Header removal/used 328 Tubi
Discussion in 'Technical Q&A' started by snj5, Jan 19, 2004.
  1. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Is it possible to remove the exhaust system, including stock exhaust manifold, in a Mondial without dropping the engine?
    Would there be a market for a used Tubi silencer (USA spec) for a 328/Mondial 3.2 ?
    Many thanks
    rt
  3. tifosi69
    tifosi69 Formula 3
    Dec 23, 2003
    1,671
    Atlanta, Ga.
    Al-Al Cool J
    Are you interested in selling it? If so, how much. You have the whole exhaust setup, I already have the hyperflow race pipe bypassing the cat. Email me if you are interested in selling it.
  4. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Russ
    You can pull both front and rear manifolds on a 308 w/o pulling the engine. You need to release the shift shaft, engine mounts, maybe the coolant hose (which has some flex) and raise the front mount enough to pull the header. As far as I recall, you also need to pull the passenger gas tank. I'd think the 328 is similar and image the Mondial and the GTB/S are similar in the relevant portions of the frame etc.
    What are your plans?
    HTH
    Philip
  5. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Philip
    Thanks!
    I'm thinking about selling the US manifolds, Stebro test pipe and tubi in favor of a set of European s/s tuned manifolds and a QUIETER free flow muffler system with a lower tone (Larini seems good). It sounds like a 355 race car now, and a bit much for me when I'm not in the mood on a DC commute at 6 am.
    Will also look at making plugs for the air injection nozzles - those dudes apparently stick way down into the exhaust steam.
    We'll see - not really in a hurry. Would be nice to match the new cams to a better header.
    will decide next couple of days as to let tifosi69 and others interested in the parts know.
    best
    rt
  6. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Russ
    I have the specs for the 308 GT4 Le Mans headers somewhere. LMK if they'd be helpful to you.
    FYI, my car was slightly louder with the P6 cams at idle and definitely makes more noise under WOT. I think you'll hear it a bit more with cams. Tubi makes (or at least used to make) headers for the 308/328 series. None of these options are cheap or quiet. just got to use a light foot around town.
  8. jedsnephew
    jedsnephew Rookie
    Jan 2, 2004
    7
    RT,
    I would like to buy your Tubi and Stenbro, if they are still available. Drop me a line at: 330GT@homesalesautomation.com
    Thanks,
