Finally a hard start/won't start fix 81 308gtsi | FerrariChat
Discussion in '308/328' started by gilligan308, May 14, 2009.
  1. gilligan308
    gilligan308 Karting
    Dec 8, 2008
    141
    S.W.Florida
    Brian
    After all of the threads and my own research to get my baby to start or restart was finally concluded today. After fuse blocks,removing add on alarm kill switch,relays it was a bad accumulator as I posted previously as a possible culprit.The diaphragm had a hole in it and fuel did make it back to the tank via the safety tube coming off the back end of the accumulator. HOORAY!!!!! Draining 14 gallons of fuel was fun even with the lift,scary draining from the bypass drain as no valve to regulate the flow.I will get a new check valve on the fuel pump soon just for peace of mind.Thanks to all of the ideas from you all, Your a great bunch of enthusiasts,Gilligan.
  2. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Funny you should say that, I have the same issue and suspected same too.
    Where did you source the new accumulator?
  3. gilligan308
    gilligan308 Karting
    Dec 8, 2008
    141
    S.W.Florida
    Brian
    Most of the normal sources have it but it crosses over to many other vehicles. The new Bosch part # is 0 438 170 004 that used to be 113978. It is the exact same part. 209.00 at Rockauto.com and I did find less at other sources.Good luck I hope this helps let me know. Bently,Mercedes Benz,BMW all use it,Gilligan
  4. cockrill
    cockrill Formula 3
    Jan 23, 2008
    1,088
    Columbia, MO
    Jeremy Cockrill
  5. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Thanks: I'll probably source it from the local Bosch agents.
  6. PittsS2APilot
    PittsS2APilot Formula Junior
    Jun 29, 2007
    857
    Gulfport MS
    Joe
    I think I have a fuel accumulator on my parts shelf if you are interested. I bought one and found out my problem was the check valve at the pump. PM me if interested. Joe
  7. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    #7 doug328, May 15, 2009
    Glad you found the problem. When I bought mine 2 years ago I went through these guys as they had the best prices:
    Importec
    7012 Aspen Creek Ln
    Dallas TX 75252
    972-596-6965
    [email protected]
    fuel accumulator $182.16
    check valve $15.20
    fuel pump $249.59 (while I was there)
