Filling up and fuel guage questions | FerrariChat
Discussion in 'United Kingdom' started by forzarich, Feb 6, 2004.
  1. forzarich
    forzarich Karting
    Nov 11, 2003
    90
    Dorset, UK
    Every time I fill the car up it clicks off. I have pretty much got the hang of getting it mostly full with too much bother but I have never managed to get the guage to show all the bars on the fuel gauge.
    Are 360 gauges all bad and never show it as full or is it just that I still have another 10 litres of tank to fill?
    Even after a few clicks and a few more quid I always seem to have two empty bars on the gauge...
    Is it possible to get all bars full?
    What does it cost to fill up from when the petrol pump starts flashing? I mostly get about £65 in it and suspect it should be costing over £75. I always put SUL in it, does anyone use NUL?
  3. Robertb
    Robertb Formula 3
    Nov 19, 2003
    1,331
    South Oxfordshire, U
    Robert
    I have a similar prob with the 355. I suspect that it is a fault, but probably one that is easily rectified by clearing a vent or somesuch. (Over to you, Dale?)
    As I understand it, there's no particular advantage in using SUL in modern engines, but EVO magazine did a test with Optimax vs Premium, which showed genuine and proven benefits in engine cleanliness and power from Optimax. I use Optimax although it costs more- only a small incremental extra cost compared to servicing and insurance!
    Robert.
  4. wazza
    wazza Formula Junior
    Oct 9, 2003
    614
    This is a common problem with modern Ferraris generally.
    The next time you take it in for a service tell them.
    I think it's pretty easy to fix.
    It probably just needs recalibrating through the ECU or needs a new sensor or something.
    I have read about this problem many times on the F.Chat General Pages.
    Do a search under Fuel problems with 550 or 360.
    You should find something.
    As far as which fuel to use.
    Stangely enough Ferrari recommend standard unleaded (95RON)
    not the super unleaded or Optimax (97RON).
    I think it has something to do with the way the engines are set up.
    In older cars you could actually do it more harm by running a higher octane petrol.
    Altough it shouldn't matter in newer cars as the ECU compensates for
    any variations in Quality.
    But certainly for road driving (even aggressive road driving)
    don't waste your money you will never see the benifit of running higher
    octane/RON rated petrol.
    It probably makes a difference on the track, but even then only small.
    Wazza
    jusy my 2 cent worth
  5. Izza
    Izza Formula 3
    Nov 3, 2003
    1,046
    London
  6. daz355
    daz355 Formula Junior
    Jan 31, 2004
    743
    MclarenVille
    Darren P
  8. vanimal
    vanimal Formula Junior
    Mar 19, 2003
    380
    Vaughan
    I put in 85.65 litres in the week, all the bars on the guage were lit and the fuel logo had been flasjing for about 15 miles, so if the guage starts to flash at 15 litres as it should - 15 or so miles plus the 85 odd litres you get your 95, so mine seems fine. i do however drip feed it after the first click.
  9. forzarich
    forzarich Karting
    Nov 11, 2003
    90
    Dorset, UK
    Thanks for the info guys. Very helpful.
