F430 roof will not close | FerrariChat
Discussion in '360/430' started by pilam99, Jul 3, 2025.
  1. pilam99
    pilam99 Rookie
    Jan 29, 2021
    20
    Was driving today with the roof down for 8 hours or so, hot and dusty weather. After stopping I tried to put up the roof. The body panels raise and it sounds like the motor continues to turn but the soft cover never really moves. Motor will run seemingly for ever, no error message. When I then reverse direction to open the roof, the two small body panels behind the headrests get stuck until I trigger that mechanical switch behind the drivers headrest and then it will go to the fully open position. But I still cannot do anything to get the roof up. Ideas?
  2. priericky128
    priericky128 Formula Junior
    699
    St. Louis MO
    Rick
    So the small flaps move but the roof mechanism will not?
    that would make it seem like you have a hydraulic pressure problem (leak) since the small flaps are mechanically driven but all the rest is hydraulically driven.
    flash32 likes this.
  3. pilam99
    pilam99 Rookie
    Jan 29, 2021
    20
    Yes. The body hatch near the trunk top lifts up but the roof cover itself will not lift.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,945
    Central NJ
    Dominick
    Usually heat causes the sensors to not operate correctly..meaning not sensing the next step in the process..so a guess would be the sensor that says flaps open continue to lift roof is not saying that due to heat on sensor or physical expansion that the sensor doesn't accommodate for
    The best is to get a diag tool and see all the various sensors on/off and narrow the problem down
    As mentioned above it can be a pressure or ram issue
    Put car in garage and let it cool ..try again and report back
  5. Qavion
    Qavion F1 World Champ
    14,312
    Ian Riddell
  6. priericky128
    699
    St. Louis MO
    Rick
    Yeah check the fluid level behind the passenger seat when it’s not in use and see the level.
    also be careful not to over run the pump. It gets hot quickly
    EastMemphis and Qavion like this.
  7. pilam99
    pilam99 Rookie
    Jan 29, 2021
    20
    Sun went down, temps cooled off, roof started working properly. Anyone have a schematic of the sensor interlock circuit?
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,945
    Central NJ
    Dominick
    Send me a PM with email ..I will send it over
    But given that you can recreate the issue it's very easy to just put the diagnostic tool on it look at all the switches when it's working (same spot) and then look at all the switches when it's not working and you'll determine which one is bad or needs to be a realigned
