F8 - F8 Battery Dead - after 1 month | Page 2 | FerrariChat
F8 F8 Battery Dead - after 1 month
Discussion in '458 Italia/488/F8' started by dariof17, Jan 16, 2023.
  1. Hopeful
    Hopeful Karting
    May 31, 2019
    156
    Vero Beach, FL
    Tony M.
    If the F8 battery compartment is anything like the 488, then its certainly doable but not trivial. Open the passenger foot rest door, remove the cover under the glove box, undo the battery quick-disconnect, remove the cross bar above the battery, remove the battery protector in front of the battery, swear mightily trying to get the copper-colored lock nuts off the battery hold-down j-hooks, disconnect the negative battery terminal, unsnap the red cover over the positive terminal, remove the 2 screws you can't see at the front of the plastic tray on top of the positive terminal, disconnect the positive terminal. Try not to strain anything trying to lift out 45-50 lb battery out while lying on your side bent over the door sill. New battery going in is a bit worse as you have to get all the cables back in the correct places to get the battery to sit properly.
    There are some youtube videos on removing the 4 battery which are very helpful.
    MalibuGuy and Dicecal like this.
  2. RayJohns
    RayJohns F1 Veteran Silver Subscribed
    May 21, 2006
    7,920
    West Coast
    Ray
    I wouldn't count on it.
    Here's a video I made of swapping out the battery on my 488 GTB a while back. No idea what the F8 is like, but probably similar:
    Ray
    MalibuGuy likes this.
  3. Dicecal
    Dicecal Formula 3 Silver Subscribed
    Nov 15, 2015
    1,859
    Phoenix, AZ
    Rob
    Yeah I just watched your video, there is nothing in the F8’s owners manual about reconnecting the battery..
    Just says never to do it.. so I guess I have to wait to get stranded somewhere and call for help:eek:
  4. RayJohns
    May 21, 2006
    7,920
    West Coast
    Ray
    Haha. That's one way to go all right.
    Ray
  5. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,890
    Hi Ray
    I followed your advice and the Braille in my 58.
    A wonderful match! Also the cheapest way to lose some weight in a super car where each additional pound lost usually costs 1,000 due to the fact that we are already at an optimized weight. Say the AGM weighs 49 pounds and the Braille weighs 18 and some change. Weight saving is 30 pounds! That's 30K in Ferrari Carbon
    When my F8 died in a grocery store parking lot, I had to wait 2 hours for the flat- B bed and watch all my groceries get warm. I decided during that wait to do the Braille in my F8 and just pay the dealer to do it. (If I would let them put in a replacement of their choice all free. But because I wanted To do it custom-- well...Ever seen GoodFellas "Pay me" restaurant scene
    The lithium might do better than a high quality AGM in the 488 and F8 because a Lithium recharges faster and easier while driving than an AGM And we already know that Ferrari has decided to under charge the battery while driving. So the longer you drive the more you drain your AGM below where it ought to live
    This is why after a long drive with an aging FIAMM which is anything between 1 month old and 16 months you run the risk of a non-starting event Such as when you stop for gas or a coffee or to pick up stuff at the shops. To protect all the EVU software and electronics , the system prevents start-up if it decided your battery is too low , even when it might be capable of a singe attempt! Thank you to the Nannie's.
    I've determine that the battery gauge doesn't reflect the health of the battery before start up at all It show 12.6 v but your battery could be lower or higher than that!
    Only once the car has started , as you sit at idle does the gauge reveal the true charge of your battery. WTf
    Just like how the F8 updated tire system won't show you a thing until 5 minutes of driving .
    I don't know what the heck the battery gauge reflects as one drives. But before you shut off the engine as you idle you will see the state of your battery health
    RayJohns likes this.
  6. RayJohns
    May 21, 2006
    7,920
    West Coast
    Ray
    Can't beat the Braille. In the 488 or later - with the new odd-ball charging system - I'd recommend using the Braille lithium charger to top things off every 2-3 months just to be on the safe side. Otherwise, works great. Too bad Ferrari changed the charging system function from the 458 to the 488, because in the 458 the i48CS was absolutely bulletproof.
    Ray
  7. Dicecal
    Nov 15, 2015
    1,859
    Phoenix, AZ
    Rob
    Talked my service advisor and was told they have had better experience with Interstate batteries for replacement (so another option). Also said obviously Ferrari recommends the dealership do the install, but they have had customers do it themselves. See if I can find out the exact battery reconnect procedure for the F8, I’m assuming it maybe similar/same as the 488.
    Gerard Miller and blkdiablo33 like this.
  8. RayJohns
    May 21, 2006
    7,920
    West Coast
    Ray
    Most any group 48 battery should work. Just make sure the positive terminal is on the correct side, etc.
    AGM are slightly better than traditional. Costco sells a nice group 48 AGM battery and it comes with a 3 year warranty. That's what I put in my 458 when I sold it.
    Ray
    Dicecal likes this.
  9. Snapshift
    Snapshift Formula Junior Rossa Subscribed
    May 31, 2020
    924
    Centralia IL
    Lyle D. Pahnke
    Use a memory saver when changing the battery. No relearn or any problems. Plugs into the OBD socket.
  10. Midwestfun
    Midwestfun Rookie
    Sep 18, 2019
    3
    Kansas
    Kevin Campbell
    Thanks for the video. It was a great help to watch it before I set out to replace mine today. I only swore once thanks to the video. Took me two hours. My battery was totally dead, i.e. 0 volts! My key fob started the car but would not lock/unlock the doors, nor would the electric trunk release actuate. I took it for a 20 minute drive/errand and shut it off once and it restarted fine. When I got it home, I got out and tried the fob again and this time it worked normally, and the electric trunk release actuated. Looks like it's back to normal. Maybe just driving it allowed its electronics to re-learn.
  11. Dicecal
    Nov 15, 2015
    1,859
    Phoenix, AZ
    Rob
    was this on an F8 or 488? So it sounds like you RnR’d the battery without doing a procedure for reconnecting the battery, and eventually everything worked normally?
  12. FE458IT
    FE458IT Formula Junior
    Jul 17, 2013
    445
    Toronto
    As if the sticky buttons and paint swirls from the factory weren't bad enough.
    Demand will always outstrip supply so I suppose they can't justify the added costs to improve quality control.
  13. Viperjoe
    Viperjoe F1 Rookie Silver Subscribed
    May 20, 2016
    2,663
    Washington Crossing, PA
    Battery failures in my 488, and most recently my F8. Both failures occurred prior to one year of ownership and required replacement of the battery (with an Interstate AGM).
    Ridiculous!
    MANDALAY and RoadRonin like this.
  14. Dicecal
    Nov 15, 2015
    1,859
    Phoenix, AZ
    Rob
    Another Li ion battery option, not as pricey as the braille. Would also need to buy the CTEK Li charger and Ferrari magnetic pigtail:
  15. Dicecal
    Nov 15, 2015
    1,859
    Phoenix, AZ
    Rob
    It’s official now, dead battery with 2 years 5 months of service. At least it’s stuck at home in my garage…:rolleyes:
  16. CChung
    CChung Formula Junior
    Dec 10, 2003
    288
    Southern California
    6 months already and all is well with my battery, knock on wood. Always on the battery tender. In case I do get a dead battery, can anyone share what’s the procedure to have your car towed to the dealer as far as releasing the parking brake, etc to get it on the tow truck? Thanks!
  17. RCorsa
    RCorsa Formula 3 Owner Rossa Subscribed
    Apr 5, 2014
    2,102
    West Coast
    I picked up my f8 at Christmas and it sits on my charger at all times. Interesting but when I drive the car and then park and place it on the tender the battery shows the yellow “charging light” for about 3 hours before it’s topped off “green”. I would think that driving the car the alternator would charge it? Maybe there is some other issue here and maybe it’s not just crap batteries installed by Ferrari?
  18. TR007
    TR007 Karting
    Jun 5, 2018
    101
    The Woodlands, Texas
    Trevor Roberts
    For info - my F8 Spider does the same thing following a drive when I put it on the charger.
  19. Dicecal
    Nov 15, 2015
    1,859
    Phoenix, AZ
    Rob
    Same here, that is “normal” for the Ferrari electrical system. :)
    Personally the antigravity Li ion battery seems like the way to go, especially if you’re gonna keep the car long term. I’m gonna let the dealership give me a new Interstate battery under warranty for now.
    TR007 likes this.
  20. rob5819
    rob5819 Formula Junior
    Dec 12, 2017
    940
    San Diego
    Rob Barry
    The battery tenders Ferrari uses are typically made by CTEK. The CTEK tenders run seven steps every time the tender is connected. My actual CTEK tenders have different lights for the tests, my Ferrari tenders have only one light and do not show the different steps that are being taken, but the tender does not immediately start charging the battery so it is expected that it will take a while to full charge, no matter what state the battery is in:
    STEP 1 DESULPHATION
    Detects sulphated batteries. Pulsing current and voltage, removes sulphate from the lead plates of the battery restoring the battery capacity.
    STEP 2 SOFT START
    Tests if the battery can accept charge. This step prevents that charging proceeds with a defect battery.
    STEP 3 BULK
    Charging with maximum current until approximately 80% battery capacity.
    STEP 4 ABSORPTION
    Charging with declining current to maximize up to 100% battery capacity.
    STEP 5 ANALYSE
    Tests if the battery can hold charge. Batteries that can not hold charge may need to be replaced.
    STEP 6 RECOND
    Choose the Recond program to add the Recond step to the charging process. During the Recond step voltage increases to create controlled gassing in the battery. Gasing mixes the battery acid and gives back energy to the battery.
    STEP 7 FLOAT
    Maintaining the battery voltage at maximum level by providing a constant voltage charge.
    STEP 8 PULSE
    Maintaining the battery at 95–100% capacity. The charger monitors the battery voltage and gives a pulse when necessary to keep the battery fully charged
    blkdiablo33 and TR007 like this.
  21. pninja005
    pninja005 Formula Junior
    Nov 10, 2010
    605
    Europe
    Well, I just joined the club of having a F8 battery failure :(
    Pff... car is almost 2 years old. Sits on charger all the time.
    RoadRonin likes this.
  22. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,955
    Isle of man- uk
    Buy a Yuasa, they do a lot of bike batteries and i fitted one in my 430 about 5 years ago and still going strong.
    SD455TA likes this.
  23. Eric C
    Eric C F1 World Champ Silver Subscribed
    Mar 20, 2009
    11,053
    St. Louis, MO
    Eric
    Its a battery. Suck it up ladyboys.
  24. SD455TA
    SD455TA Formula Junior
    Sep 11, 2021
    584
    Western Suburbs of Chicago
    I have said this, nobody seems to care much.....When your car was shipped what it take...how many MONTHS to get here......MANY...you think it was on a tender there...ha ha ha ha ha....SO,....these batteries take a hit right out of the shoot and stand little/no chance of long term performance and most likely poor performance, that is how it is. So when you put your FRESH battery in there and maintain it properly, it will last a whole bunch longer than you might have thought.
    pninja005, RoadRonin and blkdiablo33 like this.
  25. 05F430F1
    05F430F1 F1 Rookie BANNED
    Oct 22, 2005
    3,600
    Fort Lauderdale, Florida
    Todd
    All cars go through the same months of shipping and storage without battery tenders. And while Ferrari seems to have more parasitic draw than other cars for some reason, they still hold fine in my experience… of my 12 years of Ferrari experience, they seem to die about once every 3 years and that’s without using battery tender/charge thingys…. My Mercedes is on 4 years and 1 month plus it’s original build, shipping, storage, dealer stock time and it seems to be perfectly fine and strong still…. I’ll admit the Ferrari would impress me if it did the same.
