Help purchasing 308 | FerrariChat
Help purchasing 308
Discussion in '308/328' started by jonesdds, Sep 1, 2006.
  1. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    I'm in the market for my first Ferrari again, came close a few times, gave up for awhile but energized again to find the right one. A 308 seems like the best option, value, less depreciation potential and serviceability without a mortgage busting price tag. Based on my research, a pre-80's or quattrovalve seems like the best option, given the significantly reduced HP with the first fuel injected cars. While I think that the quattrovalves represent a fairly easy smog cert in California, the carbourated version concerns me. I'm interested in knowing if the pre-80's version is even smog-able and if not, what does it take to make it happen.
    Thanks in advance for the assistance.
    Jeff
  2. DavidDriver
    DavidDriver F1 Rookie
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    1975 308 GT4 is smog exempt in California. It's faster. Handles better. And is a better car for overnight trips, with room for a suitcase, and that case of wine you bought at the winery. Oh yeah... And the wine doesn't have to sit and boil in the boot either! It can fit very comfortably inside, on the rear shelf or seats, if you have them.
    It also stands a good chance of appreciating more than the GTS/GTB, (IMHO) in the near future.
    In either case though... A 308 should cost you little more than the maintenance expense to own, if you maintain the car. And if you're handy with a wrench, all the better. If not, make sure you get the best car you can afford and still have a few thousand in reserve.
    Good luck! Let us know what you finally get and remember:
    Threads that start "I JUST GOT MY FIRST FERRARI" and do not contain pictures.... Are worthless! :D
  3. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    I have a '79 GT4, and I'll agree with what David mentioned about the GT4. However, the styling may not be your cup of tea. That being the case, your question was whether or not carbed (i.e., pre-80) 308s can pass SMOG testing in CA.
    Yes.
    They can. That doesn't necessarily mean they always do on the first try. You see, carbs set up to pass SMOG and carbs set up to run ideally are two very different settings. What it will most likely entail is having your mechanic set up the car to run optimally. You'll then have to go back to him every 2 years for a pre-SMOG "tuning" to get the car set up for that. Once you pass, you go *back* and have the settings changed back to ideal running condition.
    It's certainly not glamorous, and it's more work than a standard EFI car would be, but the trade-off for me (the sound of the carbs) is worth the hassle!
    Best of luck in your search. You've picked a great place to come for info, support, etc.
    Take care -
  4. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,600
    Gates Mills, Ohio
    Jon
    Not to be the voice of doom here, but your 308 will be seeing a mechanic more often than every 2 years anyway.
    (But Aaron's answer is consistent with what I was told by a couple of F mechanics out here.)
  5. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    I am mostly interested in a 308 GTS or GTB. The body style of the GT4 is not quite as interesting to me, and I think time will show that the former mentioned have greater long term value. That being said, I'm not necessarily against any purchasing any Ferrari, just has to make sense relative to cost and expected costs in the future. Although the above statement somewhat express interest in the car being an investment, that's not actually the case. I want Ferrari I can enjoy driving, attend club events with, that won't break the bank to keep running. My concern is if I can't smog it in Calif without ridiculous costs, it won't make sense.
    That being said, a 308 GT4 is available locally in Santa Barbara on EBay. Strangely enough, it's the same used car dealer I had dealt with in looking at a 85 Mondial coupe 6 years ago. This is a comparable car to that with less miles on it. I'm going over to give a look see this weekend. From a maintanence standpoint and expense to own, any difference between the 308 GT4 and the 308 GTB/GTS?
    Jeff
  6. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Is it the red one with boxer trim, wooden shift knob and euro bumpers?
  7. BillyD
    BillyD Formula 3
    1,829
    Pacific Northwest
    Bill
    I sometimetimes wish I had bought a GT4 instead of a GTB. Easier to get in & out since I'm as old as dirt now & aging. Less noticable so I wouldn't have to stare straight ahead at lights or drive so defensive as the gawkers try & photograph me with their cell phone. At about 10k less than a GTB or GTS with the right wheels, color, sunroof & maybe lowered a bit its a killer.
    just my .02
    Bill
  8. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    Yes, that is the one. I've had a Euro MB 380SL and Euro BMW 323i myself and my dad important probably 20-30 grey market cars. No Ferrari's though. Only italian was Iso Grifo/Rivolta etc. that he imported. I don't know what concerns to have about Euro model Ferrari's, other than the obvious general potential issues including having the proper DOT/EPA docs and stickers in place. I found a shop a few years ago that didn't seeem to mind the proper stickers in place to smog a euro MB so I assume it's still possible to find shops that don't follow the rules to the extreme.
    Jeff
  9. PeterS
    PeterS Five Time F1 World Champ
    52,238
    Goodyear, AZ
    PeterS
    Been there, done that. You are 100% incorrect.
  10. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    That they are. A lowered GT4 with Euro bumpers is great looking. Make mine yellow.
  11. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    That's not a Euro car.
    Read this
    And this
    The seller is a "dealer"??? Hmmm.... :rolleyes: That's interesting. ...very interesting.
    Tow that car home. DO NOT drive it. It needs belts. IIRC: The current ones are over 10yrs old!
    PS: Edit.... 16-17yrs old!!!
  12. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    The dealer is a little suspect from past experience with him. Not necessary dishonest, just seems to deal in higher mileage cars with questionable histories. Well, might be a good learning experience just to take a look anyway.
    Jeff
  13. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    I think Vince from the other thread may be going there tomorrow to look at the car. Maybe you two should hook-up. I can't go with him tomorrow.
  14. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Dr. Jones,
    From the sound of it, you would be best suited to a 308 QV (83-85). If you can get into a SMOG-exempt 308 GTx car, go for it. If not, I think you'll really get the best out of the ownership experience from a fuel injected car. Don't get me wrong - I love my GT4. I do understand that "tinkering" isn't for everybody, though, be it for time constraints, limitations in one's mechanical abilities, etc. The carbed 308s are rather simple, mechanically speaking, but there are enough "quirks" with the design to make a novice like me wanna scream sometimes!
    Dollar for dollar, I don't think a GT4 can be beat in terms of all-around fun for your dollar. If the looks aren't for you, don't force it. Stick with a GTB/GTS, and find the best example you can afford.
  15. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    For my 1st Ferrari, I was looking at a 1985 308 GTB. They are the end of the 308 model line and by far the best sorted out. They have the quatrovalves, higher Hp, cats, injection, etc. Better still, the market has not over valued them yet. The GTB's are scarcer in the US, hence I thnk the future appreciation prospects are superior to even the GT4's. It's a main stream Ferrari, Pininfarina designed and easily recognizable. Maintenance should be better and they have the best performance of all the 308's. Heck if u really want to show off, get a 328 GTB.
    GT4's are "against the grain" since they are the only Bertone designed production Ferrari. They are an acquired taste and are not widely respected by the ferraristi. Sorry, I mean no offense to GT4 owners, but u guys just don't get any respect, IMO. But I digress. Take the '85.
  16. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    I heard that jonesdds (is that Dr. Jones?) bought the GT4 in SB yesterday. Well, I guess it looked too good, eh? Sneaky dude bought my car out from under me. LOL. Congratulations and welcome the Ferrari ownership! I look forward to hearing about the car.
    I still say the better choice was the 1985 308 GTB.
  17. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    No, I didn't buy the car. Didn't even have time to go see it, too busy building/installing bunk beds for the kids. You guys peaked my interest a little bit but I agree that a 308 QV is the best idea. Thought about a 328 too but maintenance costs are less for the 308 QV and worth the reduced HP.
    I have a few questions though further. I've research Ebay, Craigslist, Roadfly, Cars.com and autotrader.com including the local paper and LA Times for classified ads. What other sources are there to look for the right car? I'm not afraid to go into northern Calif, or even southwestern US, Oregon or Washington but sure like to be able to coordinate a PPI and testdrive the car prior to purchase. What if I can't view the car prior to purchase, is there trusted services to view and coordinate the PPI. What experiences has everyone had?
    Thanks for all the help with my quesitons.
    Jeff
  18. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,183
    E ' ' '/ F
    Snike Fingersmith
    I'm just curious about this statement. There's little difference between the the 308QV and the 328 -- what additional maintenance costs do you expect on the 3.2?
  19. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    My knowledge of 328's is not that great. What I'm really saying is the difference between the later 328's and 308's. If I not mistaken, engine removal is necessary for major service, correct in the later ones. I realize now, the earlier 328's probably compare to the QV's. My decision on a 308 vs. 328 would also be cost and I like the looks, especially with the front, of the 308's
    Jeff
  20. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    Both 308 and 328 major services can be done with the engine in the car.
  21. GrigioGuy
    Nov 26, 2001
    33,183
    E ' ' '/ F
    Snike Fingersmith
    #21 GrigioGuy, Sep 4, 2006
    Actually, the 328 is just the last evolution of the 308 series. None of the 328s require an engine-out for a major -- that started with the 348 series in 89-90. The 308QV and the 328 are very similar, with the same injection system and essentially the same engine/transmission/chassis setup.
  22. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Sorry u didnt buy the car - the seller told me that someone coming up from LA was looking at it and I thought it was u. That person ended up buying it, which I thought was kind of weird, thinking u might have had some questions before u pulled the trigger.
    328 is one hot property in the 3x8 range. Personally, I think they have become expensive compared to quality last year '08's. Either way, I know the "S" model is popular, but those "B's" are just too rare to ignore from an appreciation standpoint. Also, if u r going to track the car with the club, u'd feel better in a closed cockpit, not to mention greater chassis stiffness.
  23. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    Agreed... The 328 is almost too hot for my likes, all things considered. For essentially the same money, you can be into a 348. If the side stakes don't bother your and you don't mind an engine-out, you have a car that is low, wide, agressive looking, and will never cause someone to shout, "Hey! It's Magnum P.I.!" ....not to mention a half-decent performer, too!
  24. vvassallo
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Exactly! :)
  25. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    Thanks for the info, I guess I'm a bit ignorant on the differences. Maybe I was confusing it for being the same as an 88 or 89 mondial T? If I'm not mistaken the Mondial T's do require engine removal for major service, correct? Anyway, I agree with what you've said about the 328's and 348's vs. 308. I think a 308 QV has appreciation potential that is greater and will occur sooner than the latter cars, especially the 348's. They seem to me to be the least loved more recent V8 Ferrari's so I see a fair amount more depreciation in their future. If I could do a 348 I'd go to 355 myself but it's really not yet in the budget.
    Anyone have any additional resources for finding a 308 in California, especially southern calif?
    Jeff
