flushing transaxle gear oil 360 | FerrariChat
Discussion in '360/430' started by jackgt, Jan 10, 2019.
  1. jackgt
    jackgt Formula Junior
    Jan 27, 2015
    499
    california
    Jack
    how many flushes is normal to get the transaxle clean after a heat exchanger failure?
  2. timwu12
    timwu12 Formula Junior
    919
    TX
    yikes, my condolences!
    I've read that it's taken some people 3-4 flushes but I would flush it until there's no oily film in the coolant reservoir and no water/milky residue on the gearbox's fill dipstick
  3. jackgt
    Jan 27, 2015
    499
    california
    Jack
    The heat exchanger did not leak very long. The radiator was easy but it took 3 flushes to get the gearbox oil clear. I was just wondering, seemed like one time should do the trick.
  4. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    You can fill with atf run it just enough to circulate then drain and flush. You cThe atf is high detergent and absorbs more water so a good starting point.
  5. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,344
    On the Limit
    Dino
    UrbanHero likes this.
  6. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,646
    Silicon Valley
  7. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,344
    On the Limit
    Dino
  8. mello
    mello F1 Veteran
    5,043
    CA Bay Area
    Steve
    Wow... the one on eBay used to be about $500 a few years ago. Gouge while you can, I guess.
  9. RedNeck
    RedNeck F1 World Champ
    10,017
    The CSA
    Me
    They accept offers ;)
    I got mine from eurospares for around $450 I think.
  10. jackgt
    Jan 27, 2015
    499
    california
    Jack
    When I work on the Ferrari, I just try to get the best deal I can. I drained the hoses and I let it drain for 2 days There must be some cavity in the transaxle that holds gear oil. maybe the pump?. Anyway I have a very clean transaxle now.
