Faded diffuser | FerrariChat
Faded diffuser
Discussion in '360/430' started by I.T. Guy, Feb 22, 2017.
  1. I.T. Guy
    I.T. Guy F1 World Champ
    12,724
    Canada
    Jason
    F430 What would fade the diffuser? Sun? Salt?
  2. mkzhang
    mkzhang Formula Junior
    Oct 5, 2009
    535
    Philadelphia
    Heat
  3. JWeiss
    JWeiss F1 Veteran
    Nov 18, 2010
    7,561
    NYC and Long Island, NY
    JWeiss
    Ideally, your diffuser doesn't spend too much time significantly exposed to the sun.
  4. Turbotuner20v
    Turbotuner20v Formula Junior
    Mar 18, 2014
    362
  5. I.T. Guy
    12,724
    Canada
    Jason
    Lol re: sun.
    I'm looking at a car and diffuser is discolored. Car has heated seats, hence my salt question if it could do that or if it's normally something else.
  6. I.T. Guy
    12,724
    Canada
    Jason
    From the engine/exhaust?
  7. mkzhang
    Oct 5, 2009
    535
    Philadelphia
    Yes and no? Heat will make things fade, and the cats and muffler are close. But I'm not sure if the diffuser color fading is common, and if the heat is so intense there are a lot of components closer to the exhaust that will definitely have it worse, such as the air box, axle, and F1 actuator etc
  8. 3POINT8
    3POINT8 F1 Rookie
    4,436
    what's the diffuser even do?
  9. Perkins
    Perkins Formula Junior
    Dec 22, 2013
    702
    Sacramento
    Rick
    Faded? Do you have a picture? The rear diffuser is just painted fiberglass.
  10. Mass1mo
    Mass1mo Rookie
    Jan 29, 2016
    32
    SF Bay Area
    Massimo
    "A diffuser, in an automotive context, is a shaped section of the car underbody which improves the car's aerodynamic properties by enhancing the transition between the high-velocity airflow underneath the car and the much slower freestream airflow of the ambient atmosphere."
    Quote from wikipedia
  11. HIO Silver
    HIO Silver Formula Junior
    Mar 12, 2016
    497
    Northern California
    Alonso C.
    Fading could be a result of a crappy fiberglass or plastic formulation, exposure to heat which degrades its molecular structure, and exposure to UV from the sun.
  12. I.T. Guy
    12,724
    Canada
    Jason
    I have requested pics - seller was up front with it, just waiting to see photos and figure out if it's a bigger issue, or, a simple refinish / replace diffuser issue.
  13. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,651
    England
    Mark
    TFR/heavy detergent fades them. The black suffers the most but the grey also becomes lacklustre.
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    If it is structually sound, no reason you cannot get it spray painted
  15. 3POINT8
    3POINT8 F1 Rookie
    4,436
    thx for definition
  16. I.T. Guy
    12,724
    Canada
    Jason
    #16 I.T. Guy, Feb 23, 2017
  17. mkzhang
    Oct 5, 2009
    535
    Philadelphia
    The body of the diffuser is very matte compared to the fin which is more glossy, could perhaps be the kind of cleaning materials used?
    Plus I dont think all of them came black, I've seen some are gray, gloss black, glossy gray etc. It's something I've never figured out either
  18. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,651
    England
    Mark
    Wow - I've not seen one that bad. It's heavy detergent. Just repaint it as Mike suggested.
  19. Turbotuner20v
    Mar 18, 2014
    362
    that almost looks primer/unpainted...
  20. I.T. Guy
    12,724
    Canada
    Jason
    Thanks guys
    Cosmetic = ok
    If it was caused by something else, like driving in slush all winter... or heat...
  21. Perkins
    Dec 22, 2013
    702
    Sacramento
    Rick
    Honestly that's what it looks like to me.
  22. djempire
    djempire Formula Junior
    Apr 30, 2012
    613
    Toronto
    Serf
    Is this a Toronto/Canadian province car? I wouldn't be too concerned. PPI should reveal (if any) misuse. You can repaint the diffuser. A good product is Mothers Back to Black.
  23. unreelviper
    unreelviper Karting
    Jan 9, 2014
    174
    DMV
    It's weird, mine was faded just like Jason's. I needed a fiberglass repair as well(looked like someone had backed into a high curb and damaged the fins at the bottom). I had it repaired and repainted and it came out well. Apparently there are shops that have a computer that can match the paint. I'm back in business. Jason just repaint it.
  24. Perkins
    Dec 22, 2013
    702
    Sacramento
    Rick
    Or get an aftermarket carbon diffuser. They're surprisingly not too expensive.
  25. 338Lapua
    338Lapua Formula Junior
    Sep 5, 2015
    802
    Michigan
    Tony
    I'm with Turbotuner - it looks like the diffuser is primed and unpainted. I honestly don't think it is faded.
