F430 outer tail light loose / broken | Page 2 | FerrariChat
Discussion in '360/430' started by Wisky, Oct 7, 2015.
  1. gsworld2014
    gsworld2014 Formula 3
    Dec 23, 2014
    1,112
    South Florida
    Greg S
    Who is your Indie?
  2. blackbolt22
    blackbolt22 F1 Veteran Silver Subscribed
    Sep 25, 2007
    5,812
    Boca Raton, FL
    Mr. Anderson
    Adrian at Precision Tune in Margate.
    He "fixed" mine somehow. I really don't care how. I didn't want to replace the whole piece unless necessary.
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,012
    Isle of man- uk
    The problem with these appears to be that the light fixture is fitted with 2 bolts at the top and 1 at the bottom. When mine broke the single plastic post at the bottom , the light is then hanging on the 2 top ones which then proceeds to crack the plastic between the 2 top posts. I was lucky in that the lower post broke off near to the end, i hacksawed back to unsplit plastic and then drilled a 5 mm hole down the middle of it, tapped this out to M6. Then fitted a short length of stainless stud bar with some loctite on the threads.
    The crack in the top part was fixed with Araldite . An M6 nut, then a washer was run down the stud bar and the unit refitted. Do up the 2 top fitting and then adjust the nut and washer to come up behind the bracket- when you have this position move the nut and apply nutlock-put nut back in position and fit the outer nut.Job done and as solid as a rock. I have modified the other 3 by cutting back the lower post and fitting stud bars- if the lower post is solid in the 1st place it will not break which then allows the fitting to hang on the top 2 and crack due to being able to flex
  4. singletrack
    singletrack F1 Veteran
    Mar 16, 2011
    5,849
    Pittsburgh, PA
    My scud had this when I picked it up...or developed it on the drive home. I fixed it with a 2 part epoxy. Has held up very well since.
  5. jrodrig688
    jrodrig688 Formula Junior
    Dec 3, 2012
    397
    FL
    Jose Rodriguez
    09 scud. I recently converted rear lights all to led with scuding Swiss option. I found all 4 were cracked. I would have left them alone but the plastic receiving the screw to secure lightbulb also cracked so I replaced all 4. I'm guessing prob brittle plastic either from heat or from factory.
  6. jrodrig688
    Dec 3, 2012
    397
    FL
    Jose Rodriguez
    When ordering from ricambi they sent me the outer left in European version. Same exact light but with an orange center lense. So I have it if anyone needs it I'll sell it cheap.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,012
    Isle of man- uk
    I have posted the fix elsewhere on the forum, but the basics is to drill the plastic post with a 5mm drill appox 12mm deep. Tap this out 6 mm and fit a length of 6mm stainless stud bar, apply loctite or glue to threads.your pic shows all broken off so you need to file a V section to the end of the plastic bit and use Araldite or similar appoxy to bond it back together.With the top part stuck back you will have a short length of 6 mm studding in the lower single post, run a 6 mm nut , then a washer down it. Fit the top 2 in situ and adjust the nut and washer so they come up behind the bracket. When you have this position move the nut away, apply nutlock and put up against the bracket, fit the original ferrari nut the other side of the bracket
    The problem is the light is hanging on the top 2 and if the bottom one breaks it just moves about cracking the plastic between the top 2- if you get to it in time and reinforce the single post using a stud bar it will not fail in the first place-when 1 of mine failed i fixed it, then fitted stud bars to the rest and no problems so far
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,012
    Isle of man- uk
  9. jrodrig688
    Dec 3, 2012
    397
    FL
    Jose Rodriguez
    Very nice
  10. Freddan
    Freddan Formula 3 Rossa Subscribed
    Sep 16, 2012
    2,440
    Vansbro (Sweden)
    Fredrik
    Mine has a lot of inner-cracks in top them... is that common?
    also have outer (eurostyle) with orange in the middle Selling cheap (no cracks)
    PM me if interested.
    // Fredrik
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,012
    Isle of man- uk
    If you have the bottom fixing break then the upper 2 fixings are only allowing the light to hang in position and the cracks will develope due to the vibration of it not being soild- fix the bottom 1 with the stud bar and it should not be a problem
  12. StickBreitling
    StickBreitling Formula Junior
    Oct 12, 2012
    342
    Grrr, one of my lights was loose. Took it out to find the below. Looks like the previous owner has already repaired one of the posts. I superglued it back together then after that set, I coated the break with epoxy resin. Will see how long this holds up.
    If it breaks again I'll look at either replacing with the Scud Ing version which has rubber grommets to absorb any shock or try drowning the light in epoxy.
    Dealer wanted to charge me 500 GBP for a replacement.
  13. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,749
    Just East of Weird
    Bob
    Man, that is the worst I've seen. Looks like a new one is in order.
    I just epoxied both my two outer ones this past week because the lower posts were broke. You could seem them vibrate when the car was running. Based on everyone else's experiences, I don't expect them to last...
    Sent from my iPad using Tapatalk HD
  14. ideloera
    ideloera Formula Junior
    Jun 2, 2015
    525
    Chicago
    Isi
    500 quid, that's steep. Buy the replacement from Scuding Swiss....cheaper and better quality than oem.
  15. Flea7
    Flea7 Formula 3 Owner Rossa Subscribed
    Feb 25, 2010
    1,970
    PNW
    SKIM
    Hasn't happened to me but I would along with using epoxy resin lay down a layer of carbon fiber or fiberglass weave on the fractured area for additional strength and support.
  16. Bob in Texas
    Apr 23, 2012
    2,749
    Just East of Weird
    Bob
    Am I wrong here, the scud-ing LED's are the rear frame for the bulbs, not the outer tail light housing that breaks. You'd still need to buy/repair the taillight.
  17. ideloera
    Jun 2, 2015
    525
    Chicago
    Isi
    You can also buy the tail lights from Scuding
  18. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,012
    Isle of man- uk
  19. Bob in Texas
    Apr 23, 2012
    2,749
    Just East of Weird
    Bob
    Since the Enzo has the same tail light, do they suffer from STS.(shaky taillight syndrome?)
  20. Wisky
    Wisky Formula Junior
    Nov 13, 2006
    273
    Ridgewood NJ
    David
    The Enzo sample size / miles driven is too small to know, but I would be pretty certain the Enzo tail lights suffer the same failure rate as the F430.
  21. cclassics
    cclassics Rookie
    Jun 21, 2016
    38
    Langley
    mine got broken from someone working on the car- leaned on it and snapped the tab like original post- i know it was from that as 2 days earlier i washed the car and it didnt wobble around.
    i used the 2 part panel adhesive for bodywork- just did this a couple months ago so time will tell - but that epoxy should be stronger than the original plastic -
  22. ty423
    ty423 Karting
    Jun 9, 2015
    156
    Socal OC
    Tony
    Scuding swiss has redesigned ones with insulators to keep vibrations down. I bought a full set at $199 each.
  23. HIO Silver
    HIO Silver Formula Junior
    Mar 12, 2016
    497
    Northern California
    Alonso C.
    Epoxy the break and the bridge the crack with a separate material to spread the load and alter the "moment" as in physics speak.
  24. whatheheck
    whatheheck F1 Rookie Owner
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks to everyone for sharing all the info and their experience.
    I will summarize what I learned for the busy bodies:
    1) OE tail lights are weak and will break. Its only a matter of time.
    2) To prolong the life of the OE tail lights I suggest adding rubber washers to the tail light bolts. The rubber washers will absorb engine vibration and will put less strain on the plastic tail lights.
    3) If yours are already broken and wish to replace it with one that may last longer - I recommend going with Stef Scuding tail lights. They are better made and costs less than half of what Ferrari charges ($200 each tail light vs. $500 what OE Ferrari charges)
    Link below.
    NOTE: I have no affiliation to Stef and his business. Just sharing knowledge and info.
    https://www.scuding.com/Shop/en/rear-lights-optical-clusters/18-rolu43c-f430-light-cluster-clear.html
    Dan
  25. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,012
    Isle of man- uk
    Just remove the single stud and drill and tap in a bit of stud bar like my posted pics, mine are fine after all this time
