FF transmission problems? I am hearing this is an issue... | Page 2 | FerrariChat
Discussion in 'FF/Lusso' started by trygve11, Oct 1, 2017.
  1. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    Interesting post, 4th. Does this imply that the T places more stress on the transmission, on average, than the NA Calis?
    T
  2. otakki
    otakki Formula 3
    Mar 24, 2016
    1,635
    I would say yes because force induction engine almost always puts out more torque than a similarly displaced NA unit.
    of2worlds likes this.
  3. vjd3
    vjd3 F1 Rookie
    2,836
    Massachusetts
    Vic
    I was told by a Ferrari tech who is certified to work on the DCT that earlier versions of the transmission (at least on the California) had a problem with some internal plastic clips (similar to zip-ties) used to route the wiring that were not up to the heat conditions inside the gearbox, they would become brittle and could abrade the wiring, causing shorts to the speed sensor. Those clips were updated at some point, so later transmissions seem to be more reliable, but others may know more than I do. He indicated that I should not be concerned with my 2013. Steve down in Dallas posted a photo of the internals that shows the clips. Whether this issue is unique to Ferrari's application as opposed to Mercedes et. al. ... no idea, or if there is better cooling in the other applications aside from the California.
    Bundy, ernie, Brian L and 1 other person like this.
  4. shewu
    shewu Rookie
    Oct 20, 2014
    8
    Can the plastic clips in the older transmissions be upgraded to use the updated clips? Seems prudent to do as a preventative maintenance item; whether someone will do it is another question.
  5. vjd3
    vjd3 F1 Rookie
    2,836
    Massachusetts
    Vic
    I would guess if they are addressing the speed sensor problem they are already doing that. But the huge cost of replacing the inexpensive speed sensor is the labor disassembling the transmission to access it, so it does not really make sense as preventative maintenance.
  6. MDEL
    MDEL F1 Rookie
    4,132
    Southern Europe
    Mario
    I had an early NA California that had transmission problems at 20.000 Km. The diagnose was a faulty speed sensor and the repair was done under the existing extended warranty. In case it might be of interest to anyone I publish some pictures I took during the repair process.
    Picture 1) Shows the DCT still in place after all the bottom panels and the exhaust were removed. I presume the parking brake cables were also removed.
    Picture 2) Shows the bottom of the car after the DCT was removed.
    Picture 3) To remove the DCT the back axle had to come out on top of a trolley and before that could be done the rear brakes disks and all the oil tubs had to be removed.
    Picture 4) The DCT after being removed and ready to be opened and repaired .
    Bundy and ernie like this.
  7. otakki
    otakki Formula 3
    Mar 24, 2016
    1,635
    Thanks for putting up those pictures. It's hard to imagine something as simple as zip-ties is the main culprits to the problem.
    vinuneuro and spyderman like this.
  8. pelank
    pelank Rookie
    Dec 5, 2015
    35
    Monaco
    interestingly enough I had read this thread last week and took my 2011 FF (40k km 25k miles) to the dealer for annual maintenance... 50 min after I dropped the car off the Service Manager rang me back and asked if I had seen the Transmission light on at any time (I had not) as the computer clearly identified the issue with the speed sensor mentioned above. The service manager mentioned the sensor (and/or clips) are the cheap part but they need at least 35 hours labour to basically do what can be seen in the photos posted by MDEL. I have religiously renewed the Power extended warranty every year and the service manager was trying to confirm that this was going to be covered.... He also mentioned they have had a number of these issues with 2011 and 2012 FFs but very few on the newer ones. Will keep the group posted.
  9. PhantomCypher
    PhantomCypher Formula Junior
    May 25, 2014
    281
    35 hours at $205-240 an hour is going to be almost $8,500 in labor alone....
  10. FFantastic
    FFantastic Formula Junior
    Mar 23, 2015
    859
    UK Riviera
    Barrie John Lovelock
    No more than 2 years extended warranty though plus no limits to how many claims you make which begs the question; put 4k in an account every year religiously and if nothing goes wrong spend it on options on the next one .....or the warranty?
  11. otakki
    otakki Formula 3
    Mar 24, 2016
    1,635
    Buying insurance and warranty is paying someone to take the risk.
  12. Gh21631
    Gh21631 F1 Veteran
    9,367
    East
    2014 FF I was quoted 5700 for one year of warranty. Seems high but....
  13. ttforcefed
    ttforcefed F1 World Champ
    19,287
    Why not go to an independent?
  14. Motob
    Motob Formula 3
    Nov 11, 2003
    2,391
    Frederick, Maryland
    Brian Brown
    None of the independents have access to the factory diagnostic computer which is pretty much a must in order to diagnose a DCT isssue, as well as all of the special tools required to rebuild a DCT.
    If I was in the market for an FF, I would either get one with a warranty or set aside $30k to cover any DCT or PTU issues that the car may have.
    PhantomCypher likes this.
  15. otakki
    otakki Formula 3
    Mar 24, 2016
    1,635
    With all those cars in post #21 having the same DCT, I wonder what's the reason it's only affecting the FF.
    HKS479 likes this.
  16. pelank
    pelank Rookie
    Dec 5, 2015
    35
    Monaco
    quick update as promised. Ferrari HQ approved the work same day and the Scuderia dealer has started working on it this week. I am supposed to be getting some photos ref the rebuild... if they materialize will post.
    in Europe the warranty extension is about 4-5k Euro depending on whether you have claimed or not in previous year, I hear the comments from some Fchat members regarding paying every year - each to his own, for me it takes risk away so peace of mind and will make it easier to sell on in a year.
  17. Motob
    Motob Formula 3
    Nov 11, 2003
    2,391
    Frederick, Maryland
    Brian Brown
    It doesn't affect just the FF's. All of the Ferraris with DCT: Calfornia/T, 458 and F12 are all having the same DCT issues.
  18. ttforcefed
    19,287
    P1 in stamford has one. Have the car shipped there for 145 an hour
    HKS479 likes this.
  19. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    How did you come to that conclusion, that "...it's only affecting the FF."??? Did you read the posts in this thread properly?
    For instance, you had replied to MDEL who in post 31 of this thread had written "...I had an early NA California that had transmission problems at 20.000 Km..."
    FWIW, this 2015 blog documents similar DCT problems affecting the AMG SLS.
  20. Brandon01
    Brandon01 Rookie
    Aug 19, 2018
    1
    Brandon ilitch
    I’m trying to help a friend out he as a 2012 Ferrari FF and he has a transmission speed sensor problem. My question is that if anybody knows where those sensors are located.
    Thank you
  21. Gum12345
    Gum12345 Karting
    Jul 8, 2017
    171
    Does anyone have a sense how much cheaper it is to go with independent to fix ff engine, transmission and ptu? Just trying to figure out how much to put in piggy bank if I buy a FF.
  22. ml321
    ml321 Formula Junior
    Aug 26, 2008
    254
    London/Munich
    Had 2 repairs on my transmission
    First time a year ago it lost oil and they replaced something
    Second time this year, the car often did no longer want to shift into 7th gear at high revs (no issues at lower revs, say below 5k rpm)
  23. msgm1
    msgm1 Formula Junior
    Nov 4, 2003
    454
    NYC
    what is the mileage and year of your car?
  24. gh0st0
    gh0st0 F1 Rookie
    Jul 2, 2018
    2,932
    Midwest
  25. amenasce
    34,749
    Joe Mansion
    If the trans goes on a car out of warranty with say less than 30k, wouldnt Ferrari take some responsibility?
