Ferrari 348 hot start - does not hold the idle | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Teo's348, Apr 12, 2022.
  1. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,535
    Ian Riddell
  2. Qavion
    Feb 20, 2015
    14,535
    Ian Riddell
  3. wmuno
    wmuno Formula Junior Silver Subscribed
    Dec 24, 2007
    522
    Wilmette, Illinois
    Bill Muno
  4. Qavion
    Feb 20, 2015
    14,535
    Ian Riddell
    It’s hard to say from what was said. One person wasn’t sure and one person had to put bulbs in to make the lights work. No bulbs may be standard on Euro cars: 348 instrument binnacles may have few variations to save money on the production line. They may be like the 355. My 355 has a tyre pressure warning light bezel, but no 355 was ever fitted with that system, so there is no lamp. I can’t recall if the wiring was included inside the binnacle.
    I think we need more comments from Euro owners to be sure.
    wmuno likes this.
  5. Teo's348
    Teo's348 Rookie
    May 4, 2021
    37
    north of Italy
    Teo
    hello guys! in this weekend i did several tests and maybe i solved the problem in the easiest way:
    I turned on the car when it was cold and it didn't go well; I immediately tried to work on the main relays ( fuel pump and injectors), inverting several relays and I found out that the relay of the injection control of cylinders 5-8 didn't go well; I replaced it with a new 30A Fiamm relay, and the car started immediately! to be sure that the problem was him, I did 2 starts with the new one and it went, I put the old one back and it didn't start; I put the new one back and it went even when it was hot or after 20 minutes of stop!
    now everything seems to be ok, i will do a short test drive anyway!
    moysiuan and Qavion like this.
  6. Qavion
    Feb 20, 2015
    14,535
    Ian Riddell
    Interesting. The relay provides power directly to lots of engine sensors and devices on the left bank, but I noticed it also puts power on two LH Motronic (2.7) ECU pins. I wonder if one of these pins then provides power to the crank sensor? This is a third power source for the ECU.
  7. Teo's348
    Teo's348 Rookie
    May 4, 2021
    37
    north of Italy
    Teo
    online I find only 20/30A bosch Relay;
    the original metal one is 30A
    do you think I can put the 20/30 or 30/40 plastic that are now on the market?
  8. Teo's348
    Teo's348 Rookie
    May 4, 2021
    37
    north of Italy
    Teo
    I should try to read well the wiring diagram with an electrician who knows the car (douring the service)
  9. wmuno
    Dec 24, 2007
    522
    Wilmette, Illinois
    Bill Muno
    Now that you car is working well, for the record, when you start the engine are there 2 red Check Engine lights?
    Qavion likes this.
  10. Qavion
    Feb 20, 2015
    14,535
    Ian Riddell
    It should be in the last subsection of Engine Ignition/Fuel Control: “Diagnostics”.
  11. Qavion
    Feb 20, 2015
    14,535
    Ian Riddell
  12. Ferrarium
    Ferrarium F1 Veteran Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Teo's348 likes this.
  13. Teo's348
    Teo's348 Rookie
    May 4, 2021
    37
    north of Italy
    Teo
    exactly that's what I want to do, buy them all new so I don't have to worry about it; I've seen that it's better to put relays with this number: 0 332 019 140
    Of course I can't find them online :confused:
  14. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I have a post called foot panel relays or something where I lay out how I did it. There are other relays with different part number with the exact same spec that work.
    Sent using FerrariChat.com mobile app
  15. Teo's348
    Teo's348 Rookie
    May 4, 2021
    37
    north of Italy
    Teo
  16. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  17. Teo's348
    Teo's348 Rookie
    May 4, 2021
    37
    north of Italy
    Teo
    I was looking for it and couldn't find it, but thanks for the link! this is very useful, so I can redo the whole panel as new!!
  18. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  19. Teo's348
    Teo's348 Rookie
    May 4, 2021
    37
    north of Italy
    Teo
    Reading your post another user reported this:
    ""TE" means Tyco. Bosch had a couple of equivalents to their old 0 332 014 140: 0 332 019 140 and 0 332 209 168 but these are also hard to find. These relays a re a bit special as they are "low pull-in voltage" type, i.e. they have stronger solenoid coils and can engage at as low as 7 volt. I found out that one, possibly fairly new, Bosch equivalent is 0 332 209 136 which is GM p/n 90491314. This GM p/n is also manufactured by other relay manufacturers like: Hella 4RD 007 794-05, Siemens V23134-A52-X237 ant Tyco (TE) V23234-A0002-X031 (or X032) which has even lower (better) pull-in voltage of 6.5 volt . I do not have the specs for the Tyco relays (4) you got for the fuel pumps and injectors but I presume they are similar to the Tyco number I mentioned."
    in your opinion is it better to use the BOSCH 151 or the TYCO X031 which has a pull-in voltage 6.5?
  20. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Don't recall... you can see what I used in the post.
    It's best to post in that thread and it keeps the info in one place and mirojub would likely respond.
  21. Teo's348
    Teo's348 Rookie
    May 4, 2021
    37
    north of Italy
    Teo
    Ok, then I reread both discussions, the best thing with the availability now on the market I think is for all BOSCH 4113 (the 9 equal) there go the corresponding that you reported as BOSCH 151, for the 4 of the pumps and injection (CDNL) that have as original part 4140, should be replaced with the tyco X031 (which have a pull-in less) the rest always as per your post
  22. Teo's348
    Teo's348 Rookie
    May 4, 2021
    37
    north of Italy
    Teo
    Hi guys, yesterday I checked what you asked me about the lights on the instrument panel: when I turn the key before turning on the engine, two lights light up with the words "1-4 low" and "5-8low" as soon as I turn on the engine, all the lights are off.
    Qavion likes this.
  23. Qavion
    Feb 20, 2015
    14,535
    Ian Riddell
    Low or Slow?
    These are the SLOW DOWN lights (related to catalytic converter overheat)
    So no CHECK ENGINE lights …or the bulbs have been removed.
  24. Teo's348
    Teo's348 Rookie
    May 4, 2021
    37
    north of Italy
    Teo
    Slow sorry, no engine no light, I hope it is because there is no problem!
    Qavion likes this.
  25. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    793
    Treasure Coast Florida
    MATT
    Hey guys I am following this thread with much enthusiasm as I'm looking to replace my 4 fuel related relays just on principle. However all I'm finding is used ones on ebay....where are you sourcing these.....specifically the Tyco
    V23234-A0002-X031 or its bosch equivalent?
