How EZ Does Your Dino Start? | Page 2 | FerrariChat
Discussion in '206/246' started by 2dinos, May 20, 2013.
  1. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,882
    Southern California
    If I haven’t started my Dino in a bit I spray some starter fluid down the driver’s side intake after letting the fuel pump slow down. No choke needed here in SoCal. Starts right up and goes immediately to idle and starts up immediately every time after that. I do this to save the starter, pumping etc. As I said, I only do this when my Dino has been sitting. I have a gear reduction starter that gives a lot of energy to starting. I have the Winterburn CD Ignition.
    TheMayor and UroTrash like this.
  2. UroTrash
    Jan 20, 2004
    40,743
    Purgatory
    Clifford Gunboat
    Mine always required feathering after ignition.
    Cocoloco likes this.
  3. Cocoloco
    Cocoloco Formula 3
    Nov 26, 2013
    1,691
    Thanks. Assume you all use some type of simple battery tender - going to get a simple one today.
  4. Ken Ivey
    Ken Ivey Formula Junior
    258
    Portland, OR, USA
    Ken Ivey
    I've added a Luminition ignition to the distributor, Bosch electronics and gear reduction starter. No matter how long it's been sitting, I let the fuel pump fill the system, give the peddle 3 or 4 pumps and it fires right away. I don't use the choke, but have to keep the revs up for a bit - then it idles just fine...
  5. HMB-Dino
    HMB-Dino Formula 3
    2,353
    Pebble Beach, CA
    RonG
    Ctek Multi US 7002 - use one with each of my cars
  6. swift53
    swift53 F1 Veteran
    8,619
    E.S.
    Alberto
    My Ctek blew up a battery in my car, they would not reply to my complaints. Fortunately the car did no catch fire, but spilled acid all over.
    That, was a lot of fun to clean. :mad:
    You could offer me all your Cteks and I would not take 1 if you paid me to use it.
    Regards, Alberto
    TonyL likes this.
  7. HMB-Dino
    HMB-Dino Formula 3
    2,353
    Pebble Beach, CA
    RonG
    Which model Ctek? I have (4) in use and never an issue. Also note that modern Ferrari factory supplied chargers are Cteks with the Ferrari name on it.
    technom3 likes this.
  8. Skippr1999
    Skippr1999 F1 Rookie
    4,590
    Can you show where you spray the fluid ?
    I also have the Winterburn Ignition. Mine starts fine but I like the idea of not having to run the starter so much when the car has been sitting for a month or so.
  9. Cocoloco
    Cocoloco Formula 3
    Nov 26, 2013
    1,691
    Thanks ordered Ctek - have a Ctek lead I found under front bumper :) matched my BMW motorcycle. Made life easy
    NYC Fred likes this.
  10. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,882
    Southern California
    I literally spray it directly into the driver’s side intake as that side is used by the air box.
  11. swift53
    swift53 F1 Veteran
    8,619
    E.S.
    Alberto
    No idea, as it ended in the trash.
  12. dinogts
    dinogts Formula 3
    "No idea, as it ended in the trash and promptly started a fire....." o_O
  13. technom3
    technom3 F1 World Champ
    19,046
    Phoenix AZ
    Justin
    Yup almost every manufacturer uses ctek chargers with branding. McLaren Lambo Ferrari etc...
    We have a whole building full of cars on cteks. They are one of the only chargers I trust over night.
  14. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,354
    Norfolk - UK
    Tony
    I dont trust any 24/7 charger, Ctek or any other make.
    I have two Cteks and when one showed a floating charge and basically screwed up the battery I didnt trust them after that.
    any good battery should last 3 months at least without being used. I connect the Ctek once every 3 months and top up the battery, then disconnect. A simple sign on the windscreen over winter to remind me in 3 months time is good enough.
  15. DrDweeb
    DrDweeb Karting
    Nov 30, 2013
    172
    Hmmm ...
    a) Mine just starts, every time. It's always been that way.
    b) I have a luminition installed, a simple and excellent option that I recommend.
    c) My 1972 Euro 246 has an automatic choke based on an eccentric metallic device that closes as the engine heats. Set it once, and good to go. I assumed all Dinos had this.
  16. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,354
    Norfolk - UK
    Tony
    Hmmm.
    a) Same here.
    b) Winterburn ignition and it works perfectly.
    c) Not on any euro 246 as far as I am aware, I thought only 3x8's had that system?
    Tony
  17. gcalex
    gcalex Formula Junior
    614
    Mostly New Hampshire USA
    Alex
    To the original poster: If your choke is working (best to double check that it has not been disabled in some non-obvious way), and you are giving the carb-bowls enough time to pre-fill, you should not be having a hard time starting the car. If you are in some really cold situation (like freezing-or-below) it might still take a few attempts, but otherwise, a working choke ought to be enough to get a properly working car to start easily.
    Note that if you are in a place where the temp is (say) below 50-degrees-F, some pumping and retries are expected if you don't use the choke.
    How sure are you that the carb internals are clean/open, you have strong spark, etc? As others have basically said, you should check "spark" and "fuel" (as "air" tends to be more of a given)...
  18. Jakuzzi
    Jakuzzi Formula 3
    Mar 26, 2005
    2,167
    PR, TX, GV
    Jaime
    "How EZ Does Your Dino Start?" - Who is EZ? ;)
  19. John Skevington
    May 14, 2018
    17
    New Zealand
    John William Skevington
    Buy yourself a gear reduction starter. Its the best thing we have installed in our Dino in 38 years of ownership...its magic, and fully reversible. We have a huge variation in temperatures here in NZ. It was always hard to start when hot. Not anymore.
    HMB-Dino likes this.
