Fuel proof epoxy for leak? | FerrariChat
Discussion in 'Technical Q&A' started by bpu699, Feb 10, 2014.
  1. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    16,253
    wisconsin/chicago
    bo
    I have a Bosch fuel pump from a 930. Took it out to paint it... That was stupid.
    The pump has two screw pegs that come out for the electrical connectors. Apparently jostling the 30 year old pump disturbed a seal. It now drips fuel out where the electrical connector peg comes out.
    This is a low mileage pump, and I hate to spend 300$ to replace what is a good fuel pump...
    The pump is not rebuild able...
    Any one know of a glue/ epoxy to seal a pinhole leak, that's fuel proof?
    I was going to solder it, but can't. The peg is isolated from the pump body by an o ring, and solder would destroy that. Anything with heat, is out...
    I know this is an odd question, but someone must have had a tank leak or some other leak they fixed....
    Argh... If it ain't broke...don't take it out to beautify it...
    Barring a miracle solution, I will get a new pump tomorrow... And yes, I know, I am being a penny pinching son of a .....
    Bo
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,214
    Twin Cities
    Tim Keseluk
    JB Weld might do it.
  3. westextifosi
    westextifosi Formula Junior
    273
    Lubbock, TX
    Tex Timberlake
    I have had good luck with J-B Kwik Weld on an aluminum gas tank.
  4. bpu699
    Dec 9, 2003
    16,253
    wisconsin/chicago
    bo
    Thought about that... But isn't that porous?
  5. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
  6. sdtradingguy
    sdtradingguy Formula Junior
    720
    San Diego, CA
    Jb weld works well.
    I try to avoid using it. But sometimes it's a great fix.
    Clean the area very well. Use carb cleaner and than brake cleaner (to remove all residue).
    Scratch surface up, then spray again with brake cleaner.
    -I used this method last month after over a decade of not using the product. Sealed up my son's dirtbike crank case until the new one arrived. It was hit hard and had a slow leak. It stopped 100% of the leak.
  7. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    940
    Arizona
    Jim
    Another vote for JB Weld. I did some modifications to a couple of Holley carbs that have seen over 10 years of service and it is still in place. Just be selective on how you use it. I would not use it in a place that failure would result in in a dangerous condition.
    Cheers Jim
  8. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
  9. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Where is a safe place for a fuel leak?
  10. Jumprun
    Jumprun Karting
    Feb 7, 2012
    227
    Southern California
    T. Martinez
    I have used this product with great success to field repair a cracked pot metal carb while on tour. I intended to make a more elegant repair later but the putty worked so well I never got around to it. I now carry the putty in my break down kit.
  11. roadracer311
    May 6, 2009
    2,398
    San Francisco
    Paul
    Nice!
    A buddy of mine came to me with a motorcycle which had a 3" x 2" caved-in section from where the drive chain let go and cracked the cases. If he were a normal customer, I would have told him that his bike was broken beyond repair, because a) I thought I probably couldn't fix it and b) liability if it failed. Because I trusted him not to sue me if it failed, I patched it with this stuff, and two years later, it's still holding just fine!
  12. Motob
    Motob Formula 3
    Nov 11, 2003
    2,239
    Frederick, Maryland
    Brian Brown
    Why risk having a really nice car burn up for just $300? The pump is 30 years old! Just spend the money on a new pump and then you can have peace of mind and not have to worry about it leaking again in your lifetime. It is cheap insurance.
    Be glad that you don't have to replace the fuel pumps on a modern Ferrari. We have had to replace complete 360/430 pumps for $4500. Complete 550/575 pumps are now $7000+ for a pair.
  13. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,806
    Midwest
    Brian
    Absolutely!
  14. staatsof
    91,594
    Fuggetaboutitland
    Bob
  15. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,138
    Illinois
    Any fix like JB Weld in my opinion is temporary and will leak again. Sooner or later you will replace it. Keep looking around and I'll bet you can find the same pump cheaper. Have you tried Rock Auto?
  16. Mozella
    Mozella Formula Junior
    Mar 24, 2013
    905
    Piemonte, Italia
    It's been many years since I was fooling around with my '69 911, but I seem to remember the fuel pump was external, it was mounted just aft of the fuel tank, and it wasn't anything particularly special.
    If that's the case with your Porsche, why not take the old pump down to a good auto parts store and say, "Gimme' something like this".
    Chances are you can duplicate the effect for WAY less than 300 bucks, perhaps with the addition of an extra fitting or two.
  17. bpu699
    Dec 9, 2003
    16,253
    wisconsin/chicago
    bo
    I worry that if the pressures aren't spot on it will effect the CIS...
    Anyone done this before?
  18. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    You are working with a 930 correct? I too would think that getting the proper fuel preussure/rate would be critical.
    I've used JB weld on a holley carb for one of my corvettes to seal up the threads on the nut where the hard chrome line comes in and it held for many years.
  19. Mozella
    Mar 24, 2013
    905
    Piemonte, Italia
    I'll say again, I'm no Porsche guru, but I think your Porsche has a fuel pressure regulator at the injector module. Although the pump near the fuel tank is indeed a high performance (high pressure and flow) pump, I'm pretty sure the pump output pressure is not the determining factor when it comes to fuel pressure at the injectors.
    Here is link to Porsche pump specifications you might find interesting, especially if you are thinking about buying a salvage yard pump or a non-Porsche replacement pump.
    The position of the pump makes it a little tricky if you go to a "you-grab-it" salvage parts yard, but a good floor jack and a couple of stands should be sufficient.
    CIS Fuel Pump Options for more fuel! - Pelican Parts Technical BBS
  20. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,844
    NoNJ/Jupiter FL
    Steve W.
    That was my first thought. The fuel is leaking into an electrical connection. It doesn't take much to cause a fire which would be, of all places, in the fuel line. Hmmmm... is that a smart place to fool around?
    Have you looked to see if there are any alternative fuel pumps available as a replacement that would save you a few bucks? After my second SU fuel pump died in an old XKE I owned, a friend suggested another brand (don't remember at the moment) pump that would do the job. Since the pump was hidden in the back, out of sight, I didn't care about brand, I just wanted a dependable fuel pump. Changed it out, that did the trick. No more fuel pump problems and saved a bunch of money by buying a pump that was available OTC at any auto parts store. Just a thought.
  21. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    23,090
    Honolulu
    Kevin
    #21 Kevin Rev'n, Feb 11, 2014
    I like the parts store idea. This ebay ad seems to indicate that there might be an alternative
    High Performance Fuel Pump Same as Bosch OE 0 580 254 911 | eBay
    Bosch Ref. #: 0580254911, 0580254950
    Mercedes Ref. # 0020918801, 0020915901, 0020918901, 0030915301
    Universal Replacement Pump for following Bosch numbers:
    0 580 254 945
    0 580 254 946
    0 580 254 950
    0 580 254 951
    0 580 464 030
    0 580 464 034
    0 580 464 040
    0 580 464 041
    Fits following Mercedes Models:
    W201, W202, W129, W107, W126, W140, W124
    300E 2.6, 2.8, 3.0, 300CE 300TE 260E E320 E420 E500 E320 1986-1995 Sedan Coupe Cabrio Wagon W124
    190E 2.3, 2.6 190E-16V 1989-1993 W201
    420SEL 500SE/SEL/SEC 560SEL/SEC Sedan Coupe 1985-1991 W126
    560SL (300SL 500SL/SLC Euro) Convertible Coupe 1985-1989 W107
    C220 C230 C280 C36 AMG C43 AMG (C180 Euro) 1993-2002 W202
    300SL 500SL 600SL SL320 SL500 SL600 Convertible 1990-2002 W129
    All C-Class 1993-2001
    All E-Class 1993-2001
    All S-Class 1993-2001
  22. bpu699
    Dec 9, 2003
    16,253
    wisconsin/chicago
    bo
    Thanks guys...
    The fuel pump is in the front of the car, away from the motor, and 6 inches off the ground. It drips a drop every 5 seconds or so...
    The bosch pumps are odd, as I understand that the internals are bathed in the flowing gasoline, to keep the armature/etc cool. Not sure how that works, but thats what the web seems to suggest...
    I will try the JB weld. Searched the web, haven't seen anyone that found a suitable replacement...
    I know it seems cheap to try to fix this, but I have been going through this car for about 2 years now. There probably isn't much I havent fixed/replaced/adjusted/etc.
    $300 here and there, for every little thing, really starts to add up...
    It just kills me that there was nothing wrong with the fuel pump, until I was silly enough to move it from its restig place...
    Bo
  23. bpu699
    Dec 9, 2003
    16,253
    wisconsin/chicago
    bo
    What ad is that? What pump is that?
    the porsche part is #: 911-608-102-00-M14
    Bo
  24. Kevin Rev'n
    Nov 29, 2009
    23,090
    Honolulu
    Kevin
    #24 Kevin Rev'n, Feb 11, 2014
    I thought the part might be one of these...sorry.
  25. bpu699
    Dec 9, 2003
    16,253
    wisconsin/chicago
    bo
    #25 bpu699, Feb 11, 2014
    Ok, this has been enlightening!!! I want to thank all of you...
    I did look at Rock Auto...and the original Bosch pump was only $150... So, I ordered it...
    That, blows my mind. I called all of the porsche discount mailorder places and it was $254.
    Thats a HUGE difference...
    Anyone else ordered from Rock Auto? I see them advertise on muscle car TV shows, but never thought they would have porsche parts...
    Fingers crossed that it is the same - pictures sure look it.
    Rockauto's reviews are 5/5 stars with over 15,000 reviews! Wow.
    Bo
