How To Get That F1 Sound | Page 3 | FerrariChat
Discussion in '360/430' started by Mrjb, Apr 15, 2025.
  1. DutchFerrari
    DutchFerrari Formula Junior
    Apr 7, 2022
    790
    Bollenstreek - Netherlands
    Jeroen
    Is the Sline on a 360 that much different to the F430? As i am yet to experience any drone on my F430, must admit maybe its the difference between a coupe in your situation and my spider? Admittedly no headers or cats done yet (still in the planning).
  2. boostedt0y
    boostedt0y Formula Junior
    Dec 25, 2014
    833
    Bay Area, CA
    I have a scud with S-line x-pipe. On stock cats, there wasn’t really any drone and while the car was loud, I didn’t think it was much louder than stock with the valves open. Once I added 200 cell cats though, the exhaust volume was much louder and the there is a bit of drone between 3-4k rpm. With the 200 cell cats, you can hear the trumpeting on decel which was not present on the stock cats.
    mb5 likes this.
  3. collegeboy
    collegeboy Formula 3
    1,430
    Texas and Kaua’i
    Mikey
    Must be different then.
  4. Jaymac
    Jaymac Formula 3
    1,001
    New Hampshire
    Jeremy McCurdy
    I just think the 360 and the 430 are so far apart in their sound, pitch, and tone in general. Whether it be stock system, aftermarket system, or any combination thereof. The five valve versus the four valve motor is just a different animal, from an aural standpoint. You really can’t use one as a basis of comparison for the other when talking about exhaust systems, in my opinion.
    Mel Spillman, Racer_X and vr4henry like this.
  5. jerbear27
    jerbear27 Formula Junior
    311
    CT
    Jeremy
    100 cell cats (Kline) on my f430 and I don’t notice any smell FWIW
  6. collegeboy
    1,430
    Texas and Kaua’i
    Mikey
    The high flow cat thing is a person by person basis. Apparently some people are sensitive to it, and I am one of those people. It sucks. Trust me, I wish I wasn't. I want Kline inconel cats BAD.
    jerbear27 likes this.
  7. Jaymac
    Jaymac Formula 3
    1,001
    New Hampshire
    Jeremy McCurdy
    To add some aural context to this thread, here are a few short clips of my latest setup. One with three stationary revs with valves closed, then with valves open. Another with a short 1-2 flyby in each direction. Unfortunately I didn’t have enough space to rev out 2nd gear in either direction. A third onboard video of a few pulls from 1-2 and 2-3. The driving video was taken the day after the install. Per Kline, the exhaust is shipped in an unannealed state, and must be heat cycled on the car to harden the Inconel and help the material develop its full potential of sound. I can attest to this, as the sound has gotten better over the past week and miles. It has a much more melodic tune in the lower RPMs, and has developed a fantastic metallic “zing” in the upper RPMs! I’ll capture another video of it as it develops. This latest setup is Tubi headers, sport cats (brand unknown) and Kline Inconel catback with Forza Componenti valve controller.
    dizzy, mb5, Mrjb and 3 others like this.
  8. collegeboy
    1,430
    Texas and Kaua’i
    Mikey
    Practically the same setup as me. It sounds great in the videos, but still, you just can’t capture that special sound Inconel makes. Seriously have to hear it in person. I bet you’ll agree. Nice car! Enjoy!
    Jaymac likes this.
  9. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,823
    Lake Villa IL
    I'll throw in my .02 on this. Of course the F355 and 360 are similar engine architecture.
    I believe the high pitched/F1 sound on F355 is from divorcing the flow after the banks mix together in the y-pipe from the main muffler.
    For example, on an F355 you have the primary ex path that leads to the muffler. The secondary path leads to a y pipe and single bypass valve. That bypass valve exits to the top of the muffler and the most high pitched setups, that inlet on the muffler is just a Y or T internally straight to the tips and does not mix with the internals of the muffler.
    So for the 360, on the Kline for example, the tubes to the muffler inlet are -after- the x-pipe. So when the valves open it's not purely putting that bank to bank mixed exhaust to the tips, it's still open to the muffler.
    In my opinion, it would be much more "F1" sounding if closer emulating the F355 layout. So for muffler inlets should connect-before- the x-pipe rather than after it.
    So when valves open it's pure high velocity to the tips rather than dulled by the main muffler.
  10. collegeboy
    1,430
    Texas and Kaua’i
    Mikey
    It’s nice the way Kline does it because the pitch is a nice high pitched xpipe sound if it goes through the muffler or not. Just loud or quiet. That’s nice. Also, the pitch is higher than SLine was, and SLine doesn’t even have a muffler. I think there’s something else to it that makes the 355 sound like the 355.
  11. Kent Adams
    Kent Adams F1 Rookie
    3,512
    #61 Kent Adams, Apr 27, 2025
    You need to increase the flow out. Keeping the cats will prevent that, full stop. However, 100/200 cell would help along with an X-pipe. You will also need to change the headers to a race header. Here is an instagram video of the best sounding F430 with all those mods I listed, but it is a straight pipe (no cats). A 360 with these changes should sound even better because of the 5 vs. 4 valve.
    I'd be surprised if you could get away with having a set up like this in the UK. It can produce up to 130 dbs at 20 feet when in high revs. This set up would be illegal in much of the US.
    https://www.instagram.com/p/CPGITkgJm02/?hl=en
    Mrjb likes this.
  12. Mrjb
    Mrjb Karting
    Jan 12, 2022
    97
    Matt
    Started looking at 200 cell cats. There seems to be a really wide range of prices.
    Is there much difference in terms of what you’re getting between the £1200 and £4k offerings. I can’t imagine there’s a huge number of places on the planet that actually build the cores of catalytic converters.
  13. Jaymac
    Jaymac Formula 3
    1,001
    New Hampshire
    Jeremy McCurdy
    The only insight I can give is that not all aftermarket products are created equal. My car came with hi flow cats that the previous owner had bought and installed by what I believe to be a reputable shop in the US. While the cats themselves have no physical markings or labeling on them, the invoice only states “High Flow Cat System for 360”, for a price of $1,953. This was back in 2019. At the same time, they also installed Tubi Competition Insulated headers.The cats don’t look like anything I’ve seen for sale by Tubi, but I suspect for under 2K, they are not. The main issue is that they don’t fit like the OEM cats. The left one appeared to be longer than the OEM one, to the point where I can never get any cat back to sit even in the car (I’ve had 4 different ones now), fore and aft, left v right. The left side always sticks out 1/2-3/4” further. You can even see it in the way the muffler sits. I even cut off half an inch from the tail section during my recent Kline install, thinking the tail was too long and was bottoming out inside the cat-back. I don’t know where else the issue lies, but I’ve tried multiple rotational adjustments of each cat, pushing/pulling, leveraging, and fighting with everything to get each catback to sit evenly, but it just won’t with these cats. As soon as I put the OEM cats back on, the catback sits perfectly even first try. Frustrating, but I don’t like the way the stock cats sound, so I live with the uneven fitment. I’d also rather have it even left to right than fore and aft. Left to right maladjustment can lead to rattling and vibrating against the mesh grilles in the exhaust outlet.
    This whole long-winded story is to say that yes, spending more money might be worth it for the cats just due to fit and finish of the cats and how the actually work in the car.
    Mrjb likes this.
  14. Mrjb
    Mrjb Karting
    Jan 12, 2022
    97
    Matt
    As you’ve swapped a couple of times from sports cats to standard, are the sports cats with the valve closed bearable.
    The reason I sold my capristo 3, was there was no escape from the noise at low speed :D
    collegeboy likes this.
  15. Jaymac
    Jaymac Formula 3
    1,001
    New Hampshire
    Jeremy McCurdy
    Sport cats with valves closed are entirely docile and disappear into the background. Valves open, all depends on the catback after that. My Capristo twin sound was great for the reason. Valved for quiet driving, and roaring with valves open. Incidentally, it happens to be for sale in the Classifieds right now! :eek:
  16. Mrjb
    Mrjb Karting
    Jan 12, 2022
    97
    Matt
    Have already put the Kline system on there, so hoping the sports cats will get the wail I’m after.
  17. Jaymac
    Jaymac Formula 3
    1,001
    New Hampshire
    Jeremy McCurdy
    In my experience, they did. I was disappointed the first day, and switched back to sport cats the second day. Much better.
    If I didn’t already have some, I probably would’ve sprung for Klines Inconel Cats, just to get more Inconel tone and pitch!
  18. Mrjb
    Mrjb Karting
    Jan 12, 2022
    97
    Matt
    #68 Mrjb, Apr 27, 2025
    Hoping I can get the sound of the silver car which I linked to in my original post, which apparently used the steel system, and was standard everywhere else :confused:
    That’s not to say the engineering and quality of the Kline isn’t right up there, just a little disappointed in the sound at this stage.
  19. JohnnyGobbs
    JohnnyGobbs Rookie
    Jan 2, 2025
    10
    Johnny Gobbs
    I want to do this on my f430. Everything is stock on my car but I want to throw the sline on it. Is it way better than stock? Will it change the pitch and give me more f1 vibe? Thx.
  20. Jaymac
    Jaymac Formula 3
    1,001
    New Hampshire
    Jeremy McCurdy
    It’s the cats. Trust me.
  21. DutchFerrari
    Apr 7, 2022
    790
    Jeroen
    To me, it sounds a million times better than the stock exhaust does.
    see the following video to download, that is my car with stock headers and cat, just the Sline exhaust
    JohnnyGobbs likes this.
  22. JohnnyGobbs
    JohnnyGobbs Rookie
    Jan 2, 2025
    10
    Johnny Gobbs
    Alright I’m in lol. Did you just get the non valves sline?
  23. DutchFerrari
    Apr 7, 2022
    790
    Jeroen
    Obviously, why would i want it to be quieter at times?? i want it to be as loud as possible at all times :) i dont drive it that much (but still more than 90% of other owners it seems looking at mileages) so the neighbors will just have to suck it up just like i need to hear their dogs barking and kids crying every now and then..
  24. DiSomma6
    DiSomma6 Formula Junior
    Nov 27, 2023
    284
    Erik
    Well this morning was the first cold start on my "new to me" Capristo Sound 3" exhaust. I had this installed yesterday on my Euro-spec 360, which has the factory shielded headers (no pre-cats).
    I LOVE IT!!!! It literally has changed my life lol. Totally different driving experience. I see why some say it's too much, especially on a euro car. It's very loud and when you approach any outdoor restaurant during rush hour, it's entertaining to watch everyone stop eating, stand up and try to see what's coming up the street lol. But, now I'm forced to start the car with the garage door closed, then open it after the engine calms down. The cold start is very loud - think Fabspeed Aventador loud. I'm not close to kidding. Neighbors have every right to complain about this one lol.
    mb5 and Jaymac like this.
  25. Mrjb
    Mrjb Karting
    Jan 12, 2022
    97
    Matt
    H
    Have you got sports cats Erik?
