headlights stuck on 88 Mondial | FerrariChat
Discussion in 'Technical Q&A' started by crazy horse, Nov 28, 2003.
  1. crazy horse
    crazy horse Rookie
    Nov 4, 2003
    11
    the lights work fine but they are stuck in down retracted position. Seen a thread on it a while back.
  2. Robin Wells
    Robin Wells Rookie
    Aug 26, 2003
    29
    Dubai, United Arab E
    Robin Wells
    Have you tried operating the headlamp motors manually? If you open the bonnet and identify the headlamp-cover motors, there is a circular knob on the top of the rubber-covered cylinders and if you turn this clockwise, the headlamps will then raise themselves manually.
    This will then help you establish whether the problem is electrical (see my recent post - it probably is) or mechanical, and you will at least have some light on the road! As they have both stopped together, it's most likely to be electrical. Check whether they are receiving current, then check the fuse box to see whether the fuse is OK. Check also the operation of the column stalk at the steering wheel as this may have a poor connection, but I would suggest you start at the fuse box.
    Hope this helps.
    Robin Wells, Dubai, United Arab Emirates - 1986 3.2 Mondial Cabriolet
  3. crazy horse
    crazy horse Rookie
    Nov 4, 2003
    11
    Thanks Robin,will do.
  4. paulq
    paulq Rookie
    Nov 1, 2003
    7
    Northampton, UK
    Paul Quartermaine
    I had the very same problem on my '83 Mondial (lights on - no popup), turned out i had a blown fuse. The same fuse works the engine bay bonnet so check to see if that works.
    regards, Paul
  5. im4524
    im4524 Rookie
    Jun 24, 2022
    34
    George Spatola
    Does anyone have a fuse diagram to share?
  6. tazandjan
    38,436
    Should be one in the owners manual.
  7. Qavion
    Qavion F1 World Champ
    12,113
    Ian Riddell
    Is fuse 6 blown? Does your fuel cap lid open electrically?
    I don't know if this is the right diagram (there are lots of Mondial variations).
  8. Alden
    Alden F1 Rookie
    3,036
    Central Florida
  9. Alden
    Alden F1 Rookie
    3,036
    Central Florida
    One more thing to be careful of, if there's power going to the operating motors on the headlights. Twisting the knob on top of the lights can make them raise unexpectedly, I think you could lose a finger that way, lol.
    Alden
  10. Qavion
    12,113
    Ian Riddell
    @im4542 Since you've requested a fuse diagram on a 20 year old thread about headlight motors, can we assume you have the same issue?
  11. im4524
    im4524 Rookie
    Jun 24, 2022
    34
    George Spatola
    Yes, same issue. With the fuse diagram was able to fix it.
    Qavion likes this.
