Ferrari 550 — Check Engine and Suspension warnings | FerrariChat
Discussion in '456/550/575' started by MonsieurPedro, Jul 28, 2022.
  1. MonsieurPedro
    MonsieurPedro Rookie
    Jul 28, 2022
    3
    Paris, France
    Pierre Bonnafy
    Hi everyone,
    This is my first post here and I’m very happy to join the forum.
    I’m a new 550 M owner in France, this was my dream and my first Ferrari. I’m incredibly happy with it.
    While I was in Paris traffic for 45mns, 2 lights suddenly came : Check Engine and shocks Warning.
    After a battery Disconection and the manual ÉCU reset process, Shocks warning light is out. Sometime coming back but not that often.
    I tried to look if everything looks normal behind the fuse box and I noticed a cable ( Not SD2 câbles … ) was disconnected. ( see photo )
    Could a Ferrari 550 owner here tel me if they have the same or if this cable should be plugged somewhere?
    Many thanks!
  2. Qavion
    Qavion F1 World Champ
    14,150
    Ian Riddell
    There is a white plug in this photo which seems to be unused, but it looks smaller.
    Could you list the wire colours (including stripe colours)? How many sockets/pins does the plug have (including unused ones)?
    You seem to be missing item #43 (rear fog light control station).
    Do you have a rear foglight switch?
    Note that there is an empty slot on the relay panel...
    ... but as far as I know, it's unused on all 550's.
    Hawkeye and Ferrari55whoa like this.
  3. Ferrari55whoa
    Ferrari55whoa F1 Rookie
    3,354
    Los Gatos, CA
    Eric
    Above….”Maranello Master joined the chat”.
    #awesome
    #likeAboss
  4. AVIMAX
    AVIMAX Formula Junior
    Aug 5, 2014
    710
    Toronto
    Ryan
    There is an unused white connector in that area that is used to turn on the lights permanently for countries that require daytime running lights. The part that plugs into it is just the mating connector with wires joined together and heat shrink on top to close the circuit. When plugged in, all outside lights will be on whenever the key is on regardless of the light switch position. It was in my car, probably added when brought in to Canada from the US. I removed it because I did not like having the lights on when starting the car, just seemed like more drain on the battery than necessary.
    marce likes this.
  5. root
    root Formula Junior
    487
    Bay Area, Ca
    My 550 had the suspension light come on at random intermittently. Couldn't replicate. SD2 showed no stored errors. My tech identified a faulty (shorted) "Sport" switch. Didn't see the suspension light again after the switch was replaced.
    308 GTB and Qavion like this.
  6. bay
    bay Formula 3
    Mar 13, 2011
    1,274
    Belgium
    Bernard
  7. Qavion
    14,150
    Ian Riddell
    Thanks for the reminder, Ryan. According to the wiring diagrams, that connector only has 3 wires. Yellow/black, Yellow/Red and Green/Yellow.
    Pierre's photo seems to show more than this (?).
    bay and Ferrari55whoa like this.
  8. marce
    marce Formula Junior
    Jan 30, 2014
    454
    Australia
    Marcel
    Hi Pierre,
    Did your car sit for a long time before you bought it ?
    When a rarely used car starts getting used again things will start flowing again and problems will arise. It happened to me, leaking high pressure power steering hose, had to rebuild shocks, replace braded oil hose(ouch), leaking coolant hose, replace water pump.
    Alot of it from the car sitting too long is my guess.
