How much does a 355 weigh? | FerrariChat
Discussion in '348/355' started by Dragster, Mar 23, 2008.
  1. Dragster
    Dragster Formula Junior
    Jun 8, 2007
    501
    Charlotte, NC
    Seems like I've seen a lot of different curb weight figures for 355s that range from 29XX lbs to 31XX lbs. I think Ferrari's website lists 2900 and change, but I've seen others that are higher. Anyone care to offer an opinion? Thanks!
  2. PAP 348
    Dec 10, 2005
    100,215
    Mount Isa, Australia
    Pap
    I have the following.......
    355 Berlinetta 1350 kg or 2976 lbs.
    355 GTS 1350 kg or 2976 lbs.
    355 Spider 1400 kg or 3086 lbs.
  3. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,957
    MD and NE
    Robbie
    The GTS would have to weigh more even by a pound or two over the GTB
  4. Fpassion
    Fpassion Formula Junior
    Jun 1, 2005
    599
    I am assuming this is dry weight?
  5. PAP 348
    Dec 10, 2005
    100,215
    Pap
    Well, thats what I thought also?? I dunno?? :p:p
    Yes sir. :):)
  6. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,424
    CT
    Jay
    While I have the WSM out...lists the GTB curb weight as 3152, GTS as 3174 lbs.
  7. cuneo
    cuneo Formula 3
    2,467
    is that with the maximum occupants and luggage, or without? The GTB feels closer to 2900 lbs, but I'm no expert.
  8. conscom
    conscom Formula Junior
    Jan 6, 2008
    467
    Vancouver BC Canada
    Gary
    Mine was built in Nov., 1994. My manual says curb weight is 1,475 Kg (3,251 lb). Carfolio.com says 1994 F355 Kerb Weight is 1350 Kg (2976 lb). Quite a disparity. ???
  9. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    I weighed my F355 spider with a full tank of fuel @ 6.3 lbs per gallon and about 60+ lbs of stereo stuff. It came in at a whopping 3400 lbs :(. More than my old 993TT @ 3350lbs.... :eek:
  10. Llenroc
    Llenroc F1 Veteran
    5,481
    Colorado
    Vern
    My '97 355CH weights 3069 lbs. of course this car has had the weight reduction program as per Ferrari race specs. I did add road tires(the race slicks were lighter) to it and a set of door panels vs. the aluminum door coverings, that might have totaled 50 additional lbs. Hope that helps.
  11. rketex7
    rketex7 Formula Junior
    Jan 8, 2004
    511
    Midwest
    K.C.Y.
    MY99 6 SPD, Tubi exhaust, high flow cats, little bit over 1/4 tank of gas, tool box, 12 cds w. case, pair of sunglasses... no driver, weighed in at 3,164 lbs.
  12. Dragster
    Jun 8, 2007
    501
    Charlotte, NC
    Thanks for all the replies! Is a car's curb weight always the dry weight of the vehicle?
  13. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,323
    Palos Verdes
    Vince V
    In general, the US version of weight is dry weight - nothing in the car. No fluids, no driver, no add-ons, zip. In Europe, they have another standard that adds normal operating fluids and a driver estimated at an average weight. It is quite possible that there are other weight standards depending on country and their regs. (and don't forget mandated equipment), hence the widely ranging values.
  14. Llenroc
    Llenroc F1 Veteran
    5,481
    Colorado
    Vern
    according to what I was taught/read years ago was that curb weight was the cars weight with all fluids. but without the driver.
    never thought about it before so I looked it up in Road and Tracks auto dictionary-"Weight of a production car that is ready for the road, with fluid reservoirs, including fuel tank, full all normal equipment in place without driver, passengers or cargo". Hope that helps
  15. conscom
    Jan 6, 2008
    467
    Vancouver BC Canada
    Gary
    Regardless, it still goes like stink! Every drive is an experience. It's a piece of artwork.
  16. TheRye
    TheRye Rookie
    Oct 4, 2008
    48
    Reston, VA
    How frustrating. I've been searching around the web and I too see all kinds of differnt listings, some with the Syder, Targa and Berlinetta as weighing in differently and some the same, and from 2900 to 3200 pounds. Why is this so convoluted? If you check on the weight of most standard cars, there isn't this kind of disparity. Whatever they call curb weight in the US dry or wet, it should be apples to apples form one source to another. My title says 2,900 but the OBD2 scan said 3,300 or something like that when I was at the emissions station. It sounds like the weights you gys have posted are closer to 3,150 to 3,200 pounds, but I've found artivles where they clearly state less than 3,000 pounds. Maybe it has to do with the stripped down weight that some of the test models may have had to boost performance numbers with the magazine or somehting like that?
  17. Llenroc
    Llenroc F1 Veteran
    5,481
    Colorado
    Vern
    Best thing I can suggest is to take to weigh station near you and have it weighed. I did my BMW one time a few years ago went to a metal recycler they charged my 5 bucks and gave me a print out.
  18. 134282
    134282 Four Time F1 World Champ
    40,647
    California
    Carbon McCoy
    Check out this thread. Dry weight for the Berlinetta is 2,976 lbs.
  19. TheRye
    TheRye Rookie
    Oct 4, 2008
    48
    Reston, VA
    So the Berlinetta Curb minus dryu weight = a delta of 176 pounds. Dry Weight plus all those fluids = curb weight. So that means there is 176 pounds worth of fluids. I looked it up and the gallon capacities of all the fluids are as folows:
    brake/ clutch (.33) fluid, coolant (2.42), diff/gearbox fluid (1.1), wiper fluid (.66), steering fluid (.35), oil (2.09) and gasoline (18).
    This comes out to 24.95 total gallons, or an average of 7.05 pounds per gallon. This makes sense as gas weighs about 6.1 pounds/ gallon and water weighs about 8.3.
    So, I think that addresses the discrepencies just fine. Awesome!!!
  20. UConn Husky
    Nov 11, 2006
    4,424
    CT
    Jay
    176 lbs. of fluids?!?! Well that's it I'm draining my oil and coolant tomorrow.
  21. TheRye
    TheRye Rookie
    Oct 4, 2008
    48
    Reston, VA
    Well, most of us weigh at least that much so maybe we should just let our cars drive themselves! :-D
  22. Krisatcruz
    Krisatcruz Rookie
    Apr 15, 2017
    5
    Recently had my
