458 - Going rate for 458 oil, pollen filter, inspection? | FerrariChat
458 Going rate for 458 oil, pollen filter, inspection?
Discussion in '458 Italia/488/F8' started by F430 Driver, Apr 11, 2022.
Tags:
  1. F430 Driver
    F430 Driver Formula Junior
    Apr 23, 2008
    444
    Central New Jersey
    Just curious - now in 2022 what is the going rate on a 458 Spider (MY 2015) for oil change, new pollen filter and full vehicle inspection?
    I always thought this used to be around $500 to $600 for an oil change. The dealer quoted around $1600. Is this a typical price for these services/items? This is my 1st service outside the included 7-year maintenance.
  2. PMiranda
    PMiranda Formula Junior
    Jul 23, 2004
    594
    Austin, TX
    I just paid $300 parts, $640 labor last week at the dealer.
    $1600 sounds like a bi-annual service including brake fluid and spark plugs
    F430 Driver likes this.
  3. F430 Driver
    Apr 23, 2008
    444
    Central New Jersey
    I thought so too so reached out earlier to clarify if brake fluid was included or not. Still waiting for reply though
  4. Shorn355
    Shorn355 F1 Veteran
    6,656
    Colorado
    Scott
    Here is the annual (which is what the OP is referring to) from April 2020 - Labor costs may have gone up a bit since then but not much -
    ShadowLAP and F430 Driver like this.
  5. Shorn355
    Shorn355 F1 Veteran
    6,656
    Colorado
    Scott
  6. F430 Driver
    Apr 23, 2008
    444
    Central New Jersey
    this is helpful. Now waiting to hear which of these two services was quoted and if only annual why it’s now $1650 unless parts and labor skyrocketed this year from supply chain, labor shortage and inflation.
    took me for surprise as I always thought Ferrari oil service was a bit egregious at just $600 let alone $1650. 20 year cost of ownership going forward would come to well over $50,000 just for service if you account for future hikes and the dollars invested in just the market index
  7. Challenge
    Challenge Formula 3
    Sep 27, 2002
    1,947
    PA
    Kevin
    $2K and coolant not flushed? Man.
  8. Xrayv8
    Xrayv8 Formula Junior
    915
    New Jersey
    Xray
    I just had my 2014 458 coupe serviced last week at my dealer which is in its 8th year so out of the 7 year maintenance. I just paid $2700 for an oil change, pollen filter, air filter, brake flush, and control belt replacement.Labor was 2K and parts $700.
    Shorn355 and F430 Driver like this.
  9. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    11,375
    AUSTRALIA
    ANGELO
    The service plan is 7 years and the warrantee was 3 years , didn't any of you in the above take out the extended warrantees ?
    After the 7 years you can do the Main Power which will warrantee the car and its servicing.
    Note your cars are pre feb 2019 so they will always have an oil change.
  10. Xrayv8
    915
    New Jersey
    Xray
    After my 3 year warranty were up, I extended it 2 more years for around 10K at that time in 2017. However, at least in the USA, extending the warranty did not include service from what I recall, I may be wrong and someone can confirm this but after 7 years you still pay the routine service, at least in USA.
  11. MANDALAY
    May 23, 2013
    11,375
    AUSTRALIA
    ANGELO
    There is a new plan now that also includes service.
    I have a 2018. In 2021 I extended full factory warrantee for 2 years . Then I will go power plan for the next 2 years and end 2025 . Which will also be the last free service year .
    Then ill go on the new plan which is power and service. This is new and only has been introduced just recently. Main Power
  12. Balsamina
    Balsamina Formula Junior
    May 19, 2010
    935
    San Francisco Area
    S
    I had my 2014 458 Spider serviced at my dealer this week. $2360 labor and $460 parts for same 8th annual service plus blow ignition coils clean, inclusive of FCA member discount.
  13. HMB-Dino
    HMB-Dino Formula 3
    2,198
    Pebble Beach, CA
    RonG
    I just had my 2013 458 Italia serviced yesterday; all fluids changed (oil&filter, coolant, brake fluid, gear oil)...a little over $1800 by an independent who was the master mechanic at a Ferrari dealership. Sigh! I can remember the days of the $19.95 JiffyLube oil & filter change specials...
    F430 Driver and bball16 like this.
  14. KappaJack
    KappaJack Rookie
    Jun 28, 2017
    23
    I bought the whole cannoli for my 2015 458 Spider (performed at my new & local Ferrari dealership):
    Annual Inspection: $315.00
    Mount & Balance Tires: $1547.76 tires + $300.00 labor (I hate Pirelli tires, and prefer Michelins. They mounted Pirelli)
    4-Wheel Alignment: $499.00
    Camber Adjustment w/ Shim Replacement: $249.00 labor + $46.54 parts
    Oil and Filter Service: $420 labor + $175.05 parts (Shell Ultra 5W-40, gaskets and filter)
    Pollen Filter Replacement: $84 labor + $39.51 filter
    Gearbox/Differential Fluid Service: $294 labor + $225.24 parts (SPIRAX S5 ATE 75W90, 4 liters and drain plug)
    Power Steering Fluid Service: $399 labor + $49.64 parts (CHF11S 2 liters)
    TOTALS
    Tires (labor, parts, alignment, and camber): $2642.30
    Annual Inspection, Filters & Fluid Changes (Oil, Gearbox, Power Steering) $2,001.44
    WHAT $315 Annual Inspection Found:
    Rear Engine Oil Leak: $5250 labor + $684.01 parts = $5934.01
    GRAND TOTAL: $10,577.75
    (without coolant flush!!!)
    Mileage: 9785
    How do you say, "I got f#**ed" in Italian? Ferrari
  15. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    What exactly was the oil leak?
  16. FerrariCognoscenti
    Jan 19, 2021
    2,429
    East Coast
    -Parts cost:
    Oil $200
    Oil filter $50
    Pollen filter $40
    Brake fluid $50
    Coolant $30
    -Labor cost: $0
    I do it myself!
  17. Challenge
    Challenge Formula 3
    Sep 27, 2002
    1,947
    PA
    Kevin
    $84 labor for the pollen filter = "we hate you"
    KappaJack likes this.
  18. docf
    docf Formula 3
    Sep 14, 2008
    1,380
    Florida
    Gary
  19. docf
    docf Formula 3
    Sep 14, 2008
    1,380
    Florida
    Gary
    Find yourself a good Independant as I did and your cut your outlay to a little more than 1/3 of what you payed. My service included new drive belt ,oil, oil filter , brake inspec.,brake fluid,brake fluid flush,inspec. of engine filter, cabin filter,gen vehile inspection,top off all fluids. Did not need cabin filter.
    F430 Driver and KappaJack like this.
  20. KappaJack
    KappaJack Rookie
    Jun 28, 2017
    23
    The leak was on the main seal between the gearbox and the engine. Leak was on the engine side around the rear crankshaft seal. The rear crankshaft seal and both crush washers were replaced.
    The service advisor noted this as "yellow" meaning it was very minor. I never wait for any leak to repair itself.
  21. F430 Driver
    Apr 23, 2008
    444
    Central New Jersey
    #21 F430 Driver, Jun 3, 2022
    I found an independent close to me. Master Ferrari mechanic used to work at two Ferrari dealers as lead. Went off on his own. Will use him for next year. I went with Ferrari dealer this year and paid over 2X what he would charge. This service had a recall on it and for historical bookkeeping I wanted that to be recorded as completed by dealer so just had them do service same time. They've taken care of me for a few things in the past so it's my gift back to them. Next year for my full oil, brake fluid, etc service it would be around 3400 at my dealer. Independent will be under $1500 for everything.
  22. KappaJack
    KappaJack Rookie
    Jun 28, 2017
    23
    Your key word is a "Good" independent mechanic, and I find the factory-trained mechanics better. Sure the independents are cheaper, but they are training on your car. I know of good independent shops (with former factory training) in my neck of the woods and I have used them in the past on my other cars including Porsches and my McLaren. However, they, too make mistakes and have caused other forms of pains besides the one in my wallet.
    Thanks for reviewing my costs. I want this forum to know my experience.
    Arrivederci.
  23. docf
    docf Formula 3
    Sep 14, 2008
    1,380
    Florida
    Gary
    Really! Have collected all my life. My current mech was a Ferrari master mech. Do some research , but then again maybe not! your money do what you want.
