Fear not the seat pot (potentiometer) How to rebuild one without removing it. | Page 2 | FerrariChat
Discussion in '348/355' started by roadracer311, Jun 21, 2010.
  1. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
    Thanks Ernie!
  2. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Just wanted to say, again, that this is an EXCELLENT Thread!
  3. Monteman
    Monteman Formula 3
    Feb 9, 2006
    2,353
    Santa Barbara, CA
    Monte
    THANKS!!!!
    Awesome write up. Never had the problem but it's just a matter of time before I do.
  4. gus355
    gus355 Formula Junior
    Aug 3, 2011
    569
    B.C. and WA
    #29 gus355, Sep 30, 2011
    I just played with the roof and it seems that you can get the roof to work just fine by simply flipping the seatbacks forward - without moving the tracks all the way forward - anyone else find this?
    Edit: I mean if you are using the emerg. switch
  5. mpodgor
    mpodgor Formula Junior
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    I am surprised that with your low miles this thing failed so soon. Do you think oxidation on the potentiometer is the culprit? Like an old stereo with scratchy pots. I'm thinking maybe some good contact cleaner. I use this stuff called "Deoxit" D5. It removes oxidation. You can google it. It is the best stuff period!
    I know your car has low miles. I'm thinking maybe by long periods of non-use that the oxidation occurred. Just a theory.
  6. roadracer311
    May 6, 2009
    2,398
    San Francisco
    Paul
    Thanks for the recommendation on the Deoxit D5, I'll check it out.
    The potentiometer itself was in perfect shape, electrically. It was just the plastic ball joint that drives the potentiometer which failed. I've had several old cars and at about 14 years old, they all seem to start snapping plastic bits here and there.
  7. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    It eats plastic for breakfast. The joys of city living. Just a theory.
  8. WATSON
    24,092
    WI
    Some add-on's to a waaaay back thread that is still relevant as i fix my seat pots. .
  9. WATSON
    24,092
    WI
    #34 WATSON, Feb 5, 2016
    I did tonight:
  10. WATSON
    24,092
    WI
    #35 WATSON, Feb 5, 2016
  11. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Did you fix it?
  12. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    This thread is so good I saved it twice. I must have read it a long time ago when I was learning about the 355, and thought it was worth bookmarking. Tried to bookmark it again last night!
  13. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    excellent thread :)
    if this thread has not been added to the "348/355 - Master Sticky Thread Index" yet it should be now.
  14. WATSON
    24,092
    WI
    They are dry and look good. But not installed yet. That will be a few weeks out as the seat belts are out for a cleaning and new webbing.
    The pots track the KOHM pretty close so they should be fine.
    I will post my results, but it will be a few weeks.
  15. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    Nice thread. Has anyone though of using Super Glue for this?
  16. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    #41 Enzojr, Feb 6, 2016
    I wish someone would fix mine :(
    So I would have a spare, my wallet still hurts from buying a new one.
    I don't even have the skill set to see what broke on mine.
  17. WATSON
    24,092
    WI
    Ha. I think that's salvageable. PM if you want me to stitch that up.
  18. Enzojr
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    #43 Enzojr, Feb 6, 2016
    Something in this area, I seem to be missing a part ?
    If someone has the parts to repair this .... and the skill set ;)
    I would gladly pay you next Tuesday ;)
  19. Enzojr
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    Sent you a PM ;)
  20. WATSON
    24,092
    WI
    #45 WATSON, Feb 6, 2016
    From a different thread:
  21. lola t70
    lola t70 Rookie
    Sep 21, 2016
    1
    High,
    many thanks for your great post - as it is (sometimes) raining in germany!
    Kind regards
    Rolf
  22. sl55
    sl55 Karting
    Dec 26, 2009
    240
    Scottsdale AZ
    Guys- I am just done performing this fix on my 95's driver seat.
    I would like to add that we set it at 4.4 and it didn't work. We then checked and matched the passenger's seat forward value which was between 5-5.4 and it worked.
    So I would say to anyone trying this procedure with at least one good seat go based off of the others seat value VS 4.4
    Thank you again for this great post
  23. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Great work! Good for you diving into that and fixing it so soon into your ownership.
  24. Rifledriver
    37,367
    The seats are often different from each other. The computer has no need for them to be matched so they often are not particularly if one has been previously repaired. There is a program just to teach it where they are now and operate off of that information.
  25. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    I have not done this....yet. But couldnt you put the seat all the way forward or back and then just mark it when you take it apart. Then put it back exactly how it was oriented?
    I assume that is what Watson was suggesting in his post above.
