Flatbed towing | FerrariChat
Flatbed towing
Discussion in 'Ferrari Discussion (not model specific)' started by dhs-9, Nov 18, 2013.
  1. dhs-9
    dhs-9 Formula Junior
    Feb 6, 2004
    292
    Do you think it is better to put in a tow hook and winch on flatbed or drive it on.
    I would think if you winch you could control its speed and watch for contact with truck as it goes up
    what do you think drive or winch.
  2. V-TWELVE
    V-TWELVE Formula 3 Rossa Subscribed
    Jan 1, 2007
    1,800
    Vancouver, BC
    Winch it on all the way. On most flat decks the bed goes up on too steep of an angle and I would not like to drive it on. Winching is done at a very slow speed with lots of time for the operator to see what's going on and that everything clears. Much safer IMO.
  3. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,790
    Weston, MA
    Paul
    Agree with V12.
    If you do drive it on, you shouldn't go higher than 4th gear. :D
  4. V-TWELVE
    Jan 1, 2007
    1,800
    Vancouver, BC
    And no launch control if so equipped.
  5. etip
    etip Formula 3
    Apr 4, 2004
    2,406
    Washington State
    Eric
    Use the flatbed's winch. Hook to the tow ring under the front valance. The driver can get the bed at an angle where the cable won't rub on your car, then use some boards (if needed) to lessen the angle. They can pull it right up, all the way on with no rubbing at all.
    Hope this helps.
  6. ready321now
    ready321now Formula Junior
    Jan 5, 2013
    484
    New Jersey
    For those about to tow, I salute you. For an F 355, on a standard flatbed, it takes 2 boards under the front tires to make the lip of the flatbed without contact. Use soft straps, leave the tow-hook in place, (connected to the tow-cable), chock the wheels, and put it in neutral.Talked to a flatbed driver who tows exotics....he had a special flatbed with a different lip that is curved to accommodate low nosed-cars. Very nice. He also chooses to soft-strap the frame, not the front wheels, but will soft strap the rear wheels. Next time I will not use AAA. They had a mechanical error with their transmission, and my brick driveway has an oil stain the size of a large pizza now. Goddamit. Their truck broke down right after my car got to the dealership and off the flatbed. Close one. Wouldn't want my 355 on the side of the turnpike for 4 hours.
