Help! Stuck in NM bank 1 not firing | FerrariChat
Discussion in 'Arizona & New Mexico' started by Roadking80134, Jun 22, 2014.
  1. Roadking80134
    Roadking80134 Formula Junior
    Dec 5, 2013
    267
    Spring, TX
    Rick S
    Anyone in NM? Is there a decent Ferrari mechanic in Albuquerque? ECU 1 shows Cyl 1-4 not firing. ECU 2 then developed O2 sensor failed and I started getting the SLOW DOWN warning. Just spoke with La Scuderia and they are not open till tomorrow am -- he's out of town.
    Thanks!
    Rick
  2. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    532
    Fountain Hills
    Jon
    What car are you driving?
    Need more info on when and what happened. Were you driving and all of sudden it shut down on one bank? Did you try starting it cold and 1-4 bank didn't fire? More info the better.
    Are you pulling the codes with generic reader?
  3. AronAZ
    AronAZ Karting
    Jul 13, 2004
    227
    Tucson, AZ
    Did you try to use the battery kill switch and let it sit for a bit then start up cold following the "ecu learning" procedure?
  4. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,739
    Weston, FL
    Scott
    Call Mickey at Jim's Fine Cars in Albuquerque: 505-883-4224. Tell him Scott from Miami referred you. I used to live in Albuquerque. He's the go to guy for exotic car owners. He has all proper diagnostic equipment for your car. Also one of the best mechanics I have ever known.
    Scott
  5. Roadking80134
    Dec 5, 2013
    267
    Spring, TX
    Rick S
    While driving on a very fun road around Mora, I noticed a lack of passing power. Looking down, the CEL was flashing. While driving, I pulled the codes on each ECU using EOBD Facile. Random misfires on 1-4. I limped to Las Vegas, NM and had her towed to La Scuderia in Albuquerque. While waiting for the tow truck, I did some prelim diags. Cold start, no change. Change relay in panel behind driver and passenger, no change. Codes also showed failed O2 sensor.
  6. Tcar
    Tcar F1 Rookie
    Maybe caused by the misfire?
  7. Tcar
    Tcar F1 Rookie
    Any news, Rick?
  8. tazandjan
    38,085
    Saw him at La Scuderia when I took my 575M in for its annual. Was fixed and he was gone a couple of days ago.
