Help! Have I destroyed my engine (348)? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by gredinger, Apr 9, 2004.
  1. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    29,377
    socal
    Don't guess! Get or do a proper diagnosis. There is alot of stuff in there that can fool you 1) water pump, 2) timing chain, 3) timing belt idler pullies, 4) even seen a TDC sensor hitting the wheel. Which expensive guess would you like to make? If you are going to do a DIY'er and you are not sure then at least pay the 70 bucks to get a mechanic to give you his best guess diagnosis before you go at it. If it is time to change everything and do a major anyway then for get the diagnosis and go to town. However, if you have the dreaded timing chain bearing problem you will be very dissapointed when the noise is still there after your major.
  2. gredinger
    gredinger Karting
    Feb 19, 2004
    50
    Sweden
    Peter Gredinger
    Tomorrow I will call the dealer, hopefully they have time for me in the close future. No use for me to continue guessing.
    Still confused by this 'one per turn sound'...
    Would have replaced the belt in like half a year, so I am of course doing it now instead (if the engine has to be taken out, which it probably will).
    I will keep you posted.
  3. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,631
    The Brickyard
    The Bad Guy
    Did you check the belt guides? They are the ones that are just above the intake cams. You should be able to see them with the caps off. Make sure that they are facing they proper way. The bottom of the shoe on the guide should be facing down and toward the exhaust cam. Look to see if the allen bolt on the front of the cam cover that runs through the guide is tightend properly to hold it in place. It could be that one of them is loose and when the belt vibrates you are hearing the guide hit the cam cover caps.
  4. gredinger
    gredinger Karting
    Feb 19, 2004
    50
    Sweden
    Peter Gredinger
    The belt did actually jump one step on the crankshaft.
    It is now corrected.
    The engine is not running properly, so some valves are damage...how many I do not know.
    Less than three years since the belt was replaced, so I guess it is just bad luck.
    Anyone who knows where (in the US or in Europe) to get some spare parts at a 'good' price?
  5. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    gredinger - You have mail
    MW
  6. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Before you tear into it,
    I would pressurize each cylinder to get an idea of where I had damage.
  7. gredinger
    gredinger Karting
    Feb 19, 2004
    50
    Sweden
    Peter Gredinger
    He did measure the compression and the readings were ok. Probably the damage valves were only minor damaged.
    The belt is now in the correct position so the sound is gone.
    The engine still runs good at idle, but not so good with load on.
  8. bob348
    bob348 Formula 3
    Apr 13, 2004
    1,553
    Liege, Belgium
    Geoffrey
    The owner manual of 348 mentions to change cambelt every 2 years...
    Sorry about your problem...
  9. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,792
    western hemisphere
    Every 2 years? Do what? You must be looking at a different 348 manual than mine. Mine says 52,500 miles and doesn't say a thing about years. I doubt seriously that this gentleman's problem has arisen because he didn't change out the cam belt often enough. There are still many 348's out there (89 and 90 included) that are running on the original belt and bearings.
  10. fatbillybob
    Aug 10, 2002
    29,377
    socal
    What? Make sure someone who knows what they are doing plays with your car. 1) Belts break but rarely "jump" without slck in the belt system...was there any
    2) how di you get the belt corrected w/o taking the engine out of the car?
    3) If the engine was not out the belt has not been moved.
    4) If engine out and belt slipped any mechanic shouldbe able to do a leak down test and not leave you guessing.
    Something does not sound right! Something is rotten in Denmark.
  11. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    They won't be running for long ... :(, idiots!
    Pete
  12. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    gredinger,
    Alot of what you have posted makes no sense.
    1. Washing a car will not (should not) cause a belt to jump a tooth, if that is actually what happened.
    2. To move a belt one tooth you need to remove a heck of a lot more than the little inspection cover, thus this also does not add up. I believe the 348 has an inspection hatch through from the drivers compartment, but even so usually the engine comes out for this work.
    3. Also you cannot LOOK at a belt and learn anything (other than whether it is oil damaged), you have to replace based on age and mileage.
    4. The original noise (assuming belt did not jump tooth) sounded like a water pump bearing or even a fan belt ... they can make horrible noises.
    5. If it has jumped a tooth, there is no way in hell that I would run the motor until NEW belts have been professionally installed ... but from your later posts it sounds like the heads have to come off and bent valves replaced anyway ... unless you are extremely lucky.
    6. Belts DO not just jump a tooth, something causes the belt to do that and it is extremely rare, although I have worked on a v6 Alfa Romeo engine that did jump a tooth on the dizzi pully.
    Don't muck with those belts, use a screw driver on their edge (unless replacing) as you will stuff the belt ... experts only should play with those.
    Good luck, but something does not make sense?
    Pete
  13. gredinger
    gredinger Karting
    Feb 19, 2004
    50
    Sweden
    Peter Gredinger
    Ok, I will try to clarify.
    First of all: As I understand it, it had nothing to do with the washing.
    The belt did jump one tooth.
    According to the Ferrari dealer I spoke to this is not unusual.
    He recently repaired a 355 due to this reason, also a TR in the past.
    Both these cars and other that he has repaired has jumped before the prescribed cam belt replacement time and also without any noticalbe slack.
    The only explanation he has is: It happens...
    To make sure that it actually jumped, the whole cam belt cover was removed. After conluding that it did jump, the belt was moved to its correct position and all the noice was gone.
    One, some or several valves were damaged and needs to be replaced.
    To be on the safe side both headers will come of to really be able to examine all valves. Also valve adjustments (on non damaged valves) will be made + replacing the cam belt.
  14. bob348
    bob348 Formula 3
    Apr 13, 2004
    1,553
    Liege, Belgium
    Geoffrey
    yes every 2 years ans maximum of 40.000 KM...so 25.000 miles....
    ok 2 years is really a short time...but every 4 years is a minimum and 40.000 km a maximum.
    it's really too important you have to do it, otherwise...big trouble could appear...
  15. Etcetera
    Etcetera Two Time F1 World Champ Silver Subscribed
    Dec 7, 2003
    24,376
    C6H14O5
    The best way to determine the source of metal on metal noises coming from the engine of a Ferrari is to start it up in order to find the location of the noise.
    Do this as many times as you deem necessary, and pay no heed to the sound of valves smacking into pistons or the sump sucking up metal shavings.
    Here's a few words from the wise:
    If it sounds bad, it is.
    If you are not mechanically inclined enough to know the difference between valve/piston contact and noisy water pump bearings, don't start the car. Instead, trailer it to a mechanic for a fix because:
    That's what you will have to do anyway.
  16. Husker
    Dec 31, 2003
    11,792
    western hemisphere
    Give me a break. I'd rate the risks of jerking off your cam belt and replacing every two years MUCH greater than a belt skipping a tooth. ANY time you start pulling off cam belts, etc., you have a decent risk that the new ones will 1) be faulty, or 2) they won't be installed correctly.
    Besides all of that, a cam belt change every 2 years makes no economic sense:
    Cam belt change No cam belt change
    Year 2 $5000 $0
    Year 4 $5000 $0
    Year 6 $5000 $0
    Year 8 $5000 $0
    Year 10 $5000 $0
    Total $25,000 $0
    OK, after 10 years with no cam belt change, SUPPOSE you break the belt and have to do a complete rebuild at $12-$15K. Get my point?
    Do you tear off the roof of your house and replace every 3 years so that you MIGHT avoid a 100-year rain penetrating it and as a consequence, having a large homeowners insurance claim?
    Do you do a complete service on your home's air conditioner every 2 months so that you can avoid buying a new one some day?
    Do you have the jewelry store tear apart your watch and put new parts in it every 6 months so that it won't break?
    The "change the belt" every 2-3 years is Ferarri's way of feeding their shops with YOUR money. Changing the belts this often is EXCESSIVE AND OBSESSIVE.
  17. cmparrenzo
    cmparrenzo F1 Rookie
    Mar 3, 2002
    2,687
    Kansas
    Chris Parr
    I think every 3-4 years is reasonable, I do my F40 every 2 years just to be safe though. If you can't afford the maintenance, you cannot afford the repairs!
  18. Husker
    Dec 31, 2003
    11,792
    western hemisphere
    Who said I can't afford it?
  19. Newman
    Newman F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 26, 2001
    14,538
    Canada
    Newman
    Because you choose to gamble rather than maintain, it gives the impression you are a tight-wad or cant afford it. Cant think of another reason.
  20. Husker
    Dec 31, 2003
    11,792
    western hemisphere
    Your definition of a "gamble" may or may not be what my definition is. Your definition of proper maintenance may or may not be what my definition is. Thank you, however, for sharing your opinion.
  21. tbakowsky
    tbakowsky Two Time F1 World Champ Consultant Professional Ferrari Technician
    Sep 18, 2002
    20,075
    The Cold North
    Tom
    I would have a second opinion on this one. Sounds very strange that the belt would just jump. I would have everything checked..from the tensioners, to the water pump, to checking the cams for binding. Something has to have caused this to happen. Are you 100% sure you did not drop somthing down inside the timimg cover when you pulled the inspection cap off?
    Please keep us updated as to what caused this to happen. Don't by the Ferrari thing that it "just happends"
    Tom
  22. BigTex
    BigTex Seven Time F1 World Champ Owner Rossa Subscribed
    Dec 6, 2002
    79,418
    Houston, Texas
    Bubba
    As my tech says, "If you hear a funny noise, bring it in, because when you hear how much it costs, it won't be funny!"
  23. gabriel
    gabriel Formula 3
    Apr 15, 2001
    1,647
    Port Saint Lucie, Fl
    Well said. :)
    I think this guy has done the math and also reasonably decided an acceptable risk to benifit ratio that he can live with.
    On another note, I'm sure Ferrari would mandate a bi-annual belt change if they could convince enough people that it needs to be done...not that regular maintenance should not be done, but I would be interested in exactly how many 12s have been trashed by belt breakage due to varying degrees of non-maintenance vs how many properly serviced engines have broken down vs numbers produced.
  24. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I personally know one one cam belt failure ina TR after about 35k miles without a service. But, it had a leaking cam seal that had being soaking the belt for some time that contributed to the failure. The owner had been warned by FOA that the cam seal was leaking, but he did nothing and it ended up costing him big. I go with cam belt change every 5 years regardless of mileage.
  25. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
