How Well Does The 575 AC Work? | FerrariChat
Discussion in '456/550/575' started by cmaxcliff, Jan 7, 2024.
  1. cmaxcliff
    cmaxcliff Rookie
    Jul 5, 2021
    36
    Chester Springs PA
    Cliff Murray
    Mine has been checked by a Ferrari mechanic as ok but I have serious doubts.
  2. ///Mink
    ///Mink Formula Junior Silver Subscribed
    Sep 5, 2006
    820
    Fair Oaks, CA
    Tom Mink
    Can't speak to the 575 specifically, but the 550 has great AC when it's in proper working order. And for context, I live in Sacramento, which is like living on the surface of the sun during the summer.
    Texas Forever and F456M like this.
  3. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,174
    Have an AC specialist change out the refrigerant and oil after changing the filter/receiver and vacuum evacuating the system. He can do a leak check for you, too. My compressor needed rebuilding after about 15 years of service. Hopefully yours does not. Mine blows very cold.
    Texas Forever likes this.
  4. cmaxcliff
    cmaxcliff Rookie
    Jul 5, 2021
    36
    Chester Springs PA
    Cliff Murray
    Thank you both for that input.
  5. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    Terry, do you say the AC will blow colder if you change the AC compressor oil??
  6. Oengus
    Oengus F1 World Champ Rossa Subscribed Silver Subscribed
    Sep 29, 2004
    10,826
    Between timing belts/chains or West Palm Beach FL
    Chas
    My 550 blows really cold and I’m in South Florida……hot as balls!
  7. cmaxcliff
    cmaxcliff Rookie
    Jul 5, 2021
    36
    Chester Springs PA
    Cliff Murray
    Naples is great, in the winter!
  8. cmaxcliff
    cmaxcliff Rookie
    Jul 5, 2021
    36
    Chester Springs PA
    Cliff Murray
    The mechanic will give it a look later this week.
  9. LeoBRK
    LeoBRK Formula Junior
    Sep 26, 2010
    454
    NYC
    Leonardo
    Definitely sufficient never had a problem in summer
  10. tazandjan
    39,174
    No, it will blow colder if it has the correct mix of refrigerant and oil and the system has been really well evacuated before filling. Ferrari actually recommends changing the filter/receiver and refrigerant every two years on 575Ms. A bit of overkill if you pull a good vacuum after changing the receiver and refilling.
  11. Chupacabra
    Chupacabra F1 Rookie Owner Rossa Subscribed
    Sep 30, 2005
    3,529
    Behind a drum kit
    Mr. Chupacabra
    Mine is great
  12. Auraraptor
    Auraraptor F1 World Champ Lifetime Rossa Owner
    Sep 25, 2002
    13,974
    MO
    Omar
    Edit: found it. It looks like its PN 64894200, not the pollen filter PN 64241800? The associated pressure switch is PN 66374400. The manual:
    My AC works 'ok' on a warm day. Some days it works better then others but if over 100, its not the best. Sounds like I need a proper service.
    That said, my 456 is much better/colder so go figure.
    This was a good thread on the compressor: https://www.ferrarichat.com/forum/threads/575-air-con-compressor.634500/
  13. tazandjan
    39,174
    Pollen filter is supposed to be changed every year but you can save the frame and buy filter material just about anywhere. They used to be cheap, but no longer.
    There are tons of AC receivers/dryers/filters that fit fine with no yellow box tax.
  14. Auraraptor
    Sep 25, 2002
    13,974
    MO
    Omar
    I am trying to figure out if it’s beneficial to also change the pressure switch 66374400 at the same time. Going through 20 years of service hx, my dryer is over due and likely explains my feeble AC. Does someone have the 575 WSM that they could post copies of the AC system service instructions for the dyer? That should say it.
    575 AC Evaporator Service:
    • Vacuum Evacuate AC System (ideally overnight if possible)
    • Check AC Compressor for leaks (rebuild if needed)
    • Replace Receiver/Dryer (64894200) - if riveted, replace with threaded fastener for future service
    • Replace Pressure Switch (66374400) ??
    • Replace AC compressor oil/refrigerant (R134 charge: 1.68 lbs or 26-27 oz)
    vraa likes this.
