News
355 How to mount the front hold release lever ??
Discussion in '348/355' started by slracing, Jun 10, 2020.
  1. slracing
    slracing Formula Junior
    Jan 13, 2011
    410
    Europe
    Getting the lever mounted inside...with the cable already attached...next to impossible!! Does the cables need to be deattached in the front compartment? Clues appreciated;-)
  3. slracing
    Jan 13, 2011
    410
    Europe
  4. Ferrarium
    Ferrarium F1 Rookie
    3,018
    Central NJ
    Eric
    Never done it buy my guess is that is exactly right, mount lever run cable, attach the release is typical for about any cable release system. Sam issue with the engine lid release. Provably need to remove the trunk liners for access as well.
  5. sevminasyan
    sevminasyan Formula 3
    1,131
    Glendale, CA
    Steve
    Loosen the retaining nuts on the front latches to be able to pull the cable back and once u install the release then use pliers to tighten the cable then tighten the nuts in the latch itself
    Beetle and slracing like this.
  6. 355OXO
    355OXO Karting
    Apr 16, 2006
    161
    Simon
    If the cable is in situ already and you just want to replace the lever box. If it is the same as the rear boot release. you can hacksaw where the cable fits the release body to remove without taking cable out completely. do the same with the replacement and just refit the old cable. Hope this helps.
  8. 355OXO
    355OXO Karting
    Apr 16, 2006
    161
    Simon
  9. slracing
    Jan 13, 2011
    410
    Europe
    Thanks for replying- will give it a shot one of these days
