Help me please!!!!!!! | FerrariChat
Discussion in 'Technical Q&A' started by Steve328gts, Aug 10, 2013.
  1. Steve328gts
    Steve328gts Rookie
    Aug 10, 2013
    15
    I just got my 1987 328gts so driving it home for the fist time all is well then after about 100 miles of driving it started to lose power id say about 30% and the sound of the engine got a little Quiet, in lower gears the power comes and go's but only for a moment. When I got home I let it cool for about a hour. Then started it up a very sluggish start I may add. I then placed my hand over the Exhaust pipes and the right pipes are blowing much stronger then the left?
    Please tell me what you guys think it may be ? I'm very upset becouse I just got it yesterday and where I live there are no ferrari services.
  2. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,536
    Tuscaloosa, AL
    Drew Altemara
    My first guess is that you lost half the bank either front or rear and are only running on 4 cylinders. Maybe the digiplex went out on that side; Here I am assuming there is a left and right ECU - never owned a 328. But did have this issue on a 308QV. See if you have spark on both banks. I would not drive the car in this condition as you will be putting raw fuel into the exhaust headers and can melt them.
    Good Luck,
    Drew
  3. scorpion
    scorpion Formula Junior
    Jan 19, 2004
    469
    Kentucky
    Check the high tension leads. I had a very similar thing happen to me. When I bought my 308, after trailering the car home, when I started it up it was running on four cylinders. It ran perfect when I loaded it. One of the high tension leads had vibrated loose during transporting. Rattached it and no problem. Quick, easy and free fix but nerve racking until I figured out the problem.
  4. Steve328gts
    Steve328gts Rookie
    Aug 10, 2013
    15
    What and where is the hight tension lead? How would I check it?
  5. troyce
    troyce Karting
    Jul 19, 2014
    133
    East Tennessee
    Troyce Walls
  6. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,229
    Georgia
    Wade Williams
    That will do it. I had a 328 that only ran on one bank and everything looked great, but testing with a meter found the rotor grounded to the cam.
  7. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,931
    The stock US 328 exhaust system has a single inlet muffler so even if you lose a bank of ignition it has no effect on the ratio of what comes out the tailpipes (and the muffler is asymmetric inside so even when all is OK the tailpipe flows are unequal).
    The stock euro 328 exhaust system has a dual inlet muffler, but is also asymmetric inside so unequal flow at the tailpipes is normal.
    What version 328 do you have? Do you have a modified and/or aftermarket exhaust system (i.e., look at your muffler -- if it has a single inlet, almost no need to worry about what's happening at the tailpipes)? Agree with the others -- if it runs weakly, but smoothly = top suspect has to be a lost bank of ignition (and a MicroPlex-equipped 328 has fewer items that can cause that vs a DigiPlex-equipped 308).
  8. 308 milano
    308 milano F1 Veteran Rossa Subscribed
    Jan 15, 2007
    5,343
    Montana
    Kim
    Just another way of saying- set of spark plug wires that go from the distributors to the coils on your left hand side of the engine bay. Make sure they’re secure.
  9. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,166
    Atlanta
    Tom Spiro
    So also check the relays & connectors under the luggage compartment. under the carpet on the passengers side, you can pull up the carpet pad, there are 4 bolts - think they are 13 mm bolts, un screw them and lift out the plate. there are several relays there - one relay is pretty large, ensure that it is seated in the socket, and that the fuse is also good. a lot of time that relay can wiggle out of position and it gives you a very poor performing engine.... stumble etc...
    then also check the fuses in the fuse panel under the dash. you loosen the cover but un doing the two knurled knobs on the bottom of the dash.
    the exhaust pipes are functioning as normal - one is direct from the front bank the other goes along way around so the back pressure is usually stronger on the right side.
    only after you check the electrical connections would I start looking at the coil, and distributer. - unless that picture of your rotor arm is yours...
  10. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,333
    maurice T
    The OP posted this back in 2013,hope he got the car sorted.
