Headlight removal help | FerrariChat
Discussion in '456/550/575' started by PRS Guitarist, Oct 13, 2014.
  1. PRS Guitarist
    PRS Guitarist Formula Junior
    Oct 13, 2013
    312
    Maryland
    Bob
    #1 PRS Guitarist, Oct 13, 2014
    I am changing out the dead battery on my alarm module with the corvette part from another thread. My problem is removing my P/S headlight. I have three 10mm head bolts out and it wiggles but I can't find the fourth bolt to pull. So far I have the one in the front by the hood bumper, the one on the bracket R side as you look at it from the front, and the one back left where the wheel well is. For the life of me I cant find the fourth bolt. Here are the locations I have out. Any help please, I checked the Ricambi parts page and it really does not show the mount bolts. Feels like it is stuck in the front left (Fender) side. The bolts i have out are marked with yellow note paper.
  2. PRS Guitarist
    Oct 13, 2013
    312
    Maryland
    Bob
  3. Konadog06
    Konadog06 Formula Junior
    Aug 22, 2007
    963
    Daytona Beach, Florida
    Bill
    #3 Konadog06, Oct 13, 2014
    Bob, not sure how much help I can offer. Have removed 575 headlamp assemblies several times, just don't know how much is the same. From your pics several brackets are similar.
    First on the 575 I was not able to access the alarm battery from beneath the lamp, had to go through the front fender front inner liner to access and replace mine. There may have been one bolt that I accessed from the top but foggy on this. The alarm had to come out from below.
    Back to the headlight. There are a coupe 550 lamps for sale on EBay with several decent pics. Link below. This may help as they've left some brackets attached.
    Ferrari 550 Maranello Headlamp Assembly L H Complete re Finished | eBay
    http://www.ebay.com/itm/Ferrari-550-Maranello-Headlamp-assembly-R-H-complete-Re-finished-/301349344121?pt=Motors_Car_Truck_Parts_Accessories&hash=item4629d21379&vxp=mtr
    Only other thing to add is remove that bracket base up near the front by the bumper as you've described as it makes it easier to remove and reinstall the lamp. If you still need help, PM me and I'll take some pics tomorrow of what I know has to be removed on the 575.
    Bill
    FL
  4. ///Mink
    ///Mink Formula Junior
    820
    Fair Oaks, CA
    Tom Mink
    #4 ///Mink, Oct 13, 2014
    Bob - there are 4 bolts you need to remove. In the pics below I have circled the 4 bolts in red. I have also circled in green other bolts you can alternately loosen or remove to make the job easier.
    On a 550, just removing the headlight will be enough to gain access to the siren.
    F456M likes this.
  5. PRS Guitarist
    Oct 13, 2013
    312
    Maryland
    Bob
    Thanks Tom, I was missing the screw that holds the wiring harness. You really have to loosen the other bolts as well but that did the trick. You are the man!
  6. Canuck550
    Canuck550 Formula Junior
    Sep 8, 2015
    462
    Incognito
    RJA
    Replaced my Alarm last night, under an hour, thanks to the illustrations and directions above! :)
    Used the corvette alarm which functions perfectly, direct plug and play, all lights flash per usual, slight chirp sound change, great result!
    No more permanent LED on the dash, keeping the Ferrari alarm just in case!
    Thank You for the information
    For Ref: Japan Import to Canada 550
    Il Tifoso and F456M like this.
  7. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    Congrats! I performed that operation at least five years ago and have had zero alarm problems since. You should be good to go for the foreseeable future!
