How far can I drive with a bad alternator? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by AZLambo, May 22, 2006.
  1. AZLambo
    AZLambo Formula Junior
    Nov 4, 2003
    511
    Phoenix, AZ
    Jeff
    Well,
    With bad alternator, but fully-charged battery, I made it to the dealer..........about 30 miles away! I monitored my battery voltage all the way with a voltmeter pluged into my cigarette lighter. Started out at about 12.3 volts..........and actually, the alternator must have been putting out something, because it actually climbed up to 12.7 volts as I was driving for awhile. The battery light is still lit up however because it should be at at least 13.5. But about 1/2 way there, the voltage started dropping, and was at about 11.7 by the time I got to the dealer. Man, I thought my engine would quit at any moment. Well, the dealer said that they might have found some "pinched" wiring that could have caused the problem, and installed a new alternator and belt........no charge. I picked up the car this afternoon.
    Started driving home, monitoring the voltage. 13.55......very good, no battery light on the dash! After about 7 miles, the battery light came on the the voltage dropped to 12.2. Dammit! Made a U turn, called the dealer on my cell phone, and told him I was heading back. Left the car there. I told him to find the fricking problem and fix it! Any ideas?
    AZFerrari
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    A battery with failed internal cells will kill an alternator. You've got to load test the battery to see if it is the culprit.
    A belt that is too tight will burn out your alternator bearings and kill it, too.
    A short circuit *could* kill your alternator.
    Extreme heat could kill it.
    A really bad oil leak dripping onto it could kill it, too.
    Your voltmeter in the cig lighter was a great idea!
  3. AZLambo
    Nov 4, 2003
    511
    Phoenix, AZ
    Jeff
    I HAD JUST PUT IN A BRAND NEW BATTERY, JUST IN CASE, SO I DON'T THINK
    THE BATTERY IS THE CULPRIT.
    THE DEALER JUST PUT IN THE NEW ALTERNATOR WITH A NEW BELT.
    I DON'T THINK IT WOULD KILL THE BEARINGS IN 7 MILES OF DRIVING.
    I JUST MAY HAVE SOME SHORT CIRCUIT SOMEWHERE, BUT EVERYTHING SEEMS OK AND THE BATTERY DOESN'T DRAIN DOWN BETWEEN DAYS WITHOUT DRIVING.
    IT IS HOT HERE IN PHOENIX, BUT 7 MILES ON A NEW ALTERNATOR?
    IT'S A POSSIBILITY, BUT YOU WOULD THINK THAT THE DEALER WOULD HAVE SPOTTED THIS, IF THIS WAS THE CASE.
    I THINK THAT IT HAS TO BE SOME SORT OF ELECTRICAL SHORTING.
    WE'LL SEE WHAT THE DEALER COMES UP WITH!
    THANKS, I THOUGHT SO.
  4. mad dog
    mad dog Formula Junior
    Jan 5, 2006
    875
    suffolk uk
    andrew
    Having similar problem with repeated (91) 348 alternator failures. Had a look and cant see a heat shield at all. Can anyone help I cant see it on any parts list, does the 348 alternator have a heat shield and anyone got part number??
    thanks
  5. BigTex
    BigTex Seven Time F1 World Champ Owner Rossa Subscribed
    Dec 6, 2002
    79,418
    Houston, Texas
    Bubba
    The old 308s have a heat shield on the back of the alternator, and the wiring runs in a plastic tube for protection as well......
    I had mine in my hands yesterday but it's back under the car now.
    It's a double plate of aluminum with four mounting tabs, allows about an inch of air between the plates and the rear of the unit.....
  6. mad dog
    Jan 5, 2006
    875
    suffolk uk
    andrew
  7. BigTex
    Dec 6, 2002
    79,418
    Houston, Texas
    Bubba
    Hmmmm....different configuration but that's doing much the same function.....someone must have lost yours or a design update?
  8. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    the alternator sense wire comes to mind. I dunno where the other end of it is attached, but it's job is to tell the voltage regulator what the voltage is at some point far away from the alternator (usually someplace near the battery or other main power distribution point).
    the vr then fiddles with the alternator to maintain the desired value at that remote point, which takes care of correcting for loads and other parasitic losses. A flaky sense wire will cause the system voltage to bounce around. Whether a busted sense wire causes the alternator to full field depends on the vr.
    I've never worked on a 355, so dunno where the alternator wiring is routed. Any chance of the wiring getting damaged when the engine subframe is r&red?
  9. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    29,399
    socal
    I may have the answer to 355 problems. Fisrt can anyone tell me if the 355 uses a 1 or 3 wire alternator?
  10. wolftalk
    Jan 27, 2004
    367
    san franciso area
    phil
    3 or 4 wire. pretty hard to have a sense wire on a 1-wire alternator :)
  11. fatbillybob
    Aug 10, 2002
    29,399
    socal
    Well then you see where I am going with this. I have no clue what your dealer did but he replaced parts and does not check the electrical system. Time for a new mechanic. He has had 6 trys now FNA or not. For example Did he check the voltage at the main junction or battery vs the back of the alternator with all accessories on? Did he measure the voltage drop across output of alt to main junction? Does the alternator compensate for this drop via proper sensing wire to the internal voltage regulator? I can only assume the alts he replaces with are good. But did anyone do a preinstall check of not only voltage on a testor but amp output? Some shops do not have the proper test equipment and so the alt passes a voltage test and they think it is o.k.. I think you have a wiring problem that is draining off the battery and the alts can't keep up because the voltage drop accross crappy Ferrari wires and the sensing wire is not telling the voltage regulator to turn on more power. If you have any aftermarket huge stereo stuff this is made worse. Also, driving style can have an effect as Dave Helms illuded to the rpm of the 355 is much higher than the American cars the alts are designed for. Ferrari compensates by guessing how you will drive and in the pully size of the alts. Ferrari uses standard alts and adapts to their high rpm use. The problem is when drivers take short trips and half the trip is like they are worried they will break the car keeping rpm low. Rarely do I see Ferrari drivers even come close to breaking speed limits. Most dare I say ...drive like miss daisy further worsening alt production problems.
