I am glad you got it fixed ..and it feels good that GTE Confirmed my process/ idea in post 4 ..thanks for the info Sent from my moto g power using Tapatalk
Yes Flash32, you were right! Seems that if you are changing stuff “up top” in the system, you can get air out of that pressure relief bleed screw upon priming, and thus avoid forcing any air further downstream into the system. I’ll report back after a few more drives but so far so good!
I have done it with some others i helped ..if ignition on ..the pressure will drop when you relieve pressure back in reservoir and turn pump on .. just be careful to keep top on cause the pressure can blow fluid all over the place . Sent from my moto g power using Tapatalk
