fuel pumps leaking from the top center | FerrariChat
Discussion in '360/430' started by parkem, Nov 10, 2020.
  1. parkem
    parkem Karting
    Feb 17, 2012
    160
    florida
    peter palermo
    I took both fuel covers off and started the car and found both sides leaking.I took the ring lock off and removed the pumps ,could not see gaskets. can this be repaired or do you have to change them for new ones
    2005 f430 spider
  2. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    your best bet and safest is to buy new , more Fcars catch on fire from leaking fuel pumps .
    Eurspares sells new ones only 320.57 each . Image Unavailable, Please Login
    VAF84 likes this.
  3. VAF84
    VAF84 Formula 3
    2,278
    Central Texas
    I'd probably swap them out if I was you. However, when I purchased mine, the day I picked it up, I was told they had discovered a leaking fuel pump the day before, and that their shop had sealed it with some kind of carbon based material. It was done at Highline European (shop) next to the Luxury Auto Collection in Scottsdale. Maybe they can tell you exactly what they did. It has been about 2 years, 2,000-3,000 miles and one track day since the work was done; and I have no issues so far (knock on wood). I also have a 2005 F430.
  4. jag-oo-r
    jag-oo-r Formula Junior
    424
    This is apparently quite common on the 360 / 430 fuel pumps. VAF84 is right on the money. Many have done temporary repairs while waiting for parts to arrive (or to come off of backorder). Search this forum, you'll find a number of people have had success with JB Weld type products. Again; this is a temporary solution, but if applied correctly would likely be serviceable for many years. I filled one of mine so I could continue to drive while I waited for the replacement fuel pump to arrive, and then swapped it out.
  5. shad99
    shad99 Formula Junior
    Dec 12, 2013
    300
    Japatul Valley, CA
    Andy
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    If you decide to repair them, be sure it is done right. I believe a few people have got this badly wrong and up she goes
  7. parkem
    parkem Karting
    Feb 17, 2012
    160
    florida
    peter palermo
    I epoxied them yesturday afternoon, and will be starting it soon to see if they still leak. I will report later.I filled all 4 cavities like the previous picture in this thread.
    sparetireless likes this.
  8. parkem
    parkem Karting
    Feb 17, 2012
    160
    florida
    peter palermo
    Started the car and drove around the block and let run for 10 minutes and so far no leaks
    armedferret likes this.
  9. one4torque
    one4torque F1 Veteran
    5,720
    Houston
    One4torque
    I guess if it’s only you driving this car... but I could not live with myself if a loved one or mechanic or valet got cooked due to a repair like this.
  10. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Funny thing with some Fcar owners they will worry more about what kind of floor mats they have than the mechanical repairs and up keep .
    RobinMasters and brookliner7 like this.
  11. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Are you going to keep engine bay covers off ?
    If not ? you should and make sure you carry a fire extinguisher around in the front seat .
  12. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Oh yea almost for got, if you ever have any fire damage and your ins company finds this blog they may not cover your loss .
  13. parkem
    parkem Karting
    Feb 17, 2012
    160
    florida
    peter palermo
    I attached a fire ext,behind my seat last year and will keep my covers off for a couple of months
    RANDY6005 likes this.
  14. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    #14 Sj_engr, Nov 11, 2020
    Swap might be the best
  15. one4torque
    5,720
    Houston
    One4torque
    Further if a psgr perished lawyers would have a field day w a jb weld repair.
    for $300 per side not worth it to me.
  16. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    I think I watched a YouTube video where the tank had to be dropped slightly on the driver side swap. Is that the same story for the passenger side fuel pump? Or since no fuel level it pulls straight up and out?
  17. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    On the coupes there is a metal plate that has 15 6mm hex head bolts allowing the pump assembly to tilt sides ways for removal .
    Spiders do not they just left straight out allot easier to replace than coupes.
    Do not have drop fuel tank to remove fuel pump, and not to mention moving fuel tank around could cause damage and then motor and trans has to be removed.
  18. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  19. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
  20. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    #20 RedTaxi, Nov 11, 2020
    Sometime '07 onwards the tanks don't have the plate. The pump mounts directly to the tank. On coupes at least you have to move the fuel tank rearwards to get the pump up and out. Inner plastic wheel arch needs to come out to get to it. Not too bad, with a hoist. Tried gluing mine to no avail.
    Edit, just watched that vid above. That's what I had to do. Pre '07 is way easier. I don't think there is a difference in tanks between spider and coupe. Spider may be different to get them out?
  21. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  22. psessa
    psessa Karting
    Jan 9, 2019
    108
    Perry Sessa
    I have a 2007 coupe without the metal plate that allows access to remove the pumps. Has anyone had success with just loosening the tanks?
  23. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
    I wouldn’t epoxy it unless I was stuck on a road trip and had no other option.
    It’s a relief valve not serviceable and even if it was and you have the old pump in your hand to repair the valve just put a new pump in. the newer part is upgraded plastic.
    cavlino and EastMemphis like this.
  24. collegeboy
    collegeboy Formula 3
    Aug 25, 2007
    1,369
    Texas and Kaua’i
    Mikey
    And they are cheap.
    cavlino and 360+Volt=Prius like this.
  25. RedTaxi
    RedTaxi F1 Rookie
    3,339
    New Zealand
    Glen
    Yes loosen the tank and move it rearwards enough to get the pump out.
    cavlino likes this.
