Help with Daytona Steering Box | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by ag512bbi, Nov 21, 2020.
  1. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,692
    So. Cal
    Armen
    Anyone have any contact info on who rebuilds or sells a kit for a Daytona steering box in the USA? Too much play in steering and It seems the gears inside may even be grinding a bit. Any help would be appreciated.
  2. calder1
    calder1 F1 Rookie
    Sponsor Owner
    Aug 26, 2006
    2,917
    Redondo Beach
    Craig
    we rebuild them in house
  3. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,692
    So. Cal
    Armen
    Please give me your info and I'll contact you on Monday.
  4. calder1
    calder1 F1 Rookie
    Sponsor Owner
    Aug 26, 2006
    2,917
    Redondo Beach
    Craig
    You can call the office number . 310 937 6700 or you can email . [email protected]
    Craig
  5. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,692
    So. Cal
    Armen
    Thank u. Will do
  6. 1monza
    1monza Formula Junior
    321
    Manhattan Beach, CA
    Norbert Hofer
    Roelof's Engineering or GTO Engineering may have the parts for a proper rebuild of the steering box versus just changing a couple of oil seals and a gasket. I have purchase the parts for a 275GTB4 steering box from Roelofs in the past and worked out fine.
    ag512bbi likes this.
  7. TTR
    TTR F1 Veteran
    5,866
    Riverside, CA
    Timo
    Well, “proper rebuilding“ will likely still require someone like you, me or guys at Craig’s shop to actually make it happen.
    Just having parts or access to them may not be enough for most owners.
  8. 1monza
    321
    Manhattan Beach, CA
    Norbert Hofer
    Usually the excessive freeplay is because of worn out tie rod ends, bad wheel bearings and/or bad alignment. Rarely is a steering box worn out unless they run it out of oil. Daytonas are heavy and they eat tie rod ends for lunch.
    pilotoCS likes this.
  9. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,692
    So. Cal
    Armen
    Thank you for all the help
    I was lucky to find a new one in Europe.
  10. TTR
    TTR F1 Veteran
    5,866
    Riverside, CA
    Timo
    If you’re interested in selling your old one after the replacement, PM me.
  11. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,692
    So. Cal
    Armen
    Ill let you know if thats the case. thank you
    TTR likes this.
