News
Gearbox problem after new clutch 360 Modena 2001
Discussion in '360/430' started by SwedenPeter, Oct 11, 2018.
  1. SwedenPeter
    SwedenPeter Rookie
    May 9, 2013
    16
    Sweden
    Peter Dahlstrom
  2. radlu
    radlu Formula Junior
    Jun 6, 2005
    253
    I would just drive it for a couple weeks. Likely the clutch just needs to be broken in.
  3. does the car drive ok?
    if not, as an internet mechanic and internet ferrari expert (tongue in cheek), i'd suppose those 2x sensor cables were installed incorrectly?
    why do you want to disconnect the ground point if its only a clutch job?
    those ground harness are usually only touched when you are pulling the engine or replacing the harness
  4. SwedenPeter
    SwedenPeter Rookie
    May 9, 2013
    16
    Sweden
    Peter Dahlstrom
    I didnt disconnect the ground it was like that !! The sensor cables is installed correct. The car was alive for about 150 km then the problem starts
  5. radlu
    Jun 6, 2005
    253
    What about doing several hard launches off the line to break in the clutch?
  6. ok, get me thinking: more of a installation problem than an actual problem
