Oct 14, 2012.
  1. darth550
    Jul 14, 2003
    61,222
    In front of you
    BCHC
    Write-up ;)
  2. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,463
    Santa Clarita, CA
    I used hockey pucks for the pads between the jack and the car, they worked great on the front and back. I had to use two different jacks, a low profile one and set the car tires on blocks of wood, then a larger jack to get the tires high enough to put it on my ramps. I used the blocks of wood under the gap in the ramps in case the ramps collapsed.
  3. wrs
    wrs F1 World Champ
    13,986
    Lakeway, Texas
    William
    home schooled were you?
    darth550 likes this.
  4. albkid
    albkid Formula Junior
    Jul 1, 2016
    318
    Jim
    I have used blocks of wood as well.
  5. colorfull
    colorfull Formula 3
    2,404
    Franklin Park, New Jersey
    John Napoli
    Thank you so much @spvisd for the detailed write-up, this is hugely helpful! An FYI on the ATE Super Blue, it seems it is no longer readily available, I reached out to ATE, this was their response (I presume they may have run into an issue with the dye they were using?):
    That is correct what you say, the ATE brake fluid ATE Super Blue Racing is no longer offered
    for sale in the ATE Aftermarket.
    The replacement for these brake fluid is the ATE Typ 200.
    The difference between the 2 fluids is only the blue color from the ATE Super blue racing.
    Otherwise they are identical.
  6. sunkat
    sunkat Rookie
    Dec 3, 2023
    18
    Charlottesville, VA
    Necroing this thread just to note that it's much easier to get to the gearbox drain bolt if you unlatch the support that holds the F1 lines in place. (Nothing that I have a manual conversion with ediff. Not sure if F1 has more lines here.)
    Here's the piece I'm talking about. There are two bolts to loosen. The only thing this piece does is secure the hydraulic lines. You can loosen it without worrying about anything falling.
    Once loose, you can swivel the holder down. This creates plenty of room to get to the drain plug with any normal 12mm hex head on a ratchet extension. No need for a special tool. This little hack turned it into a quick and easy chore (except of course when I pulled the plug I discovered it had been previously stripped. Don't overtighten!)
    colorfull likes this.
  7. Pete Schweaty
    Pete Schweaty Formula Junior
    May 21, 2014
    326
    I had the same exact thing happen to me. Whoever the hell came up with 75Nm for the torque spec must have been on meth! Gnarled one on the right.
  8. colorfull
    colorfull Formula 3
    2,404
    John Napoli
    What a great recommendation here. After removing the bolts and swinging this bracket back, SO much easier to deal with the gear oil plug.
    Also, where I was unable to previously, I was able to drive the socket hex in solid which allowed me to get the 75Nm torque spec. Still seems a bit much, but was much more doable with the bracket out of the way.
    The one question I have is why is this bracket so substantial compared to the rest of the car where they use flimsy metal plates...curious....
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,215
    Central NJ
    Dominick
    75nm is way too much
  10. colorfull
    colorfull Formula 3
    2,404
    John Napoli
    I thought so when I couldn't get a proper position on it.
    But with everything in the proper place, it felt right
    That said , it seemed like 60Nm was good enough
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,215
    Central NJ
    Dominick
    for the drain - 48-50 nm should be perfect
    Filler plug even less
