How to remove Diablo engine | Page 2 | FerrariChat
Discussion in 'LamborghiniChat.com' started by ang308, Jun 16, 2025.
  1. ang308
    ang308 Formula Junior
    455
    Stamford, CT
    Billy
    On top of driver side wheel well there are connections that go to phase sensors there are 2. Disconnect those. For my car the pink connector in front is for bottom phase sensor
    white out likes this.
  2. ang308
    455
    Stamford, CT
    Billy
    Boomhauer likes this.
  3. ang308
    455
    Stamford, CT
    Billy
  4. ang308
    455
    Stamford, CT
    Billy
    Next to that is power steering pump. Put a pan underneath to catch power steering fluid. Smaller connector is 17mm. Larger banjo connector is 15/16in.
    white out and Boomhauer like this.
  5. ang308
    455
    Stamford, CT
    Billy
  6. absostone
    absostone F1 World Champ
    10,253
    Good luck to you. How much is the clutch kit?
  7. ang308
    455
    Stamford, CT
    Billy
  8. ang308
    455
    Stamford, CT
    Billy
    At some point my car was updated to newer style clutch. So as of right now clutch, pressure plate, flywheel, throw out bearing and pilot bearing cost about $3200. All new
    absostone and ryalex like this.
  9. ang308
    455
    Stamford, CT
    Billy
  10. ang308
    455
    Stamford, CT
    Billy
  11. ang308
    455
    Stamford, CT
    Billy
  12. ang308
    455
    Stamford, CT
    Billy
  13. ang308
    455
    Stamford, CT
    Billy
    Undo the two starter cables that go into frame. This is access by oil filter opening (triangular piece removed in beginning). There is a ground and positive cable. Positive go to main fuse with 15mm nut. Behind that the ground goes to a 13mm stud on the frame. Disconnect both wires
  14. ang308
    455
    Stamford, CT
    Billy
    And last,y undo motor mount bolts. I forgot to take photo. Use a 24mm socket and undo both sides from under car
    On the rear differential mount Undo the 22mm nut and bolt that goes to bracket and undo the rear mount brackets with 4 13mm bolts. Two more ground straps on these
  15. ang308
    455
    Stamford, CT
    Billy
    knocker, white out, Schultz and 5 others like this.
  16. Great thread!
    Boomhauer and absostone like this.
  17. Peter K.
    Peter K. F1 Rookie
    4,454
    Connecticut
    Peter K.
  18. Peter K.
    Peter K. F1 Rookie
    4,454
    Connecticut
    Peter K.
    Great thread. Diablo guys will thank you! Car looks to have been driven like it should.
    I might be in the market next year for a rough Diablo
  19. ang308
    455
    Stamford, CT
    Billy
    Yes car gets driven. They all do. Not interested in cream puffs. An amazing this about cars of this age is the cars feel like you’re driving faster than you really are. I drive the 308 and at 40 miles an hour feels like I’m driving 70. So much fun.
    knocker and Boomhauer like this.
  20. white out
    white out Formula 3
    Mar 3, 2010
    1,312
    While the motor is out, it is a great time to replace the motor mounts and driveshaft bearings (from gearbox to rear diff).
  21. ang308
    455
    Stamford, CT
    Billy
    Have you ever taken out the driveshaft? I see only one snapping in front bearing. According to parts diagram there should be 2. It looks like it’s behind oil seal. Do you remove seal and then snap ring? Or remove the rear snap ring out and then use slide hammer to pull out shaft and then get to those bearings?
  22. white out
    white out Formula 3
    Mar 3, 2010
    1,312
    I haven't on the Diablo, but have on the Murci - driveshaft is not enclosed and I think the VT Diablo is a similar design where the early Diablo has the driveshaft enclosed. It is snap rings holding the bearings in and the driveshaft comes out the bell housing side of the motor.
  23. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,877
    Bologna
    As a guy with a 92 that will eventually need a clutch upgrade, I am grateful for the write up as I plan to do this myself, maybe over the winter (or hopefully not if my clutch remains in good health). I have watched an engine removal being performed on my Countach, it looks dangerous but seems all a question of angles and height of the car off the ground, something that experience teaches. I suspect the job is easier on a Diablo as the engine bay is more spacious and the shifter can drop out of the cabin once the knob is removed as unlike a Countach it uses an exposed linkage.
    How much did you have to rotate the engine to get the transmission to clear the chassis when pulling it out? What type of engine hoist did you use? The rigs I have seen for use with a Countach are somewhat specialized as it needs to be lifted quite high to clear the car.
    I was also told there is a near impossible to reach coolant hose above the Diablo's bell housing that is a good idea to replace.
  24. Dmond
    Dmond Karting
    Jun 18, 2025
    61
    New Jersey
    Dave
    Remove rear tires. Lug nuts are 19mm.
