How does this timing belt look to you? | Page 2 | FerrariChat
Discussion in '308/328' started by mustardfj40, Apr 20, 2009.
  1. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    #26 finnerty, Apr 20, 2009
    No worries Ken ---
    A lot of people on this forum forget that posting a reply to a thread is OPTIONAL.
    If a topic annoys one, and one has responded to it so often that is unimportant to one ----- well, there are other threads to choose from aren't there?
    I agree with Glassman ------- Give the guy a break :)
  2. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I just got a PM, so I thought I should clarify. Note I didn't say anything about being able to tell if the belts were good, only about if the belts were bad. A belt with missing teeth is bad. A belt without missing teeth might also be bad. A belt with worn teeth is bad. A belt with perfect looking teeth might also be bad.
    out.
  3. Glassman
    Glassman F1 World Champ
    Personally I have no problem with Timing Belt threads. Some are interesting some are very stupid. And sometimes a tidbit of information comes up that really helps.
    And as for the search function. Quite honestly the search function sucks. So being that we have discussed every aspect of the Ferrari already, what should we talk about now?
  4. finnerty
    May 18, 2004
    10,406
    #29 finnerty, Apr 20, 2009
    Indeed. And, as I no longer use the Pirelli belts, I learned something new from the photo posted in this thread -----
    How to say "Do not crimp / bend" in German and Italian!!! (I already knew the English and the French translations :))
  5. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    "Abstract: To design low-cost and more robust products, the application of probabilistic methods should be employed. This has been successfully carried out on a timing belt, a key component of the synchronous belt system for driving camshafts, water pumps, fuel injection pumps and balance shafts. The model development process for determining the durability and reliability of a timing belt will be discussed. The timing belt model, based on Miner's rule and the Arrhenius Law, will also be described for the primary failure mode of tooth shear due to cumulative fatigue. This is a closed-form engineering parametric model that considers the belt loads, geometry, mechanical properties, environmental effects and customer usage. The model calibration and correlation against accelerated testing and fleet data, respectively, will be shown. Using an algorithm in BASIC listed in the appendix based on the Monte Carlo simulation method, the predicted timing belt durability and reliability results will be given on an existing vehicle application and an optimised design for the same vehicle, where the belt construction and geometry have been changed. The benefits of using probabilistic methods in the design process are effectively demonstrated and depend on the use of accurate reliability prediction models."
    http://www.inderscience.com/search/index.php?action=record&rec_id=1271&prevQuery=&ps=10&m=or
  6. cockrill
    cockrill Formula 3
    Jan 23, 2008
    1,088
    Columbia, MO
    Jeremy Cockrill
    I appreciate the photos -- thanks for posting them! Now I know what 20 year old belts with few miles on them can look like.
  7. mustardfj40
    mustardfj40 Formula 3
    Jun 17, 2004
    1,142
    Northen California
    Ken
    OK, I got cylinder#1 to TDC after an hour or so, tomorrow the rear valve cover is coming off.
    Here's a stupid mistake I did today: I thought I didn't a have 36mm socket to turn the crank manually, so I rushed to Sears to pickup a 36mm socket. Well, I came home and tried it out, guess what??? I found the other 36mm socket on the floor...
  8. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    I think this is an opportunity to test an old, yet low-mileage timing belt. Is there a way to put it through a strength test, and settle once and for all the age-old question that has plagued us all for years around here?
    I'd be curious to know if this is even possible. Maybe the darn thing would prove to be OK after all..... NOT THAT I SUBSCRIBE TO NOT CHANGING THEM REGULARLY!
    I'd just like to know how much truth is in the factory's new recommendation to change every 3 years, regardless of mileage...
    Greg
  9. david bentley
    david bentley Karting
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    Thanks for the post
    Everyone was new sometime
    Dave
  10. ZiFF
    ZiFF Formula Junior
    Mar 30, 2009
    323
    LOL on the socket.
    How about some pics of your belt change project?
  11. BigTex
    79,406
    Houston, Texas
    Bubba
    Every belt over three years old.......
  12. BigTex
    79,406
    Houston, Texas
    Bubba
    #37 BigTex, Apr 21, 2009
    ...is BAD!!!!! LOL!
    Next question..........
  13. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    I cannot see condition or number of teeth, so I have to dip myself and move closer.:)
    Jokes apart, I was under the impression that timing belts are recomended to be changed every two years especially for low usage cars. Am I wrong?
  14. dwhite
    dwhite F1 Rookie
    Why not have a sticky in the 308/328 section of the more informative timing belt thread. However the 308 section will lose half it's threads and Rob probably can give up a server or two.
  15. BigTex
    79,406
    Houston, Texas
    Bubba
    #40 BigTex, Apr 21, 2009
    It's a Ferrari Tech Bulletin I should scan, I have it inserted into my three sets of Owner's Manuals....
    IIRC it's "three years, or 30K miles," so I run my cars 'round and 'round the Loop 610 here, at full throttle....to get maximum value!
    As you can see, that gal was trying to "stretch" the use of hers, and it failed........now she'll need sunscreen!
    I got that out of my apartment computer, I need to make a "WANTED REWARD" poster out of it and paper the neighborhood!
    There were several at the pool last weekend, might have been her! Here's the rest, of the vacation!
  16. ace_pilot
    ace_pilot Formula Junior
    Sep 6, 2007
    921
    Long Island, NY
    George
    There should be a gizmo or gadget that one can place so that it can either scan the belts with laser, infrared, x-ray, superman-eyes, that can pre-warn the owner of impending doom. Maybe the emitter on one side of the belt and the sensor on the other side so that there would be some sort of indication.....
    Ace
    BTW...patent pending....:)
  17. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I can see it already: "My 'Belts About To Break' light is on. What does that mean? Should I really change my belts, or is it OK to drive it for a while?"
  18. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Focus, BigTex, focus!!!
    Good stuff!
    Greg
  19. ace_pilot
    Sep 6, 2007
    921
    Long Island, NY
    George
    I was thinking more of a green----yellow---red----blood red----loud buzzer---hammer to the head---can not start the car type of gauge for people that don't understand the idiot lights. But I am open to suggestions!
    Ace
  20. mustardfj40
    Jun 17, 2004
    1,142
    Northen California
    Ken
    #45 mustardfj40, Apr 21, 2009
    I need your help here, while doing the belt, I'm going to rebuilt my water pump (even it's not leaking but what the heck, it's 20 years old), I need a place to get the water pump seal ring part# 152051. From my favorite part store the seal costs around 300 bucks. Right now I have the 409 seal but I think I need to modify my pump to make it work but I and would like to keep this original. Any other part store that I can get the part a little bit cheaper?
    Thanks God, my pump has the brass impeller, the blue stuffs on the pump are sealants from the factory:
  21. mustardfj40
    Jun 17, 2004
    1,142
    Northen California
    Ken
    Now imagine if there were no timing belts in our 3x8, this forum would be dead calm....
  22. mustardfj40
    Jun 17, 2004
    1,142
    Northen California
    Ken
    #47 mustardfj40, Apr 21, 2009
  23. mustardfj40
    Jun 17, 2004
    1,142
    Northen California
    Ken
    #48 mustardfj40, Apr 21, 2009
    I found the #152051 seal for an OK price at www.eurospares.co.uk. Are they reputable? Meanwhile I soaked the shaft with PBblaster and leave it overnight, will pull the pulley tomorrow, I taped the pulley so the puller won't damage the surface:
  24. tazandjan
    39,318
    #49 tazandjan, Apr 21, 2009
  25. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I've purchased things from them without drama. You will probably get a nice note from UPS after the package arrives asking for customs duties.
