How long to change a CV Boot? | Page 2 | FerrariChat
Discussion in '348/355' started by vdettore, Nov 23, 2018.
  1. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    So it appears as the grease was generic (non branded). Do a search - it appears lots of companies made grease for CV joints.
    vdettore likes this.
  2. vdettore
    vdettore Formula Junior
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Thanks all. Not sure if my impact wrench qualifies as “good” [emoji16]so we’ll see.
    So will replace the cv boots on both sides then attempt replacing the right rear wheel bearings. At worst I’ll throw in the hat an order the complete hub with bearings
    Vince FerrariChat.com mobile app
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,671
    San Carlos, CA
    Mitchell Le
  4. WATSON
    23,926
    WI
    Impact wrench = disassembly
    Torque wrench = assembly
    Reversing that = serious damage.
    BTW, I have the "Porsche" CV boot parts option.
    If someone wants to go that route let me know.
    I never used them and they are available.
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    As confirmed by Johnk, they don't fit.
  6. yelcab
    Nov 29, 2001
    13,671
    San Carlos, CA
    Mitchell Le
    Correct, they don't fit.
  7. WATSON
    23,926
    WI
    Interesting.
    My dry fit suggested they kinda do. Just not well IMHO.
    The axle diameter was bigger than what the boot was built for but if a guy wanted to make them work...he could.
    Would I recommend it? No. I bought the Ferrari parts after I did the dry fit.
  8. yelcab
    Nov 29, 2001
    13,671
    San Carlos, CA
    Mitchell Le
    I would just get a correct boot from one of the Ferrari suppliers and be done. It is not that expensive....
    vdettore and Dave rocks like this.
  9. WATSON
    23,926
    WI
    Clearly what I did...and I agree.
  10. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    So why are you promoting the wrong stuff? :D
    /ducking for cover /
  11. WATSON
    23,926
    WI
    Yea, duck away actually....
    Promoting? Come on Dave....not sure where you got that perspective from.
    Just saying I have some parts and if someone is so inclined...they can have them cheap as I am not using them.
  12. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  13. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    What does it take to get the rotor off? There are no retaining bolts and I’ve tried tapping/whacking a wood block with a hammer up against the inside of the rotor.
    Maybe a puller? Just want to make sure I’m not missing something.
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Vince - you have an aftermarket wheel spacer on the car. Remove the 5 hex head bolts to get the spacer off. When off, you will likely have 1 or 2 other fasteners holding the rotor on the hub that will be visible once you get the wheel spacer off.
    ernie and vdettore like this.
  15. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Well I answered my own question. The rotor broke loose with vibration from impact wrench taking off the wheel spacer. [emoji106]
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  17. PaulK
    PaulK F1 Rookie
    4,801
    Michigan
    Paul
    Here is a tip for you- when you take the CV joints apart, either try to not take them apart all the way (by taking each bearing out one at a time and cleaning them one at a time individually) OR have some kind of a system to identify each bearing and where it goes in relation to the rest of the joint. Each bearing is of slightly different diameter than the next one.
    If you use a parts washer ensure it is completely dry before applying the new grease. The fluid of the parts washer will eat the grease while its in the boot.
  18. Rupp3r
    Rupp3r Karting
    Aug 26, 2016
    184
    France
    #43 Rupp3r, Nov 27, 2018
    Hello
    When doing the cv boot on my Mondial T I just removed the driveshaft by undoing the bolts from their flanges (gearbox and hub) and that was it, I left the hub in place.
    It should be also possible on a 348?
    You avoid to mess with the hub nut and other stuff to take apart and you save time, even if it is a little bit time consuming to undo the gearbox side bolts if you don't lift the car nicely.
  19. PaulK
    PaulK F1 Rookie
    4,801
    Michigan
    Paul
    I found these videos very helpful.
    ernie likes this.
  20. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Yes, I’ve been looking at them. Thanks. The difference is the one in the video has a axle shaft nut. Mine doesn’t. Looking at what this means as far as getting the shaft out
  21. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Looks the same for tightening an F-4 Phantom axel nut. :)
  22. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
    Ok so mine was the same as your Mondial T. Did not have to loosen the hub by taking the A Arm bolts out - Hallelujah !
    I’ll post more as I progress. If this novice can do it anyone can [emoji2]
    ernie and WATSON like this.
  23. WATSON
    23,926
    WI
  24. vdettore
    Mar 3, 2017
    353
    Georgia Coast
    Vince
  25. Rupp3r
    Rupp3r Karting
    Aug 26, 2016
    184
    France
    You have to use a plier like this one https://www.ebay.fr/i/332875757934?chn=ps&dispItem=1 to tighten the band and then cut it.
    I went through this two months ago I just gave up using these clamp since I wasn't managing to get it not to leak when back on the car.
    I bought standard CV boot clamps with their ears and with the proper plier it was done much more easily and quickly and it doesn't leak..
