how reliable has the 360s really been | FerrariChat
Discussion in '360/430' started by scycle2020, Feb 10, 2004.
  1. scycle2020
    scycle2020 F1 Rookie
    Jan 26, 2004
    3,477
    potomac
    Hey ferrari folk...those of you with experience with 360 coupes and spiders.....any reliability issues with either the early or late model cars?
  2. Brian C. Stradale
    Brian C. Stradale F1 Rookie
    Mar 17, 2002
    3,603
    Dallas, TX, USA
    I wish all my German cars had been as reliable as my 360 Modena has been.
  3. t88power
    t88power Formula 3
    Feb 19, 2001
    2,396
    Puerto Rico
    Ernesto
    3+ years, no major problems... broken ash tray, broker passenger door handle... thats about it....
    Ernesto
  4. allanlambo
    allanlambo F1 Rookie
    Jun 9, 2002
    4,363
    Maui
    Allan
    Uncles 360 coupe=tranny problems
    360 Spider=Roof problems
  5. ty (360mode)
    ty (360mode) Formula Junior
    Sep 25, 2002
    807
    Houston
    Tim
    F1 failure twice, got rid of F1, 6speed has had no problems at all.
  6. Prugna 328
    Prugna 328 Formula 3
    Sep 10, 2003
    1,233
    L.I.N.Y.
    Gregory
    Allan, F1?
  7. allanlambo
    Jun 9, 2002
    4,363
    Maui
    Allan
    No 6 speed. It would be very difficult to get in and out of 2nd and 4th gear. Dealer never could get it right.
  8. Hubert888
    Hubert888 F1 Veteran
    5,441
    Manhattan & LA
    Hubert
    only problems encountered are dead batteries (result of NYC cold winters)
  9. lawwdog
    lawwdog Formula 3
    Dec 4, 2002
    1,178
    Northern California
    Mario
    Allan,
    Of course you would happen to have knowledge regarding 2 bad 360's....thats odd.
    Any knowledge of problematic Lambo's? :)
  10. andybm3
    andybm3 Karting
    237
    Andy
    2000 360 F1 Coupe - No problems
  11. robinh
    robinh Formula Junior
    Jan 3, 2004
    622
    Cambridgeshire, Engl
    Robin
    2001 360 Modena (6 speed) - master brake cylinder leak but nothing else. Probably the most reliable car I've owned and the one driven te hardest
  12. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,183
    The Cold North
    Tom
    Speaking as a mechanic(none owner:() They have seemed to be quite reliable engine wise. The early ones had a problem with the connecting rods,because Ferrari did not allow for enough oiling between the big end jernals resulting in a dull knocking sound from the bottom end.
    Most problems I have seen are just trim problems and the occational roof problem on a spider..usually nothing to serious with the roof though. Batteries like stated above are common..crummy batteries.
    F1 cars seem to have some problems with the shifting solinoids on some cars, expensive to fix but if you get the warrenty(highly recommended with the f1 cars) no big deal other then loss of time with the car,while it's in the shop haveing repairs. The F1 clutch must be installed and set-up by the dealer inorder to set the slip rate. An independant cannot do this.$$$
    Timing belts are cheaper to do on the 360 as the engine does not need to be removed. But unlike the 348/355 the entire tranmission must be removed inorder to replace the clutch as it has returned to the conventional location mounted directly to the engine instead of at the rear of the car.
    The head lights according to some on the board have a problem with condesation getting inside the lenses. This really can't be repaired unless you want to attempt to remove the glass portion of the lens. Ferrari may cover this under a new car warrenty but doubtful on a used car.
    I have one customer who's radio kept shuting off on it's own when he went over bumps..easy fix..replaced the radio.
    The ignition key fobb seems to wear the silver coating they put on it with in a matter of weeks.
    The aluminum trim inside the car is very easy to scratch, and scuff marks are normal on the drivers side door panel trim.
    Look for scratches on the dash board surround directly above the steering colum. If you find an aera that looks like its been painted with touch-up paint this is a good indication that the dash was removed for "recalibration"(speedometer roll back) Even though it has a digital read out for the mileage it is easy to rest set to any number desierd.
    Tom
  13. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    Independants can do clutches. I've done clutch/gearbox swaps so many times in the race team I can't count. NEVER needed the SD2.
    Having said that, the Challenge/N-GT cars clutch behaviour is not too important. As long as it doesn't stall itself, it's no big deal. I fine tune with the SD2 later if possible may make it a little better, but not always.
    Occasionally, a computer gremlin will need the SD2 to clear it, and of course any clutch PIS adjustments need the SD2.
    As in independant working on road cars. I simply do all the hard work, then get the dealer to spend 1 hour max on a clutch clear and set up with the SD2. I get them to reset wear readings, do a test cycle, self learn and set PIS as necessary. Saves the owner thousands.
    By the way, the clutch wear reading is totally fixable and should NEVER be taken as proof of actual wear. It can be set anywhere the technician chooses. The only real way is to pull the floor and inspection plate off, and measure the plate thickness. It's quite easy.
  14. vanny
    vanny Formula Junior
    Nov 3, 2003
    262
    buffalo ny
    van molenberg
    i have a 2000 360f1-minor problems-gas gage, loose cd wire other than that it has run great.question timing belt cost?the dealer says it is time-do other people change them after 3 years?
  15. titanium360
    titanium360 F1 Rookie
    3,446
    2 360's and have had no problems.
  16. NTB
    NTB Karting
    Nov 3, 2003
    144
    Maryland, USA
    Tom
    2003 Spider - in 247 miles the following went wrong:
    Top malfunctioned 2 times, once on the test drive, once at home in the garage, it became stuck mid-way closed.
    Drivers door "hinge stop" broke, resulting in a door that would open to far, towards the fender.
    The passenger door handle broke.
    The battery would die in 5-7 days, required a full time charge.
  17. bostonmini
    bostonmini Formula 3
    Nov 8, 2003
    1,890
    now THIS is a useful thread! So good to hear "no problems....minor issue....more reliable than any other..." COOL! I want one, now we need a gallardo review, but too soon!
  18. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,823
    Jupiter, FL
    Paul Bianco
    100% satisfied.............thank God!
  19. ZINGARA 250GTL
    ZINGARA 250GTL F1 World Champ
    Jun 21, 2002
    17,499
    PA
    Ken
    Read your thread on the 360. Your battery problems may be due to not having a battery protector. They are a must for any car with a lot of electronics and an automatic alarm. These "vampires" will run you down to zip charge in three weeks. This has been one nasty winter in Central PA also. My 360 is ready to go on full charge and I have not had it out in a month. Just thought this might help. Luck, Ken
  20. jeff
    jeff Formula 3
    Feb 19, 2001
    1,924
    North America
    2001 6spd- clutch and tranny problems
    2002 F1 Spider-car has been perfect except for bad battery
  21. tifosi69
    tifosi69 Formula 3
    Dec 23, 2003
    1,678
    Atlanta, Ga.
    Al-Al Cool J
    Yeah, that is kind of funny isn't it?
  22. bgomez
    bgomez Karting
    Nov 3, 2003
    59
    2003 6spd coupe with 1800 miles. Check engine light has come on twice after not starting on first try. After about 4 restarts/drives the check engine light shut off by itself. Been very pleased in every way.
    Bill
  23. dwhite
    dwhite F1 Rookie
    Please include mileage in the replies.
  24. smsmd
    smsmd Karting
    Nov 12, 2003
    150
    San Jose, California
    Steven Scates MD
    2000 F1 coupe has had one dead battery I replaced, added battery tender. Just did the belt change-2800 dollars, but I asked the transmission etc be checked out at the same time-everything was fine.
  25. srpatterson
    srpatterson Rookie
    Feb 11, 2004
    3
    Kansas City, MO
    Steve Patterson
    2001 360 Spider F1 with 3200 miles.
    Top sticks a little if not cycled enough (mainly winter problem)
    Gas gauge will not read over 60% (I've think this is a fleet wide problem)
    No real problems, a great little car
