Front hood release help! | Page 3 | FerrariChat
Discussion in '308/328' started by tinterow, Aug 18, 2015.
  1. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,307
    Black Forest Germany
    Martin N.
    this is the single latch version right above the brake booster, isn't it? Like discussed before - and I made the same mistake - he has two latches.
    BTW; No chance to reach the latch from under the dash.
    Best Regards
    Martin
  2. ntb308gtsi
    ntb308gtsi Karting
    Nov 17, 2013
    82
    South Africa
    Nick B.
  3. ntb308gtsi
    ntb308gtsi Karting
    Nov 17, 2013
    82
    South Africa
    Nick B.
    Martin, sorry, I missed that post! Then disregard my post :(
    Regards,Nick.
  4. Martin308GTB
    Jan 22, 2003
    4,307
    Martin N.
    Nick,
    no need to apologize. I have heard, that folks, who are working or trying to help, are making mistakes from time to time :)
    Best Regards from Germany
    Martin
  5. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Ok, this is great info...
  6. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Nick..THIS IS IT! This is exactly what happened...you nailed it.
    ...the latch was accidentally 'closed' before you shut the hood and you jammed it by pushing the hood forcibly down...
    Now..how can I get it open? And yes, I already have a flexible boroscope :)
  7. BigTex
    BigTex Seven Time F1 World Champ Owner Rossa Subscribed
    Dec 6, 2002
    79,408
    Houston, Texas
    Bubba
    I don't think that is possible...the cam that latches, if it was already in the closed position, would present a flat bar top surface and there is no way the hood rod could go in!!
  8. BigTex
    Dec 6, 2002
    79,408
    Houston, Texas
    Bubba
    I have extra hoods, hack it open.....
    j/k
    I also agree it would be extremely hard to reach the interior bolts that hold the hinge at the radiator, but that may be a better way to go at it, after removing the inner fenders??
  9. Martin308GTB
    Jan 22, 2003
    4,307
    Martin N.
    +1
  10. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Tex...I already thought about the new hood option...now where did I hide that blow torch?
  11. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Guys, just imagine you adjusted the latch too low and when it clicked in to place it is so tight it won't release. Under that premise...how do we get it open?
  12. E-Dino
    E-Dino Formula Junior
    Aug 11, 2012
    378
    San Diego
    Push down like a gorilla on the hood while pulling the release.
    If you were going to cut it open with a torch anyway then maybe a dent is better than a hole.
    Easy for me to say, not my hood :). Good luck :)
  13. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Dino...good point...haven't gotten to brute force yet...but may have to get there :(
  14. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    I was also considering a very large can opener:)
  15. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,842
    Cerritos, CA.
  16. 308gt4++
    308gt4++ Formula 3
    Apr 12, 2015
    1,245
  17. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    Ok...I got it! No dents, no scratches, no errors! Fixed!
    First, I had to get it open. I took a ratcheting tie down strap and ran one end through the emergency release and the other end through the seat belt mechanism. I ratcheted it tight to hold the emergency release in its pulled or "open" position. I then continued to pull, going so far as to stand on the strap to get more pressure...NOTHING!
    I then went to the hood and pushed and pulled up and down trying to get it loose. NO LUCK! Then went back inside and stood on the strap and lo and behold...POP...hood opened!
    I then examined the two mechanisms and decided to raise their adjustment up so getting stuck would not be possible. Checked the levers with hood open. Looked and felt good. Closed the hood...and....BINGO...stuck again!!!
    Went back for the strap...worked for 30 minutes again and got the hood open again. So, the question is...why is it sticking in the closed position. Upon further examination, I got it!!!
    There are two adjusting bolts that adjust the height of your mechanism...well guess what...if you tighten them down too much, they will squeeze the mechanism and when you close the hood the latch is so tight that it will not release. The fix? Loosen the adjusting bolts till they just hold the mechanism where you want it and "DO NOT OVER TIGHTEN"!
    That's it...fixed! Thanks for all your hints, suggestions and help! Chaya
  18. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    Glad it's fixed without any damage Chaya!
  19. ntb308gtsi
    ntb308gtsi Karting
    Nov 17, 2013
    82
    South Africa
    Nick B.
    Great news! I was cringing at the thought of you using that blow torch...............
  20. Jdubbya
    Jdubbya The $10 Trillion Man Silver Subscribed
    Dec 28, 2003
    43,882
    Hell's waiting room
    Glad you got it. I was extremely careful and nervous the first time closing my rear deck after I had redone boot area including cleaning and reinstalling the latches. I didn't want to end up in this same situation. :)
  21. miketuason
    Feb 24, 2006
    15,842
    Cerritos, CA.
    Well done and good job!
  22. 308 milano
    308 milano F1 Veteran Rossa Subscribed
    Jan 15, 2007
    5,351
    Montana
    Kim
    Very good news! Glad to hear it this morning! :)
  23. Tricycle
    Tricycle Formula Junior
    Dec 21, 2004
    636
    LA Cnty 4,083sqmiles
    Cool!
    Happy Ending.
    Though you left out the cursing and swearing part between it getting stuck again and spending 30 min to get it to release a second time :)
  24. f14dexter
    f14dexter Rookie
    May 4, 2005
    23
    Virginia Beach, VA
    Gus
    Hey guys -
    I wanted to revive this thread, and add some additional info that I didn't find in any of my searches.
    Background - '85 QV. About a month ago, my front hood became stuck - passenger side latch released, but driver side stuck. I jiggled, finessed, yanked the hood release over the last month, to no avail. Same with the emergency cable - nothing.
    Finally, I pulled extra hard on the lever tonight, and the offending hood latch popped open. So, I lubed both latches with white lithium grease, and tried to figure out why the driver latch stuck. After inspecting the cable between the two latches, I finally figured out what had happened. The cable had gotten stuck behind/under the brake reservoir cap. At least on my car, the cable runs between the latches and lays directly across the brake reservoir cap. I have had an intermittent brake leak in the right rear caliper recently, and had topped of the brake reservoir a few times over the last couple of months. The last time I must have pushed the cable out of the way to get cap back on.
    Once I laid the cable back across the reservoir, the hood opens and closes normally. I have taken a picture to show how my cable is routed.
    Really hopes this helps someone else!
    Now, back to troubleshooting my brake leak....
  25. Casino Square
    Casino Square Formula 3
    Apr 21, 2004
    1,728
    Hong Kong / USA
    Andrew
    .....I was getting cold sweats following this thread. Glad you had a happy non-damaging outcome ! It's good info for all of us.
