355 - Ferrari F355 Challenge Steering rack | Page 10 | FerrariChat
355 Ferrari F355 Challenge Steering rack
Discussion in '348/355' started by SOstergaard, Sep 1, 2021.
  1. deuce49
    deuce49 Karting
    Sep 25, 2011
    141
    Scottsdale
    BC
    Yes it's out of the car, again...
  2. deuce49
    deuce49 Karting
    Sep 25, 2011
    141
    Scottsdale
    BC
    Interesting, I will check them out. Thank you
  3. ShineKen
    ShineKen F1 World Champ
    19,892
    Southern California
    Nostradamus
    @yelcab in Norcal would be the man to rebuild it.
  4. Qavion
    Qavion F1 World Champ
    14,271
    Ian Riddell
    Do you know what the problem was with the Volvo kit?
    Volvo kits were recommended on FChat
    https://www.ferrarichat.com/forum/posts/146256631/
  5. Philipnz
    Philipnz Karting
    Apr 12, 2015
    222
    Whitianga New Zealand
    Philip Hart
    The Volvo kit repaired my Fiorano rack. Is the challenge rack the same?
    Qavion and ShineKen like this.
  6. ShineKen
    19,892
    Southern California
    Nostradamus
    Yes. Exact same.
    Qavion likes this.
  7. ShineKen
    19,892
    Southern California
    Nostradamus
    If you no longer want to deal with the headache, I’ll gladly give you $6k for it as is :).
    deuce49 likes this.
  8. 601
    601 Karting
    Dec 19, 2010
    223
    California
    This is where I will go too when the time comes. Dale and Eric at GP Autoworks are awesome.
  9. deuce49
    deuce49 Karting
    Sep 25, 2011
    141
    Scottsdale
    BC
    Lol, thanks for the offer but definitely not getting rid of it for this restoration ;)
    ShineKen likes this.
  10. Flynt
    Flynt Rookie
    Aug 23, 2013
    45
    I'm rebuilding my standard rack now. I can only answer for myself, but here's the problem I've run into with the Volvo kit.
    Seal 12014254B (Corteco part number) AKA 34002485 (TRW part number). The original I pulled out and destroyed in the process is a double-wiper radial shaft seal. The one supplied in the kit is a single-wiper and very delicate. If I do end up using the seal supplied in the kit, I'll have to make a tool to press it in, because where it seats in the bore is thin and it lacks the broad lip to press on. I'll have to press it in without damaging the wiper spring or whatever that things called.
    I bought a few Corteco 12014254B seals off ebay from a vendor in Lithuania. Correct dimensions in their listing. They showed up in Corteco bags with that part number on them, but they're totally different seals - no shared dimensions, some weird big metal flange built in. Some other places say they have these seals, but shipping is $60 for a $3 part..
    It looks like this seal just keeps grease from migrating up the input shaft, and since this one is for my personal car I was just going to give this single wiper seal a shot..
    ShineKen and Qavion like this.
  11. ShineKen
    19,892
    Southern California
    Nostradamus
    I assume you are restoring a challenge car? If so, maybe a trade is in store? I have a ton of challenge parts.
  12. deuce49
    deuce49 Karting
    Sep 25, 2011
    141
    Scottsdale
    BC
    Yes, I'm doing a complete restoration on my 1997 Challenge. I have most of everything I need, however, there are always a few parts here and there that always rear their head up. I'll shoot you a DM
  13. ShineKen
    19,892
    Southern California
    Nostradamus
  14. ShineKen
    19,892
    Southern California
    Nostradamus
    Can we can a good pic of the rack?
  15. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,724
    Get rid of the power steering pump.
    insert a 348 rack.
    But here, you are going to fight the caster specification (around 7º for F355 and around 5º for 348) which may make the unassisted rack heavy, but because of the top speed advantage of the F355 over 348 you may find a high speed instability with this little caster.
    Alternate plan:
    Get rid of power steering pump (or connect output to input.)
    connect PS inputs to the F355 rack to each other to simply recirculate fluid.
    mclaudio likes this.
  16. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    The problem with the 355 rack isn't the assist, it's the ratio.
    Illyria and ShineKen like this.
  17. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Another option could be fitting one of those reducer boxes into the steering column linkage, and keeping the PAS
  18. mclaudio
    mclaudio Formula 3
    Dec 13, 2003
    1,272
    Seattle area
    Claudio
    My Challenge rack (2.75 ratio) underwent this alternate plan. If one derives a lot of driving enjoyment out of a very communicative steering car, I would highly recommend.
    Another thing I’ve done in a different car is a 997 GT3 Cup race car ps (electric pump-assisted hydraulic) with a custom on/off switch (hydraulic to manual). GT3 Cup ps is one of the best hydraulic ps I’ve experienced. Yet if I want the manual steering feedback, I can switch off the ps.
    Qavion likes this.
  19. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    In my experience you don't get manual feedback on hydraulic rack with the pump disconnected. You get "oh my god I'm pushing around a bunch of hydraulic fluid with my arms" feedback.
  20. GatedF355GTB
    GatedF355GTB Karting
    227
    SF Bay Area
    Joe
    993 owner here. I put a 340mm momo steering wheel in my F355. While not as good as the 993 steering, it's close enough. There's no way I'd convert to a manual rack on a F355.
    IvanRico and OCKlasse like this.
  21. OCKlasse
    OCKlasse Formula Junior
    709
    Newport Beach, CA
    Brandon K
    340mm is the perfect size for the F355, IMO.
    IvanRico likes this.
