How to use fuel injector puller? | Page 3 | FerrariChat
Discussion in '308/328' started by climb, Jun 7, 2011.
  1. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    Same as my 1980 non-QV 2V.
  2. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    Thanks, I'll keep it in mind. (luckily we have strong American car culture so USA parts are covered good.)
    When I change injectors, I also notice that injectors came out very easy.
    I made correct tool in half hour;
    I veld two nuts with correct threads together, used tube, long bolt and couple of shims to pull and push injectors out and back in.
  3. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    Same as my 1980... one of the first few "i" cars
    So it must be they sometimes used the screw in plastic seat (ala VW) with the fat O-ring and then sometimes used the big rubber seal with the metal collar/cap. Doesn't appear to be any set point when they transitioned from one to the other. I've certainly seen cars between yours and mine with the plastic seats and O-rings. I had no idea they were still using this setup as late as your car.
    Whats the old Foose line..? "it's what you learn after you think you know it all that matters"
    Rick
  4. DWPC
    DWPC Formula Junior
    Mar 10, 2011
    733
    Sedona AZ
    Dennis
    Does the seal simply expand against the injector from compression when the carrier is tightened, or must the injector be pressed into it?
    How did you check and adjust the new injectors?
  5. mwr4440
    mwr4440 Five Time F1 World Champ Rossa Subscribed
    Jun 8, 2007
    58,118
    Bavaria, The 'Other' Germany
    Mark W.R.
    The injector fits tightly in the seal and the seal fits tightly in the carrier. I could not get the injector into the seal or the seal into the carrier w/o lub of some kind. I used a very light coating of dish soap and a good amount of pushing.
    It doesn't just fall in together. It is pretty TIGHT.
  6. mwr4440
    Jun 8, 2007
    58,118
    Mark W.R.
    Same as my '81.
