Still miss my little 308, good to see the forum is still active. Can someone with a spare dizzy cap measure the diameter of the carbon pin/conductor? Thank you in advance Geno
Hi Geno, If you just need the measurements, I can do that later today. If you are trying to match the pin to another suitable replacement, I have about 50 varied Bosch distributor caps from an inventory I bought years ago (with some blue and red coils!). I can see if any of them match a 308 pin and send it to you. No charge of course. Jeff
Thanks guys, loving the lambo's but missing the 308, she was a beauty and easy to own comparatively. The V12 distributor cap is $1,600. I broke the carbon element, but the rest of the cap is good. I know i can go to napa and likely find an element, but I thought at one point the carbon element was the same in the 308, just looking to verify. I think its 6mm Image Unavailable, Please Login
thank you, perfect that will work. if anyone has a old spent cap that wants to donate a carbon tip please let me know. Will figure out some sort of compensation.
I've still got a couple old caps sitting around. Had no idea the carbon button was so expensive. I can check tonight when I get home if you'd like. If I do you can have it. Since I also don't have a 308 any longer I have no need for it.
