First time 612 | FerrariChat
First time 612
Discussion in '612/599' started by michael stegmann, Dec 11, 2018.
  1. michael stegmann
    Dec 11, 2018
    3
  2. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    Looks nice !
  3. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    Take a very close look at the dash . If the plastic vent piece is curling up at the corners, or the leather is showing some wrinkles around the sensors then you will need to spend some money, this is a common problem area on many Ferrari's including the 612 .
    Check the tie rod ends for play, make sure there is no fuel smell in the trunk .
  4. michael stegmann
    Dec 11, 2018
    3
    Thank you, I will check it. It’s not so warm and sunny here, so I don’t think the leather will creep.
    Fuel smell in the trunk?
  5. ZDF_Fan
    ZDF_Fan Karting
    Oct 29, 2013
    57
    Kuwait
    Fuel pump seems to be a common problem with the 612. I replaced mine on a preventative basis after I got the car. The cost was reasonable from what I remember.
  6. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    There are two fuel pumps in the tank and the plastic fittings can crack with age and/or incorrect tension on the fuel line.
  7. F612
    F612 Formula Junior
    Feb 5, 2018
    603
    Leeds,AL
    David D. Hood
    One other thing to be aware of. Turn on the key and wait for the dash to "settle down" (5-10 seconds) before starting.
    The car does a self check and it needs time to do it.
  8. 360Marnix
    360Marnix Formula Junior
    Jan 4, 2017
    490
    Holland
    Vacker bil! :)
    Verstuurd vanaf mijn G3121 met Tapatalk
  9. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Must be an early 2007 since it has the single din radio of the 2005-2006. My 2007 HGTC had the much more usable double din Bose. Check all interior plastic bits for stickiness... expensive (if done right) and time consuming to disassemble and reassemble interior. As someone else said, check carefully for the dash leather pulling - it typically starts by the long defroster vent by the base of the windshield. I know you said you are in a colder climate, but it is free and takes 30 seconds to check... Costly to address correctly as well.
  10. Anthony James
    Anthony James Formula Junior
    353
    Essex
    I'm digging my 05. No mechanical issues. Needed tires (had the original tires). Buttons and dash are part of the Ferrari experience I guess. As a family ride, its an excellent choice. The tan and black look great from the post. GL
  11. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Newport Coast, California
    Ron H
    Nice looking car. The Challenge wheels are a plus as is the HGTC. Interesting that the steering wheel and the strip along the dash below the leather are carbon fiber. I was not aware that was an option. Maybe aftermarket? Looks great.
    I have an 07 and i love it. Semi daily driver (swap it with another car). I have owned it for 3 years and maintenance and repairs are very manageable.
    Good luck.
  12. 360Marnix
    Jan 4, 2017
    490
    Holland
    How was the car? It is for sale at Helsingborg right?
  13. F612
    F612 Formula Junior
    Feb 5, 2018
    603
    Leeds,AL
    David D. Hood
    My '08 OTO has the carbon on the dash and steering wheel. It is an option shown on the sticker.
    RonH likes this.
  14. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Ron H
    Nice David. I didn’t know that. Show us some pictures. I like the look.
    Sounds like this car the OP is interested in was pretty loaded up by the original owner.
  15. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Ron H
    That looks awesome David! Love the carbon. Wish i had that!
    Does the tan dash get to you? I had a similar dash and really liked the look but out here in sunny California the glare drove me nuts and I had it replaced with a black dash.
    Sorry to the OP for hijacking his thread.
  16. F612
    F612 Formula Junior
    Feb 5, 2018
    603
    Leeds,AL
    David D. Hood
    Thanks for your compliment.
    The dash can be a problem but the windscreen is vertical enough that the glare problem is rare.
    My 911 with a similar dash color is much worse. It's pretty but cars are meant to be driven!!
    RonH likes this.
  17. gburkett
    gburkett Karting
    78
    Austin, Texas
    Glenn Burkett
    That is a highly optioned 612, probably around $350 k new. Carbon fiber, HGT2, yellow tach challenge wheels , matching color leather upper dash. Quite a loaded car. Check that the ball joints have been changed and the tires are old and stiff. Not too many problematic areas with a well maintained 612. Drive it like a manual and it is a completely different vehicle. Sport settings and less auto mode and you won’t regret slacking on The Netflix
  18. TheCook
    TheCook Formula Junior
    Oct 16, 2015
    304
    Buckinghamshire
    Ian
    Beautiful 612! Plus one in ball joints, also check the handbrake. Enjoy.
  19. michael stegmann
    Dec 11, 2018
    3
    So, I took my Lamborghiniand went to look at the 612. Such a gorgeous car, interior was very well maintained, a bit sticky window buttons.
    The drive though, it felt very muted, and auto mode is out right horrible. Feels like a first gen Smart car, where your upper body falls forward between the super slow gear shifts. The car is well balanced and actually feels nimble despite the size. If I find a manual that may be the solution, even better would be a 612 without a drive train.
  20. F612
    F612 Formula Junior
    Feb 5, 2018
    603
    Leeds,AL
    David D. Hood
    My 612 is OTO and is nothing like this?
    I almost never us “automatic “ but works fine when I do.
    Did OTO change the transmission?
  21. 360Marnix
    Jan 4, 2017
    490
    Holland
    My 2006 with the F1-s transmission shifts great. I was actualy surprised by the smooth way it changes gear. If this is not the fact with yours, I personally would check the transmission at a Ferrari specialist.
    Makuono likes this.
  22. tazandjan
    38,087
    #23 tazandjan, Dec 17, 2018
    Driving a 612 extensively in Auto mode will make you hate it. I have had my F1 575M for 10 years and have never even hit the Auto button. Drive a dry clutch F1 system just like you would a manual transmission with the clutch pedal missing and you will love it. Drive it like a Buick in Auto and you will be very unhappy. If you intend to use Auto quite a bit, get a different car. Occasionally using Auto is fine, just not for me. It also takes a while to learn how to drive F1 smoothly, so do not be surprised if you are jerky at first.
    612 F1 software was updated continuously through production, with big improvements in 2007 (~125 ms min shift times for HGT2) and later with using the 599 Superfast 1 software (100 ms min shift times) and 599 twin disc clutch for the Sessantas and OTOs.
    lee-o, Nospinzone, TheCook and 2 others like this.
  23. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,380
    Weston, MA
    Paul
    In my 5+ years of ownership my 612 has been in AUTO mode only 4 times. The first time was when I first bought it just to see that it works, the second time was when I made the mistake of having a hot cup of coffee in my hand (there is no cup holder), and the other two times are when my wife drove the car.
    Note: Decades ago I tried to teach my wife to drive a manual transmission car. She just couldn't grasp the whole gas, clutch, brake pedal sequence. She said to me, "Why would anyone buy a manual transmission once they invented the automatic transmission?" Doooooooh!
  24. Cobraownr
    Cobraownr Formula Junior
    931
    Edgewater, MD
    Donald Silawsky
    I would appreciate comments from Taz or anyone else about "learning to drive an F1 smoothly." I never got the hang of that with my former 575 Superamerica. Do you try to anticipate the revs/min of the gear you are shifting into (up or down) and modulate the accelerator to get close?
