What a pretentious post. They made less than 500 factory gated 360 Modenas for the US market. In what world is a sub 11k-mile example a “driver”? It’s funny you think spending $50k+ with EAG to convert your F1 Spider affords you the ability to be an ass to others here. You really need to check yourself, Kent.
You can make your point without the hyperbole and name calling. Years in Production: 2001, 2002, 2003, 2004, 2005 The Ferrari 360 Spider is Ferrari’s 20th road-going convertible. 2,389 Ferrari 360 Spider models were built for the US Market, with 670 being produced with the gated 6-speed manual transmission. The 360 Spider was the best Maranello built in the time period in terms of technical content, styling, and performance, so to purchase a Ferrari 360 Spider for sale is to own a crucial touchpoint in the development of the modern Prancing Horse. https://www.continentalautosports.com/ferrari-range/ferrari-360-spider/ This must be the source of the 500 Modena's? https://www.continentalautosports.com/ferrari-range/360-modena/ So close to 1100 in total for the 360's as a model in the US.
A converted Ferrari will always be a conversion and worth less than a factory original keeping everything else the same i.e. miles and options. How much less that is up to the market to decide; therefore being able to the tell the difference is important and I would have a dealer pull the build sheet before buying.
Gidday guys, Hello from Oz. I'm not sure why it is so difficult to determine if your 360 was born a gated manual or F1. You do realise that Ferrari have affixed a plate to the inner door jamb that specifies this? I own a UK/RHD example but I'm sure it would be the same worldwide, you look at the plate in ther inner door jamb (normally drivers door jamb - so mine is on your US passenger side) and it has details of the VIN number and also TIPO (type) which is a F131. It should also state the letters ABM / ABE for Modena or ADM / ADE for Spider. ABM = 360 Modena 6 sp manual (aka gated) ABE = 360 Modena F1 ADM = 360 Spider 6 sp manual (aka gated) ADE = 360 Spider F1 Hope this helps you and it's the most definative way to determine if your car is a gated manual or F1 - especially if you are looking to purchase. Cheers, Dave. P.S Not sure, but would assume something similar applies to F430. Note: Below pic is an example and 360 Spider 6 sp manual gated (not my car) Image Unavailable, Please Login
That plate is not on US Ferraris. Here is what we have over here. This is for a 575M, but the 360 ones are the same except the front part of the VIN is different, as are the weights. Image Unavailable, Please Login
Really? That's very interesting. The plate looks like a country compliance plate. I wonder why Ferrari combined the two for US market? For example we also have a local compliance plate for Australia, but it's a separate plate to this door jamb build plate and in a different location. Well there you go....(I'd still look in both door jambs in case there was another ) But in anycase the model designation still holds, so if you can confirm the ABM/E or ADM/E code for your car it will identify trans. My car also had a certificate of conformity issued by Ferrari SpA when new which was a two page typed letter and it designated ABM (Gated Modena) and specified Gearbox type: "mechanical, hydraulic with lever on the central tunnel". Good luck with it guys. Dave.
Looking at the gate is no good- plenty of reproduction gates out there with the horsey on them. In terms of parts to check, the clutch pedal would be easier to look at. It should appear the same as the brake pedal- many reproductions are CNC from billet or quite “rough” castings. A look at the clutch master might show a willwood in there rather than oem. F1 cars will certainly still have the plugs there for the TCU. Many converted cars still have the holes in the steering column covers where the paddles would have gone, or maybe have some plastic inserts over them. Aftermarket turrets and control plates are pretty obvious too if you can get a look at them, but they’re mostly out of sight. Sent from my iPhone using FerrariChat
It is. 100%. I spoke to the man who removed it from a salvage yard in Italy. I've sold repro's and real ones, but I've always been straight about which is which.
