How many use a special wrench for their knock-off wheels? | Page 2 | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by Ak Jim, Sep 17, 2010.
  1. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,077
    San Francisco Area
    John Vardanian
    I see the benefit of the special socket. I have used one for years and will never go back to the hammer, but what is the need for a torque wrench? With the right leverage the lug nut tightens till it bottoms on the hub. It's a binary thing.
    john
  2. modena1_2003
    modena1_2003 F1 Rookie
    Aug 17, 2005
    3,954
    Jon
    I'm sorry, but I thought hitting it with a lead hammer was common sense. I'd never have thought twice about it.
    I do think that wooden thing looks kind of cool though. :)
    _J
  3. buurman
    buurman Formula Junior
    Sep 21, 2004
    267
    cornelis leendert
  4. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    I take no credit for that device. I spotted it this summer in someone's trunk and was struck by its simplicity. I assume it can be used in four different orientations.
  5. ColdWater
    ColdWater Formula Junior
    Aug 19, 2006
    621
    bicoastal USA
    British car parts vendors sell these. The gap around the hub that is necessary to allow fitment causes slop in the application of force, which can send the wood and/or hammer off into the spokes and rim. The offset puts the swing of the hammer closer to bodywork. The wood soon splinters - and if it doesn't, your hubs are too loose for safety. It's also an awkward thing to carry and store. The urethane/rubber of a dead-blow mallet is probably more cushioned than wood, so the wood adaptor really adds nothing.
    Cornelis, you should get a hammer like this: http://www.harborfreight.com/3-lb-neon-orange-dead-blow-hammer-41799.html. 3 lbs is about right, and the urethane is nice and soft. The metal on your hammer is more risky, and the plastic faces are harder and much more inclined to slide on impact.
    Custom sockets and big wrenches are mechanical and intellectually satisfying. I have several myself. But a urethane dead-blow mallet would be used on winged knock-offs by Occam himself.
  6. buurman
    Sep 21, 2004
    267
    cornelis leendert
    Coldwater,
    It all depands in what hands this hammer is.
    I can not play golf with one hand.
    Cornelis
  7. ColdWater
    Aug 19, 2006
    621
    bicoastal USA
    #32 ColdWater, Sep 19, 2010
    Understood.
  8. John Vardanian
    Jul 1, 2004
    3,077
    San Francisco Area
    John Vardanian
    #33 John Vardanian, Sep 19, 2010
    The wooden tool may work for the common Dunlop wheels, but probably not too well for the 60's Ferraris.
    john
  9. Ak Jim
    Ak Jim F1 Veteran
    9,442
    North Pole AK
    Thanks for posting all of the responses. I was hoping there would be a right or majority answer but I guess there isn't. I think at the very least I will get one of those dead blow hammers.
  10. pauls
    pauls Formula Junior
    Apr 25, 2004
    566
    California
    I would advise against a dead blow hammer because unless you are very strong you will not get enough torque and loosing a wheel could be disastrous.
  11. John Vardanian
    Jul 1, 2004
    3,077
    San Francisco Area
    John Vardanian
    #36 John Vardanian, Sep 20, 2010
    The hand-eye coordination is the key. The reason why I stopped using the hammer is because about one out of ten times I would miss the knock off and land on the aluminum rim. This can happen more often the deeper the knock off gets, like the 15 inch wheels on the Lusso and the like.
    john
  12. pauls
    Apr 25, 2004
    566
    California
    #37 pauls, Sep 21, 2010
  13. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    The narrower older wheels aren't really the problem, and the danger of doing damage missing the spinner isn't as bad as with the wider rims of the sixties. John, you're right, those deep wheels are very imposing come the time to take them off. The deeper the wheel, the more angle there will be between an ideally directed blow and what you can effectively do within safety margins to avoid damage.
    Ideally, a tool for these should have an outside support, and act as a fulcrum, so you can apply force safely away from the wheel/bodywork and efficiently in the pane of rotation.
  14. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #39 Napolis, Sep 21, 2010
  15. 275gtb6c
    275gtb6c Formula 3
    1,942
    europe
    oscar
    Jim,
    That's handy but wont fit in my trunk......
    ciao
    Oscar
  16. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    We keep that one in our support helicopter. In our trunk we keep mini compressor,
    and can of fix a flat.
  17. 275gtb6c
    275gtb6c Formula 3
    1,942
    europe
    oscar
    Hi Jim,
    sounds real vintage :) I bought some run-flats for my 212 export, took some encouragement to convince the people from Engelbert to produce them, but was cheaper than a chopper.
    BTW, I use a "vintage"copper hammer but a modern jack, no problem finding the right torque as when you hear a dry "bang" the wheel is secured,
    ciao
    Oscar
  18. buurman
    Sep 21, 2004
    267
    cornelis leendert
    Oscar, on the track Jim's huge heavy weight tool brings a lot of DOWN force.
    Thats all what counts.
    The function has no importance.
    C.
  19. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #44 Napolis, Sep 21, 2010
    On the track what matters to me is that the original Ferrari KO hammer was total crap. Chris tried to use it at Le Mans on 0846's RT rear when he got a flat and the head of the hammer flew off and he was unable to change the wheel so he tried to drive back to the pits but the mag wheel caught on fire and the car burned. Luckily there wasn't enough time to repair the damage before the next race. Realising an opportunity I bribed the French to lower the prototype engine size to 3 liters so the P cars would be banned as well as the MK-IV's. This kept J6 from being used too much before I could buy her and caused Ferrari to disassemble 0846 and bin her chassis which I was able to retrieve and "Resurrect" (Ferrari's words). If that hammer hadn't been crap I probably wouldn't have wound up with 0846. All is good.
  20. VIZSLA
    Jan 11, 2008
    41,692
    Sarasota
    David
    For the want of a nail..
  21. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Always True...
  22. Bryanp
    Bryanp F1 Rookie
    Aug 13, 2002
    3,821
    Santa Fe, NM
    I KNEW it, you crafty, magnificent bastard.
  23. 275gtb6c
    275gtb6c Formula 3
    1,942
    europe
    oscar
    Where was the chopper when you needed it.....
    I never understood why they used magnesium for structural parts. Remember the Porsches in 1971 at LeMans....Well they did win though. Wasnt there a story that the weight of the oil cooler was saved as the chassis (magnesium) was used for cooling the oil...Those were the days,
    For now back to topic, Ferrari tools are crap anyway, ever tried an original jack? Driving magnesium cars is dangerous, but using the original jacks is a garantee for chopped limbs.
    Ciao
    Oscar
  24. todaxyz
    todaxyz Karting
    Jul 16, 2009
    133
    Nor Cal
    Tom
    #49 todaxyz, Sep 22, 2010
    My 330 GTC has 14" borrani's making it somewhat hard to hit the knockoff consistently. So taking a cue from another owner, I made my own tool. You can order spindle nuts in various sizes on line or at your local auto store. The one I purchased is a KD tools 3 1/2" #2451 for $17. I took it to a local machine shop who notched it so it would fit over the 3 ears. I took some 1/2" copper tubing (available at any hardware store), cut it in 5/8" lengths then cut it lengthwise so you have 2 pieces of 1 tube. I then wrapped the copper tubing around the notched edges of the spindle nut to protect the knock offs from getting nicked. I used JB Weld adhesive to secure the copper tubing to the spindle nut. I bought a 3" extension and a large torque wrench which I use to safely loosen or tighen the knockoffs. Works like a champ and I no longer worry about mis-hitting the knockoff. At Concourso this year, I saw a vendor selling the exact same spindle nut except they coated the end with a rubberized material in place of the copper tubing. The asking price was $350!
    Tom
  25. rosso dino
    rosso dino Karting
    Mar 5, 2009
    195
    I also use the tool from "oldtimer tools" on my Dino 246gt. For me it works perfectly too. Before I was using a lead hammer (not the original one ofcourse) which is still in the trunk.
    But now I am facing another "problem": Do anybody have an idea what is the correct minimum and/or maximum torque to use?
