Ferrari F430 having this problem CST | FerrariChat
Discussion in 'United Kingdom' started by darkangel7747, Jun 18, 2017.
  1. darkangel7747
    darkangel7747 Rookie
    Jun 20, 2009
    6
    Singapore
    Alex Adam Low
    Hi guys, I am having this problem, can someone advice. Thanks
    [​IMG][​IMG]
  2. daytona355
    daytona355 F1 World Champ
    12,655
    London
    Sid Korshak
    Sorry mate, haven't seen it before, but clearly suspension, either physical issue with the systems, or an ecu/sensor issue. Hopefully bad sensor, normally is. Have you tried the system reset in the owners manual?, that's the first place I'd start, as whenever I've had error codes, a 'spanner check' of related areas, and if that fails, reset, tends to work.
    Before you do the reset , I would check all tyre pressures, make sure brakes and wheels clean and free of any dust and rubbish, and all bolts tight. You know how sensitive these cars can get.
    Could just be a spanner check and reset will clear it, but once the reset done, if it clears, drive it a few miles and let the sensors all register a few reports to the ecu to check its working smoothly again.
  3. darkangel7747
    Jun 20, 2009
    6
    Singapore
    Alex Adam Low
    Hi Simon, thanks for fast reply, at first I think could be the cause of the battery, so I change to a new battery. After I change it, it still the same.
  4. darkangel7747
    Jun 20, 2009
    6
    Singapore
    Alex Adam Low
    Could it be the shock absorber?
  5. darkangel7747
    Jun 20, 2009
    6
    Singapore
    Alex Adam Low
    Thanks for the update mate, will try your way and update you guys again.
  6. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Manetino warning light. Could be many things but the spiral contact behind the steering wheel failing is common.
    Disconnect the battery for half an hour. Reconnect it, drive the. At, if the light comes on when the steering wheel is turned either way it's likely the spiral contact is the cause.
    You really need a proper diagnostic check before carpet-bombing it with parts though..
    daytona355 likes this.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,938
    Isle of man- uk
    Check the negative battery cable connections, i was having ghost alarms traced to poor connections on the negative side.
    Disconnect the battery cables, connect a multimeter to the negative battery clamp and to an earth point under the cover behind the seat. Do the same with the positive cables. Measure the resistance ohms- my negative lead was over twice the resistance of the positive lead. Remake the connections on the high resistance lead. It may be losing voltage due to poor connections.
  8. parkem
    parkem Karting
    Feb 17, 2012
    160
    florida
    peter palermo
    Had the same problem,it was the wheel sensor on front passenger side.you need to have it checked to see which wheel it is
  9. khalidb43
    khalidb43 Rookie
    Dec 5, 2013
    14
    italian horses
    Hello,
    Any conclusion on this issue? Having the same problem.
    Thanks!
  10. johnjstewart
    johnjstewart Karting
    May 6, 2008
    52
    York
    John Stewart
    Any conclusion? I am having exactly the same issue.
  11. craze
    craze Formula 3
    1,162
    Melbourne
    Michael
    Mine had a warning like that when battery was dying
  12. johnjstewart
    May 6, 2008
    52
    York
    John Stewart
    Failed ABS sensor on front offside wheel. The sensor is part of the wheel bearing around £350 for the part plus tax and a couple of hours labour. Not too terrible.
    Danny T. likes this.
